In this youtube video demonstration, I present an unusual observation that became evident after shutting down my trigger generator. Even with the trigger turned off, residual energy persisted in the system, most likely due to ambient induction. I utilized this lingering energy to activate a high-voltage pulse module, which then pulsed back into the coil, effectively taking over the role of the original trigger.
The result? Output voltages soared into the tens of volts range, accompanied by substantial production of radiant energy. This was verified by a rudimentary radio setup that I had at hand.
In the video, you'll find the schematic outlining the setup. This configuration could potentially serve more sophisticated applications—perhaps energizing your capacitor discharge circuits or similar endeavors. The further potential of this arrangement remains an open field, inviting your exploration and ingenuity.
https://youtu.be/ZbnNPfvI_DY
If you keep experimenting soon enough you'll find out that you don't even need a power source to extract what you're looking for
Switched off, but also fully disconnected, avoiding air gap and other forms of connection?
Have you tried immediately after disconnecting, to remove the source by a significant distance, 10 or 15 meters, to compare readings? Just to make sure what you call "ambient" is really ambient.
Yeah sure, everyone who gets fe/ou is a hoax, or just stealing from power grid ;D
Well let's put it this way ;D I found free energy a long time ago. I also found this site gets trolled, Much of the activity here is trolling actually for some reason.
So it's my way to have a bit of fun with it and come on here from time to time to "troll" the trolls 8) As you can see it works!
And who knows, Once in a while someone legit comes by, If they can use the information. All the power to them. ;)
It's my way of having a little fun with the "that will never work" folks. While still providing some valuable info to those who dare to experiment.
Take care!
Joel
Honestly ,
there are plenty to test your setup .
Scrutiny ( productive scrutiny from other experimenters)
Is always wonderful to have, and I have seen quite serious researchers ( who share their bench work and research ... comment in your topics!
It is scientific method to run towards scrutiny..
And you typically do this !
Hopefully more replication or discussions on circuit and components
will open up Greater understanding of how energy inters the circuit.
Respectfully
Chet K
Hi joel, hi all, if authentic beings is what you want, that is what you will get, more and more. 8)
My first guess, would be that the phone wire, with the plastic insulation around each individual wire and a plastic sheath insulation surrounding all of the wires, it is tapping from the normal ambient voltage we are immersed in.
It will still work fine, even without all the radiation from other technologies.
The coil you are using has good capacitive qualities and resonance is probably easier to achieve as well.
This is probably along the lines of the old world's antiquetech, which tapped into the earths voltage potential.
Raise that coil high into the air and you might see improvement in output, it will be like an accumulator energy antenna.
Flux capacitor anyone. ;)
peace love light
