Overunity.com Archives
Energy from Natural Resources => Gravity powered devices => Topic started by: iacob alex on October 10, 2023, 09:16:29 AM
Title: Unbalanced pendulum…
Post by: iacob alex on October 10, 2023, 09:16:29 AM
.....this time , as an one-piece "compound" pandulum and a particular fulcrum playing momentum and inclined plane physics , at :
    www.geocities.ws/iacob_alex/Some_Drafts/text050.jpg
    I hope that a simple test can clarify the validity of this proposal ...
    Al_ex
Title: Re: Unbalanced pendulum…
Post by: Cloxxki on October 12, 2023, 10:13:24 AM
The way you've drawn it, two weights are on the rod that has the fulcrum on it, with the third off the side, directly across the fulcrum? The blue off the side would just be hanging down unless one of the other weights is much higher. Sure it will all dangle around happily.
What's the point of it though, what would make it "valid" for you? Never ceasing to move and even press through external resistance to keep moving?
I suspect it will simply find an equilibrium with the lowest possible centre of mass from which any and all movement will require a lifting of that COM.
Title: Re: Unbalanced lever…
Post by: iacob alex on November 10, 2023, 03:04:47 PM
.....due to a 90 degrees switching pendulum , every half turn , as a proposal at :
    www.geocities.ws/iacob_alex/Some_Drafts/text026.jpg (http://www.geocities.ws/iacob_alex/Some_Drafts/text026.jpg)
.....with the help of a modified rising butt door hinge ( screw ... inclined plane...simple machine ) ,if we take  a look at :
    https://www.eBay.co.uk/itm/232597307302 (https://www.ebay.co.uk/itm/232597307302)
    https://www.dndhardware.com/What-is-rising-butt-hinge-and-when-to-use-or-not-to-use-it-id3950700.html (https://www.dndhardware.com/What-is-rising-butt-hinge-and-when-to-use-or-not-to-use-it-id3950700.html)
    Al_ex
