I know I might be a bit yellow on this...and I am not italian
But just in case some-one didn't know, here is, for the record, a scheme of a setup for a Testatika device.
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2Fwww.progettomeg.it%2Ftestatika%2Ffullcircuit.gif&hash=fff7da76760a15778b6f4d23dfe0e7daafbddd68)
just cut and past like I did...
And this topic, I think, has to do something about the materials. Anyway it looks like an indept analysis...
http://www.progettomeg.it/testatika.htm
http://www.overunity.com/index.php?topic=1682.0;wap2
Testakita
http://www.pixerve.de/41903/pese.html Schaltschema mech
http://www.pixerve.de/42809/pese.html Schaltschema elektr
http://www.pixerve.de/42810/pese.html Schaltun-Detail Diode
http://www.pixerve.de/42510/pese.html Linden experiment
http://www.pese.150m.com/fe/index.html
ah cewl,
thanks!
Pese
Have you ever worked with this technology before?
Quote from: IronHead on February 07, 2007, 08:58:16 PM
Pese
No , but i look all papars since long time over this.
this is "radiant" , it make dangerios radiation out , for
this the eorking is stopped.
so as hendershot moray possibly als hubbard worked wit "radium"
or other "hrmless?" supplies insided.
Pese
P.S. see also M.Mayer (France) with his 3 coil patent , this will also vreate radiation !.
Mayer Device:
http://jnaudin.free.fr/html/mmcgen.htm
Stefan Marinov became a member of the Swiss group that has the Testatika devices, but they would not disclose the means of operation since Marinov would not swear an oath of silence. Marinov felt the technology should be shared with the world - the group disagreed. Marinov WAS allowed to inspect the device and had some idea of how it may operate. Marinov later discovered that a divergence of the magnetic vector potential produced anomolous momentum and energy production.
Marinov stated on several occasions that there were no "fields", only the "potentials".
Even Einstein also came to the conclusion that fields were not the answer:
QuoteI consider it quite possible that physics cannot be based on the field concept, i.e., on continuous structures. In that case, nothing remains of my entire castle in the air, gravitation theory included, [and of] the rest of modern physics. (Albert Einstein, 1954)
Our entire foundation of physics is built to describe effects, but can not describe the cause. The mathematics developed to describe our universe only describes the illusion we have created - not reality.
Quote from: Grumpy on February 08, 2007, 10:46:10 AM
Agreed!
http://babelfish.altavista.com/babelfish/trurl_pagecontent?lp=it_en&trurl=http%3a%2f%2fwww.progettomeg.it%2findex.html
(English translation of Italian Testatika page)
Above in MSWORD DOC and PDF (they are a little rough) (notes included at end - from site):
OOPS!
Original source in English:
http://website.lineone.net/~aarekhu/
I have seen posting of working replications - I'll dig them up and post.
Quote from: Grumpy on February 08, 2007, 07:42:49 PM
please do that.
you're this first I've heard about working replications.
So far personally, I've seen only attepmts to explain the machine.
If you have more, please share with us.
Thanks.
Hi all,
My name is Peter from Holland, I just registrated here.
I have studied this for more then a year now, and i am almost certain, how it works.
In the tubes is no radium or any radioactive materials. Just copper wire, glass ( against sparks ), aluminium and again glass ( against dust ). These tubes are getting charged by ions from the air. This is where the energie is coming from. ( you put a negative charge on the wire, and it attracs positive ions from the air which are getting on the alumium tube ) it only works with high voltage.
Futher, the perforated lamels on the 2 discs, are made from chroom-steel ( rvs 410 ). it can be made magnetic. and it will be magnetic while running, because there is coming through a high voltage. ( only negative or positive ) This is a part of the key for spending around.
I have allready the two discs ( one meter diameter ) glas and vinyl. I am working in a fabric, where we make perforated metal plates. I have allready the chroom-steel plates. My uncle is making the drawings in autocad for the perforating plates, so it can be fabricated on my work.
I dont need the low voltage ( 220 - 270 volts ), so i dont need the big transformers in front of the testatika. I need the high voltage.
I also have studied, the flying saucers from the germans, and its easier to understand that then the testatika. I did not explained everything on the testatika, but when i am finished, i will give the invention free away. and will go on with more ancient inventions. since I am a child, I have allready inventions in my head, like the implosion technik, and I have seen very strange things in my life. so there is more then only the " normal " people think. There is also a city under the ground beneath the pyramides in egypt. ( if you go there on holiday, you will see near the pyramids, that a gate is guarded by military )
I hope i have finished this device by the end of the year, you must understand, that it is expensive. so every month i buy something. I dont need so much anymore. The discs costed me together 750 euro's. ( one meter big, 10 mm thick ). I want to build a good one. so it cost some time.
I hope one day, that everyone knows the truth about past, free energie devices, and ufo's, and why they are here. I am certain, that in a few years, something bad will happen on this planet. and it has to do with the maya calander.
Ok, this was it first.
Greetings from holland.
Ik ben erg benieuwd!
Keep us informed
Is this the replication you were thinking of?
http://rimstar.org/sdenergy/testa/testareplicationjr.htm
I'd noticed that the website that had been hosting it disappeared,
the second time that's happened, so since I had a saved copy I
uploaded it to my site above. Hopefully that means the link will
be good for a much longer time.
-Steve
http://rimstar.org
The "title" say it !!! :
Testatika Clone from or by Jorge Resines.
Shown "as" equivalent ,but "shure" only as designer modell .
not an working clone,
Yes. That's it. Have seen same pictures on other sites in Germany and Russia.
100w
I agree that it may not be a complete, perfect, exact duplication. I would expect some slight variation.
It is still a lift of faith for those researching Testatika.
I agree it's probably using more energy to rotate the two discs
than the 100W and 300W it puts out. At least I can see it
taking that much power to run the motor (if there is a motor and
a wall outlet behind it.) The discs seem to be running pretty
fast and I count 5 pulleys at least.
The original webpage that I'd saved was titled "Testatika
Nachbau von Jorge Resines". Nachbau is german for Clone.
I was just being faithful to the original when I used the
term "Clone". "von" can be either "from" or "by" so I used
both.
It is a beautiful thing though. And from my limited experience
so far, getting 300W out of rotating discs is pretty impressive.
I wonder if they just replaced those two large coils on either
side with concentric grid cylinder style pots, would they start
generating excess power?
Also, if those horseshoe magnets are playing an active part
in the overall circuit, given their placement in the circuit,
they're likely serving the same function they are in the
real testatikas (I suspect they're acting as diodes.)
If anyone knows the history of this replication (Stefan?) it
sure would be nice if they'd share it.
-Steve
http://rimstar.org
