What's a good cell design to start with? I have seen cells that look like batteries with up to 70 electrodes and cells using CVPC pipes. My original idea started out as a cell built like a battery, but as time passed, I have been slowly been progressing towards the cell using a schedule 80 CVPC pipe as the cell housing.
CPVC will muck the water very fast and seemling endlessly.
Cell Cast Acrylic is very good
Where would I found Cell cast Acrylic. That doesn't sound like anything I can find very easily around my area.
Any plastics shop or you can use 316 stainless steel.
I was reading the hydrostar PDF that i have posted under my topic Power In Water, and it recommends that you use CPVC for the cell housing.
Try it ,
I had little luck as it produced lots of scum. But maybe it was something else. I don't think it was because I took out the cell and put into Tupperware and no scum. Tupperware is good for testing but not for a system in a car or? The Tupperware can not handle high heat conditions for long periods of time.
Thanks, I'll try different alternatives for the cell housing. Right now I'm still in the research phase, so it may be a while before I start actually building any kind of electrolysis cell. Plus i have other ideas in my head that I want to try. One idea is based on something that a character built in a fanfiction. It is a circuit that recharges the battery using a small amount of power that is recycled from the output of the circuit. The fanfiction is called Jedi Harris on Twisting the Hellmouth. He builds the circuit for the power supply of his light saber. If someone, me included, could make a circuit like that, there would be unlimited uses for it.
