HI TO ALL IN THIS FORUM
3 MOUNTS I TRYING TO MAKE SOMETHING ,NOW MAKE SOMETHING VERY GOOD ..ALL YOU NEED IS TO HAVE A 1 OSCILATOR WHIT ABOUT 150 Khz,and a secundary out coil whit SPEAD DIODE WHIT BIG CAPACITATOR ABOUT 20000 uF ..ITS WORKING LIKE THIS...
MAKE I 8" COLECTOR COIL HO IS ABOUT 40 TURNS , THEN AROUND THIS COIL MAKE ANOTHER PRIMAR COIL WHIT 20 TURNS THEN IN THIS PRIM COIL BRING THE OSCILATIONS WHIT 150Khz THEN IN THE OUT COLECTOR COIL IF YOU BRING A BULB 12 VOLTS YOU CAN SEE THAT NOTHING HAPEND ........ IF YOU WANT TOLIGHT THIS BULB ALL YOU NEED IS A SPEAD 4 DIODE WHIT 1 CAPACITATOR , ABOUT 20000uf ............................. T H E N YOU HAVE WAIT
JUST ABOUT 8 SECOND THEN THE CAPACITATOR WHIL CHARGE MORE POWER THEN INPUT THEN YOU CONECT THE BULB TO THE CAP THEN THE BULB WHIL START TO LIGHT VERY STRONG ABOUT 2 SECOND ,,,,, AND THEN ITS THE SAME PRINCIPE AGAIN .................................................................................
I T S VERY IMPORTANT THE SPEAD DIODE IF YOU NOT GET A SPEAD DIODE YOU GET NOTHING THIS DIODE IS A HAVE SMALL RESIST ABOUT 100 OHM , BUT IF YOU HAVE STANDAR DIODE THIS RESIST IS 500 OHMS ITS
V E R Y I M P O R T A N T IF YOU GET MORE SPEAD DIODE IN PARALEL CIRCUITS THEN YOU GET SMALL RESIST FOR THIS OUT COLECTOR 150Khz ...
AND ANTHER THING .. IF YOU BRING MORE DIODE IN PARALEL THEN THE CAPACITATOR WHIL CHARGE MORE FAST ,, VERY IMPORTANT WHEN YOU CHARGE THE CAP. THE BULB MOST NOT CONECT TO CAP ,, WHWN YOU CHARGE MAX. CAP THEN YOU CONECT THE BULB...
IN THIS DAYS I SEND PDF AND IF I CAN THE VIDEO FILE TO SEE
THANKS MACEDONIA CD
Sounds to me just like a normal transformer, though I may be getting the wrong gist of this device.
Can you show your math involved in the calculation of Input and Output energy?
I would like to see how you came to this conclusion.
Great! Overunity!
.....(or overignorance?).....
bye :-X
OK PEOPLE IF YOU DONT BEALIVET YOU SE THE VIDEO CLIP NEXT DAY WAIT THAN YOU CAN SEE THAT IS POSIBLE TO MAKE THIS CAO CAO CAO
EUREKA ,,,, HEY DID YOU NOW THAT THE Nikola Tesla is from Macedonia his father is from Macedonia ::) is true bealivet
By no means are we accusing you of fraudulent claims, but the description provided doesn't seem to prove how you concluded that 50 watts were being produced from 8 watts of input energy.
Also I was under the impression that Nikolai Tesla was from a military front in the Austrian Empire. I don't think that Macedonia was ever part of the Empire, but at one time Austria-Hungary did occupy the Macedonian lands under their consent for a short period (I believe in the late 1800's). Tesla then moved to France and then to the United States.
Granted Tesla's father was Serbian, which did include some parts of Macedonia from the 1800-1900's, so you can state that was Tesla has somewhat Macedonian ancestry, but saying he was from Macedonia wouldn't be entirely true.
Cheers!
@MACEDONIA CD
When you say Spead Diode, I found this one. Is it OK? I'ts 100 ohm.
https://secure4.vivid-design.com.au/jaycar2005/images_uploaded/BAW62_2.PDF
Also, while you are making video or photo, do you have a rough schematic diagram of your set-up with more details on the components?
