http://www.youtube.com/watch?v=ZI4NDrPQ2rA
Anyone know any details about this device?
OK, my hopes of getting any useful information from this guy have just dropped...
http://www.youtube.com/watch?v=xfuay_nsWFI
At least the first video with the magnet motor
seems to be pretty realistic, that it could turn
and
accelerate itsself !
The other videos, which he has online there
are more political religious ?
Did not watch them all,
but I think this guy has only got a chance,
if he makes his technology open source.
Regards, Stefan.
Interesting, but there does not appear to be any forward thrust. Just resistance to reverse movement.
Quote from: ken_nyus on September 11, 2007, 09:37:03 AM
Oh, all that means is that he is not interested in getting debunked. Take for example George Walker Bush, he is a complete baboon but he did make it to be president. Not a very good one but he sure made it all the way. Apparently there is no brain needed for the task, it just takes doing things. Last time God send Joe that didn't work out so well.
For you to start talking about this man's stock options, post stamp collection or Britney spiers fanboyism real has nothing to do with the topic. To start talking about such subjects shows you to be bullshit yourself? You post a screenshot of an unrelated video without a link to the video?
Here is his new video where you can see his measurements on the scale.
http://www.youtube.com/watch?v=Xs_pszg03f8
He gives the measurements and the promise it will be open sourced by x-mas. I strongly advice you not to change church over it? haha? What do you care about his religion anyway? I should care about this?
Now that I think about it, it's a very interesting phenomenon actually. It's the domain where credentials rule over facts. It should not surprise you how this guy escaped this dogma.
I know for sure the truth is not a person.
You may think it's holy Einstein, but it's not. *grin*
Quote from: gaby de wilde on September 15, 2007, 12:56:23 PM
Good grief Gaby!
This guy has not shown anything but an unfinished magnet motor, unfinished means untested!, and the rest of his videos concerning the religious aspects certainly puts a bad light on him!
religion was created to control the peoples, Poeples need to forget about this thing and move on, stop believe in the crap made by the illuminati and live your life !:)
His idea will probably not work.
He does not have any thrust forward, just a stopper backwards.
1) Forward sticky spot is easy to overcome but there is no real thrust forward.
2) Backward sticky spot is hard to overcome but this does not matter as it's not going backwards.
3) When the whel is fully equipped with all the magnets as he tells us, there is still no thrust forward.
4) The wheel will get stuck in the equilibrium between the sticky spots.
5) Perhaps I'm totally wrong about this (at least I hope I am) and then we will finaly see a working magnet motor.
Quote from: RunningBare on September 15, 2007, 01:25:56 PM
Sure, but if you make an account specially to post a screenshot of a video then you are an imbecile. Just the link would have been good enough. But apparently that was not enough for some weird reason.
Don't bother trying to understand, I know you have a fetish with stalking people.
How weird you cant spot it jet?
Quote from: Honk on September 15, 2007, 04:42:19 PM
did you talk with god or something?
Looks like a partial Perendev motor. Based on the same principle anyway. I really like the part where he says: "Now if you are a physicist, you'd understand what I'm talking about"
what he needs to do it put a stopper just passed the "kick" in the forward direction - so that the full force of the push is applied to the scale in that position to measure it.
then compare that to the scaled-force measurement required to push it through the stcky point.
weighting it in reverse does nothing for me really, as we are not interested in that force, this particular wheel is designed to spin the other way (or at least thats how he makes it seem). we'll see when its finished
"If you're a physicist" you would know that the amount of work generated from the magnets repelling each other would be equal to the work it took to get the magnets into that position of opposition.
Anyways, I think a better design would have the static magnet on the left side(rather than the top right) so that gravity could help with the sticky spot.
in a symmetrical magnetic field yes the work forces are equal on each side, but when the flux lines on one side are manipulated this can change. Altough doing so depletetes the strength of the permanent magnets rather quickly, because it often involves placing magnetic shielding on them, or placing magnets against each other with like poles facing, to misshape the lines of flux.
You can also use a a certain flux-canceling method to create 2 "synthetic" monopoles and have only ONE force,. repulsion. of course directing this in a usefull manner eludes me...
Yes but the rule I mentioned still equally applies in monopoles and/or misshapen flux lines. If I am mistaken please give me a scenario where the rule doesn't apply.
"Yes but the rule I mentioned still equally applies in monopoles and/or misshapen flux lines. If I am mistaken please give me a scenario where the rule doesn't apply."
if there is such a thing and i had access to it, thered be a video of a working device on here for you to see ::)
This motor idea will not work.
You can simply look at the video to see where there easy spot is located vs the tough spot.
The tough spot comes first and in order for the rotor to get a forward thrust the easy spot should be located just afterwards, like 0.1-0.3 inch.
But the easy spot is located far away e.g 4-5 inch from the repelling tough spot. This means that the rotor will find equilibrium between spots.
There is simply no continuously thrust forward due to this gap between sticky spots.
It always amazes me how some people are more diligent in defending their half-built devices than they are in finishing building it. I wonder what his motivation is in defending his device? He hasn't yet asked for investors. Maybe he's faking a magnet motor to try to gain status to help promote his other religious videos.
Hello Folks,
You may have realised by now that Brian Leonard Golightly Marshall has become a member here and his first post on his video start here as Reply #3 September 12, 2007: http://www.overunity.com/index.php/topic,3245.0.html
Gyula
