well in this design i get rid of the water it seams simple and should be fairly easy to construct i was thinking of using a tesla turbine as the vacume pump and as well as the forced vacume acexelerator pump ;D could use compressed air to start in in operation and if the gearing was right in the tesla pump then i think it would gain in speed in a closed loop system
i will draw somthing in a bit about this system
william
;D the more i think of this the more i like it
there just so many ways it could be done easy and cheeply it could even be an open loop system with just a vacume pump simple im sure it would spinn really fast i was thinking of 4 input nedles focousing right on the turbine pressure points like the nedle to fill a basket ball and where the shaft comes out put a plastis tube and a vacume pump on the other end an ou generator ;)
less mess than water and will spinn just as fast make the turbine as light in weight as posible
is
i worked on this a bit last night this is a basic dwg of it
the rotor will be similar to the tesla turbine in the way the force travels through the turbine and exits through the center causing spinn
im still designing it but will post when i finish it it will be made of fairly thin plexi glass in layers like other turbines i have built except this will exit the center of the turbine :D
william
