Overunity.com Archives
Discussion board help and admin topics => Half Baked Ideas => Topic started by: Grim on October 29, 2007, 03:16:01 AM
Title: This little piggy is going to market...
Post by: Grim on October 29, 2007, 03:16:01 AM
Post by: Grim on October 29, 2007, 04:45:06 AM
Post by: Grim on November 01, 2007, 05:51:08 AM
Title: Re: Magnet motor, gauss gun inspiration...
Post by: Pirate88179 on November 01, 2007, 07:53:00 AM
@ Grim:
One of the things I am working on is using a quasi-SMOT on a low friction wheel (bicycle wheel) where the SMOT occupies a quarter of the revolution from 12:00 to 3:00 in a clockwise rotation.  The idea here is to have a steel ball mounted to an adjustable height rod attached to the circumference of the wheel such that the sphere enters the SMOT and, hopefully, accelerates at least a little and uses gravity and certain angles to drop out of the SMOT sticky spot at the 3:00 position and...maybe...complete the rotation to begin again.  My apparatus is about 60% completed and I hope to begin testing within a week or so.  If this will work, I believe that very fine adjustments will be the answer...if there is an answer.
I am not too familiar with the Gauss gun.  I take it this is a series of magnets that accelerate a ball and shoots it out of the end of the gun barrel?  Why is there no sticky spot at the end of the barrel with this design?  Unless, of course, it is comprised of a series of electromagnets firing in order...then no sticky spot but power required.  I am fascinated by all of this.
Bill
Post by: Grim on November 01, 2007, 09:03:55 AM
Post by: Joh70 on November 01, 2007, 10:08:35 AM
is interesting. why does it work. why is there no sticky point. this gauss gun uses only magnet force and no gravity. is better than a smot, i think. how does it function physically?
my first impression is, the additional steal-ball touching the magnet(s) take a short time to be magnetized and flips over polarity of exactly one ball (the last one) for a short time, which shots it away from the others. if this is true, it show, that metallic-material interferes with magnets and their timing.
Post by: karl on November 01, 2007, 01:52:19 PM
Hi Grim,
you have inspired me.
I`ve seen some videos about area15 this days.
Think about a raund track (tube) with four aircoils at 0/90/180/270? or other configuration.
What happens to a mass e.g. steelball (there should always be a mass to store and share the energy) which is pulsed at the right time and position ?
Maybe one pulse is enough to shoot the ball in the circle motion and you get 3 pulses back from the rest of the coils, rectify and collect and measure coulombs to one condenser.
Thats my project for sure.
The ball acts as e=m*c^2 storage device with a memory effect due to changing speed.
Backwardreaction could be canceled out due to high speeds in the super sonic range. Therefore the backwardreaction could act as inwardreaction followed by the next pulse. Understand?
Basicly the track follows one fieldline of the aircoil and therefore the ball itself acts as a complete core.
An infinitisemal magnetic core which is at the same time carrier for electrons and overlightspeed electrons (magnetic particles, electrons with extremly alterated orbitals in the range of e.g. 30cm=Trackradius).
People of this earth: this is X-mass.
Any further questions?
What ever you want to build (excentric mass, stabilized circular mass, circulating e-filed, circ. m-field....).
Do it this way.
The ball is a big electron, you know the rule: You Need a A-Vecor = E parallel M
The coils surface is in the same direction as the ball is propelled. The ball (or a magnet of any size, TPU)   is the carrier of a mass of electrons. Maybe Lorentz is astonished when the object is rotated which his force acts to.
...my inspiration due to your idea...
Best wishes
kafRLunkel
Post by: karl on November 01, 2007, 03:02:13 PM
...see the animation here:
http://en.wikipedia.org/wiki/Coilgun
...we could design a coilgun with feedback circuit coils or use back emf to feed next coil (differnt coils to match properties of BEMF).
...from this link:
"A large current is pulsed through the coil of wire and a strong magnetic field forms, pulling the projectile to the center of the coil. When the projectile nears this point the electromagnet is switched off and the next electromagnet can be switched on, progressively accelerating the projectile down successive stages. In common coilgun designs the "barrel" of the gun is made up of a track that the projectile rides on, with the driver electromagnetic coils around the track. Power is supplied to the electromagnet from some sort of fast discharge storage device, typically a battery or high-capacity high voltage capacitors designed for fast energy discharge. A rectifier is used to protect polarity sensitive capacitors (such as electrolytics) from damage due to inverse polarity of the current after the discharge. ->Here we could start<-
A superconductor coilgun called a quench gun could be created by successively quenching a line of adjacent coaxial superconducting electromagnetic coils forming a gun barrel, generating a wave of magnetic field gradient traveling at any desired speed. A traveling superconducting coil might be made to ride this wave like a surfboard. The device would be a mass driver or linear synchronous motor with the propulsion energy stored directly in the drive coils.[citation needed]"
Looking forward
Karl
Post by: Grim on November 01, 2007, 08:16:06 PM
Post by: Grim on November 02, 2007, 11:16:48 PM
Post by: Grim on November 03, 2007, 12:34:11 AM
Post by: Grim on November 03, 2007, 10:39:08 PM
Post by: Grim on November 04, 2007, 01:11:27 AM
Post by: Grim on November 04, 2007, 03:44:54 AM
Post by: Grim on November 04, 2007, 04:44:32 AM
Post by: Grim on November 04, 2007, 11:22:12 PM
Post by: Pirate88179 on November 05, 2007, 12:11:17 AM
Grim:
You can get pretty nice neos from Hobby Lobby, if you have one near you, if not, you can order on line.  I purchased a bunch of 1/2" dia neos for $2.99/pack of ten.  Very strong little buggers.
What I am using to adjust angle and distance is just two threaded rods/screws and therefore you can make some very fine adjustments which I believe is very important.  I am not sure if anyone has done this before.  I think they just stick the magnets up there, eyeball it and say, damn, that didn't work.  When possibly, with a few thousands of an inch adjustment, maybe it would have.  Who knows?
Good luck,
Bill
Post by: Grim on November 05, 2007, 01:28:31 AM
Post by: Grim on November 05, 2007, 01:31:28 AM
Post by: Grim on November 05, 2007, 02:12:17 AM
Title: Re: This little piggy is going to market...
Post by: Grim on November 05, 2007, 04:51:12 AM
Sorry guys, but I have a bit of work to do now, so I thank you all for watching.
Good luck.
Sincerely, Grim.
Post by: FreeEnergy on November 05, 2007, 04:55:06 AM
are you going to hide it from us now?
Post by: Grim on November 05, 2007, 06:56:17 AM
I have a five year old kid, and if I play my cards right, he can get a university education.
You wouldn't begrudge me that, would you?
Post by: bluedemon on November 05, 2007, 09:30:52 AM
Whats more important, the future of one kid or all future generations of kids?
Post by: Koen1 on November 05, 2007, 09:59:20 AM
right, Grim shows he does want to make use of the advantages of the idea of sharing information on a forum,
but now that he has all the info he needs, he simply erases all he posted before
so that he can cash in on the idea that was developed with at least some assistance of others, giving their info freely...
Great Grim, how righteous and all...  >:(
Post by: AB Hammer on November 05, 2007, 01:48:43 PM
Hay Guys! let it go, if he thinks he has enough thats fine. I just won't tell him the problem with it. LOL
Post by: Pirate88179 on November 05, 2007, 03:11:02 PM
Also, forget the patent as the idea WAS published here...removing it after the fact does not "undo" the publication. (Kind of like trying to unring a bell)  So, anything based upon published designs and ideas would not be patentable, and, even if one did get a patent, it would be easily rendered null and void.  I am not a lawyer but I believe all of what I stated is true and correct.
Bill
Post by: FreeEnergy on November 05, 2007, 04:22:13 PM
wow how sad. i am pretty much done with you. you remind me of bill gates.
Post by: buzneg on November 05, 2007, 04:37:54 PM
did someone get a copyies? just repost or redescribe it.
Post by: Grim on November 05, 2007, 05:29:58 PM
I saved a copy of the thread.
I am aware of the consequences of breaking your trust. No-one will offer me help now, as my intentions are now known to be  'selfish'.
Replies were pretty thin to this thread compared with the flap-wheel topic, hehe. I got the feeling that either a my thought processes here were so retarded that my posts didn't merit a reply, or b I was helping others through the same problems that I was working through.
There is money in a device that can produce energy. Not every one who reads this thread is as altruistic as we would like.
I am not taking someone else's idea to market, I thought of it. Maybe it is already patented, I don't know. I will find out, muuuuch later.
But I am making an effort not to be the inventor that was ripped off, or beaten to the punch 'by the famous one'.
The only thing that I have stolen from readers readers of this thread is opportunity, and knowledge.
Opportunity taken away can never be restored.
Knowledge however is timeless. It can't be taken away (easily, hehe). But it can be restored to full effect.
...and on a final note, AB Hammer is right, there is a flaw in the device that returns it to a zero sum.
Me finished making bed, now me lie in it.
Post by: Cap-Z-ro on November 05, 2007, 06:45:18 PM
If any of my obscure thoughts, ideas, or inclinations were ever to purcelate down into a concept resulting in grid freedom, I would become famous shortly after releasing it here on this forum.
Clealry freely sharing such a gift would mean never again picking up a check - whereas selling the gift would mean always being charged double.
The term rich can mean many things.
*inserts word 'it'
Post by: Grim on November 05, 2007, 07:06:39 PM
Hehe, I am not in the socio-economic group where checks are offered.
I still file bills in order of who I have to pay first.
But I understand the implication Cap-Z-Pro. ;)
Post by: Mr.Entropy on November 05, 2007, 10:32:10 PM
OMG Grim,
You actually erased all your messages, as if they held the clues to some sort of secret treasure that you've decided to take for yourself!
This is the soul of irony!
I hope you have the stones to come back here, confess your failure, and take your ribbing when its is all over.  :-)
Cheers,
Mr. Entroy
Post by: Localjoe on November 05, 2007, 10:39:43 PM
... Severs keep backups for days stupid....Think your smart now?
Post by: Grim on November 05, 2007, 11:38:33 PM
I am still here dudes, and I am still quite interested in your replies.
Yes, I am back at square one, but I feel quite confident in my own abilities now.
That is good starting capital.
Post by: konduct on November 06, 2007, 03:39:46 AM
lol...this dude is serious eh?  What an idiot.  There is a very well know inventor (BL'F) that has already covered this ground.  Let this dumb ass go on about his way.  He didn't have anything to begin with.  If he does, he'll have to go through a law firm and my family works for the biggest alternative energy law firm in the world in DC.  Let him try to take a piece of cheese and run. His name will be burned and cursed before the public ever hears it or ever receives any money for it. People...makes you want to agree with the eugenicists sometimes.
Post by: mapsrg on November 11, 2007, 01:57:02 AM
@ grim ....Why remove all your posts...are you trying to hide something? This forum is about sharing views,comments,knowledge,.....good on you for acheiving but where is the record for others to learn from?
Post by: Pirate88179 on November 11, 2007, 02:01:36 AM
Exactly.
Bill
