Overunity.com Archives
Discussion board help and admin topics => Half Baked Ideas => Topic started by: Captcaveman4201 on December 05, 2007, 01:34:18 AM
Title: Pentagon structure uses zero point energy vacuum??
Post by: Captcaveman4201 on December 05, 2007, 01:34:18 AM
They say that if you are 1 step ahead of the crowd you are considered a genius, but if 2 steps ahead you a considered crazy. The Pentagon uses the Zero point energy quantum vacuum. The explosion that we all seen on 9/11/01 was caused by this.  Now some of you might be saying thats impossible !!! its just a building.  But consider this, a magnifying glass doesn't have any moving parts to speak of. But depending on how you position it you can make it focus the energy's of the Universe to cause a reaction to happen at a designated point. example you place the magnifying glass a certain distance above a piece of wood outside. So as when the energy's of the Universe focus at a certain TIME/SPACE .in this case when the Sun focuses on the lens at noon when it is directly overhead. The Pentagon structure/device has 5 sides and 5 rings. And in the middle is a shaft that goes straight down the middle. This is where the zero point quantum vacuum happens, It work by generating a sort of tug of war between positive and negative energy's. Both energy's continue the tug of war on a long enough timeline that the rope finely snaps. The result is an electromagnetic energy field that goes rushing back to the vacuum.  coincidences are one thing but after awhile SO many of them and that is a pattern. SO here is a few of the questions that this explanation answers. 1- how they didn't find major parts of a 747   2- the holes in the side of the structure were not consistant to that of a 747  3- there was only one video camera pointed at that spot, that didn't show a 747 but instead showed a blur  4 - other video tapes were confiscated that had a view of that area   5 - that part of the pentagon was under construction 6- books and wooden furniture near the blast area we not burned at all ( this would be consistant with an energy field for that the heat and explosion would be from friction and not jet fuel)  7- my personal favorate is that the event happend 60 years to the day of the structure's creation. i can go on and on with things that don't add up with the official version of the event. But You might say OK even if that is possible why would they do that to their own building. And then cover it up?  There is a good reason behind that also. And i will go into that at a later time in detail But for now know that. It is SO we have a smooth transition into this next era we are entering, instead of a crash landing SO to speak. SO take a look at my diagram and share your thoughts on mine. ( a description of the diagram is basically showing the spiral of TIME/SPACE with the very biggest thing on the outside of the spiral and the smallest possible thing in inner part of the spiral. The line connecting the two TIMES is the focusing of the energy.
Title: Re: Pentagon structure uses zero point energy vacuum??
Post by: Captcaveman4201 on December 07, 2007, 04:20:40 AM
nobody has any comments about this? does it not answer questions?
Post by: Eden on December 07, 2007, 05:33:50 AM
Quote from: Captcaveman4201 on December 07, 2007, 04:20:40 AM
hi Captcaveman,
the text in the picture you attached is not legible.
could you please post a clearer one?
thanks
Post by: dean_mcgowan on December 07, 2007, 05:58:19 AM
Thankyou capt'n caveman,
You have taken this forum to a whole new level
Cheers,
Dean
Post by: acp on December 07, 2007, 06:09:07 AM
I would recommend laying off the wacky backy for a while.
Post by: Koen1 on December 07, 2007, 09:30:56 AM
Lol.
So in your opinion it makes more sense that the Pentagon blew a "fuse" due to its own multidimensional shape-power energy "tug of war",
than it does to believe that it was a manmade explosion?
The fact that official plans for staging an enemy attack on a US military building, including the option to do it on the Pentagon itself, have been developed in the 70s already and have been open for view to any American visiting the Pentagon for over a decade, and which have also been admitted by several military officials, combined with the fact that the "airplane" "crashed" into the only wing of the Pentagon that had been structurally strengthened to withstand a big explosion, and combined with the curious absence of any camera footage of an airplane actually flying into the building while the area contains thousands of fully functional cameras,
to you is not as convincing as your hypothesis of some mysterious energy explosion caused by "shape power"?
Are you sure you are getting enough oxygen?
Post by: AB Hammer on December 07, 2007, 10:13:00 AM
Sorry ::) but talk like this is what is used to call others looking for free energy, Cranks!
Capt Caveman, you need to come up several centuries, like 20,000
Post by: Captcaveman4201 on December 08, 2007, 06:11:38 AM
ahh i tried to increase the size but it didn't change anything. um basically what you have here is the equation for the universe.and overunity. two sides positive on the left and negative on the right. Take note that the Positive is larger then the negative side.  the curve is how they are both relative to each other from the very big biggest objects down to the very smallest objects down to the quantum level. The curve is also a timeline because time/space is also relative to eachother. The bottom arrow points to the introduction of the structure to time/space( 9/11/41. The top arrow is the tipping point date 9/11/01.the inner part of the spiral is the date 12/21/2012   there is an equation related to this. 5/3= 1.666666666.......    on one side of the equation you have a solid set of numbers. and on the other side of the equation you have infinity.
Post by: rhombus24 on January 06, 2008, 07:50:13 PM
Good theory but science fiction at best.
If it were true no one would have been able to go near the pentagon b/c the feds don't want people knowing of such advanced energy.
The TRUTH is that it was no plane that hit it, it is a very big conspiracy and yes the conspiracy is real.  I won't discuss it hear but in case any of you are ready to wake up go to abovetopsecret.com
