Hi All!
Just found an interesting link http://www.energynews.gr/
It's about the producing of electricity by playing the special recorded saw-type signal from magnetic tape with help of specific magnetic head.
I have looked around for any critical information about this project but without any success? :(
It will be great if someone with good skill in magnetic recording explain his thought about possible side-effect's preventing the overunity.
Thanks!
This is quite a write up. Complete with conspiracy theory. I guess my only problem with it is the fact
that tape just doesn't last very long. I did away with most of my vhs due to tape failures. I would love
to see one of these units tho. I just remember the high speed mag tape systems used on main frame
puters.
To get any kind of heavy signal out of a tape, the flux would have to be thick as it was on the mag
reels. Then there is head wear, tape chatter, wow and flutter.
Exactly why I went to CD/DVD
sugra
Poor you, my VHS tapes from when VCRs came out still work fine. Pity some of them seem to be missing, such as the original Yellow Submarine cartoon, a little different from the current release. Taped off the TV in the early 80s. Pity also that the original VCR I kept safe in my room somehow was thrown out while I was away at college. Oh but there's no conspiracy at all.
If you fellows are interested in all electronics based over unity then you will want to look at my device in the downloadable pdf on my page "Get Your Over Unity Device Here And Now" here at Over Unity
Send a copy to your favorite electronics tech for criticle review or if you have the knowledge and skill then build it and use it. Or check me out today Dec 4 2005 on the front page at www.zpenergy.com you can also download my pdf there. Daniel Jackson @ the gate overunityenergy@netzero.com
Corrected as per your request below; thank you for the notice, look up my name here and its posting and you will find my downloads.
Hi Daniel,
if you post web-adresses, please post complete and correct info.
No way to find this info at all
Kator
Er meint www.zpenergy.com
MfG Lanca IV
p.s.:Nicht mit einem Herrn Dr.Lanka verwandt oder verschwaegert.
de Lanca: sizilianisches Fuerstengeschlecht,Stammhaus:Palazzo in Palermo
Hallo LancaIV,
ah ja, Sie haben den Beitrag zur Vogelgrippe gelesen.
Ich bin sicher, ich h?tte Sie nie in Herrn Dr. Lankas Stammbaum eingereiht.So genau wollte ich es nicht wissen, da ich Privatsph?re ?ber alles achte.
Oder deute ich Ihren post so, da? Sie vielleicht an einem pers?nlichen Kontakt interessiert sind, da Sie ja etwas privat wurden ?
MfG
Kator
Ich sehe an meinem "post" nichts privates.
Es war nur als Hinweis gedacht,um eventuelle Verwechselungen bezueglich
Namensaehnlichkeiten zu vermeiden.
Ihnen bezueglich habe ich eigentlich nur eine Nachfrage:
Sie wiesen -innerhalb ihrer vielen posts-auf eine Kontaktierung mit dem Herren Kunel hin,
lebt er noch ?
Neben dem "Cyclotron" hatte er ja auch noch einen Magnet-Motor entwickelt gehabt,
nach dessen eigener Aussage(Patentbeschreibung) mit einer Input1:Output10 Relation
(evtl.sogar Output 100,muesste nachfassen!):
Haben Sie jemals einen Prototypen in Funktion erlebt ?
Hallo LancaIV,
Nein, leider, einen Prototypen der Art habe ich nich gesehen, Ich wurde nur bei meinen damaligen Recherchen auf Ihn aufmerksam und ahbe ihn angerufen.
Ich glaube nicht da? er noch lebt, denn damals, ich muss noch in meinen Unterlagen nachsehen, wann das war ( ca. 5-8 Jahre) war er gesundheitlich sehr angeschlagen und er sagte selber, da? er nicht mehr lange lebt. Iin dem fast einst?ndigen Telefonat war er eher geheimnistuerisch, sagte, sein Sohn h?tte im alles geraubt und weiterver?ussert etc Er wies auch daraufhin, da? er in den Patentschriften den Knackpunkt der Funktion seiner Ger?te nicht offengelegt habe. Einen Hinweis gabe er bez?glich der MEG-?hnlichen Aufbauten : "man m?sse auch von der anderen Seite kommen", was f?r mich der Hinweis auf einen Gegentakt-Betrieb war, aber ich kam damals einfach auch mit diesem Hinweis nicht weiter, weil ich auch davon absah Ihn zu besuchen, da faschsitische Gruppen vorort Ihn angeblich im Visier hatten. Er erw?hnte noch, da? die Ideen Ihm kamen, als UFO's bei Ihm auftauchten. Solche Geschichten kenne ich genug, siehe Hamel-Konverter, den allerdings halte ich f?r realistisch, aber nur mit Pr?zision-Technologie zu bauen.
Kator
Herzlichen Dank fuer ihre Aufklaerung !
Auf "Ufo/faschistoide Gruppe" will ich lieber mit Kommentaren verzichten.
