Overunity.com Archives
Discussion board help and admin topics => Half Baked Ideas => Topic started by: nush-sing-smp on February 05, 2008, 06:24:33 AM
Title: NEED HELP! HOW TO MODIFY THE DRINKING BIRD SO AS TO GENERATE MORE OUPUT????
Post by: nush-sing-smp on February 05, 2008, 06:24:33 AM
hey all
i recently bought a drinking bird. i think its quite a fascinating toy. sadly, its just a toy. i think it'd be exciting if a device made use of the drinking bird to work. i thought of making such a thing. however, i realised that the output of the system is very little. the drinking bird has very little energy. of this energy, only some of it is wasted and the remaining is used for its motion. this small amount of wasted energy is so little that (according to my research and calculation) is not enough to even light 1 miserable LED!
do u guys have any ideas or suggestions as to how the drinking bird's output can be increased  ??? i considered changing teh size but it would probably need to be as big as the taj mahal just to light up a lamp! your help is greatly needed as this is an important project.
if you guys have ideas on how else to use the drinking bird, please post them here as well. i will be more than happy to discuss them with you.
thanks!
Title: Re: NEED HELP! HOW TO MODIFY THE DRINKING BIRD SO AS TO GENERATE MORE OUPUT????
Post by: hansvonlieven on February 05, 2008, 03:10:56 PM
G'day nush-sing-smp and all,
Designs based on the principle of the drinking bird that are capable of extracting meaningful quantities of power are called Minto wheels.
There is a forum on Yahoo that works on this, http://tech.groups.yahoo.com/group/MintoWheel/ otherwise search the net, you will find any number of designs.
On this page is is Wally Minto's version:
http://www.amasci.com/freenrg/minto.html
Hans von Lieven
Post by: nush-sing-smp on February 07, 2008, 06:46:45 AM
thanks a lot hansvonlieven,
the minto's wheel is a good invention. however, my question is: if the minto's wheel requires some energy to move, by removin this energy for other purposes, the wheel will stop its movement due to lack of energy, will it not? a similar problem arises with the drinking bird.
another question: assuming there is a lot of extra energy that we can use, how do we harness it?
thanks, once again,
cheers
Post by: armagdn03 on February 07, 2008, 11:13:08 AM
Good question..
Post by: AhuraMazda on February 07, 2008, 02:53:09 PM
Try adding some high protein mix in the water. Sugar might also work.
Sorry. I couldn't resist that!
Post by: hansvonlieven on February 07, 2008, 04:22:30 PM
Quote from: nush-sing-smp on February 07, 2008, 06:46:45 AM
thanks, once again,
cheers
I am not sure you understand how this contraption works.
This is a simple heat - gravity motor. It uses heat differential to move a body of liquid into an elevated position after which gravity takes over to restore equilibrium, resulting in movement. The amount of torque generated is proportional to the height and weight of the displaced liquid. This energy is usable, minus friction losses of course. It will always be low power and slow rotation or movement.
Hans von Lieven
Post by: nush-sing-smp on February 08, 2008, 01:58:23 AM
Quote from: hansvonlieven on February 07, 2008, 04:22:30 PM
Hans von Lieven
thanks for explaining about how the the torque affects the amount of energy generated. but by withdrawing energy from the system, there will no longer be a heat differential, am i right? unless, you mean that the energy can be withdrawed so as to result in a heat differential (cool one end by withdrawing energy). then, the pool of water will no longer be needed. or, the thermal properties of either of the containers on each tube can be changed so as to result in a heat differential (eg, painting one silver and the other black).
here is another thought that is a bit off-point, hilarious and maybe unproffessional too.
can a minto's wheel just be made of 2 long, thin hourglasses. give it a slight push initiually and the system will move in a cycle. of course, many factors other need to be considered to build something like this but, since it just just a brief thought, i have not considered them
Post by: mapsrg on February 09, 2008, 01:19:32 AM
The best toy Ive seen is one involving a swinging man and a magnet that does not allow a rest state....he swings all day long so proving perpetual motion is possible with the use of gravity/magnets....
Post by: FreeEnergy on February 10, 2008, 03:56:07 PM
You are probably better off using a Stirling engine.
Google: Stirling engine (http://video.google.com/videosearch?q=stirling+engine&hl=en&sitesearch=)
Post by: MeggerMan on February 10, 2008, 06:17:04 PM
@All
I found this giant drinking bird that looks like a scaled up version:
http://www.youtube.com/watch?v=gZ-zeRCUicw&feature=related
Another one doing some work (end of vid):
http://www.youtube.com/watch?v=mIjXg5fvvas
Its based on evaporation of water from the fuzzy head, so its going to consume the water in the bucket eventually, which is not too much of a problem.
So a good drying day would be best, but I imagine the output power is not going to be that great no matter how big you make it.
Its interesting as to how it works.
Rob
Post by: hansvonlieven on February 11, 2008, 04:34:19 AM
Quote from: mapsrg on February 09, 2008, 01:19:32 AM
Sorry mate, if that was real, Perpetual Motion would have been solved long ago.
There is a battery, an electromagnet and an electronic circuit in the base that makes this sucker swing. SORRY.
Hans von Lieven
Post by: Koen1 on February 11, 2008, 06:08:43 AM
Yeah, Hans is right. It's a very simple circuit, but electromagnetically induced motion nevertheless.
Interesting though, there seem to be many people who believe that type of toy is a perpetuum mobile...
Post by: nush-sing-smp on February 11, 2008, 07:37:15 AM
so lets assume that the drinking bird or the minto's wheel were to produce a large amount of output, how do we harness it?! generators? won't they interfere with the engine's movement? piston? i dunno!!
Post by: AB Hammer on February 11, 2008, 05:53:50 PM
OK I think I have your answer. You need to find Granny Clampet and get some of her recipe drink. That ought to do it.  ;D
Post by: sm0ky2 on February 11, 2008, 08:17:16 PM
i believe a micro-sterling, as mentioned above, would produce more output per delta-T than the drinking-bird
using the same low-temp-boiling-point-fluid
the power will still be fairly small, because of the low difference in temperature, but you should observe an increase in efficiency.
Post by: hansvonlieven on February 12, 2008, 04:43:42 AM
You are right Smoky,
Not only is the Stirling engine the most efficient heat engine ever built it is the most efficient motor ever built.
The problem with the Stirling engine has always been its power output, not its efficiency.
The drinking bird and the Minto wheel will never be more than toys. They are nice to play with but from a practical angle useless devices.
Hans von Lieven
Post by: FreeEnergy on February 12, 2008, 05:05:00 AM
hans do you think a stirling engine alone could power a small home? if it was scaled-up to a bigger size? maybe a solar powered stirling or maybe a magnifying glass can help too or just build a small fire :)
is it worth it?
how can i build this with off the shelf parts? anyone want to help?
Post by: FreeEnergy on February 12, 2008, 05:13:07 AM
cool http://youtube.com/watch?v=BBZDJn6B0cs
Post by: hansvonlieven on February 12, 2008, 01:44:43 PM
Quote from: FreeEnergy on February 12, 2008, 05:05:00 AM
is it worth it?
You certainly could power a small home, or a large one for that matter, with a Stirling motor and an alternator. At one time Stirling motors were mass produced and used on farms and in remote locations. They could not compete with internal combustion engines because of their size to performance ratio. Today they are used virtually only by the military and are powering submarines as well as generators. The military likes them because they run very quietly and with virtually no vibration.
There is one company that is producing a Stirling motor type generator http://www.whispergen.com/main/technology/  I don't know too much about them or what they charge for such a device.
As to building one yourself, you really would need a reasonably well equipped machine shop, off the shelf parts are really not suitable.
Hans von Lieven
Post by: FreeEnergy on February 13, 2008, 03:05:20 AM
QuoteAs to building one yourself, you really would need a reasonably well equipped machine shop, off the shelf parts are really not suitable.
what if i buy off the shelf parts and take my parts to a machine shop so they can do minor cutting and welding for me? shouldn't be too expensive, i just have to find the right parts, shouldn't be so difficult.
Post by: sm0ky2 on February 13, 2008, 04:07:29 AM
well, essentially you can make a low-temp engine with a sealed alimunum can on a shaft. your gas is in the can, and as you heat it from the bottom it rises up the shaft, cools down and the can comes back down,
just attach a crank assembly to the top of the can and there ya go.
they made these things in the 1800's
Post by: barematt on February 27, 2008, 11:03:40 PM
The drinking bird uses ambient temperature as the heat source and the wet bulb temperature as the heat sink.  Draw a rankine cycle using these temperatures and you will have yourself a low temperature gradient heat engine.  Very little power with cold exhaust air as a by product.  Worst case is you will have an evaporative cooler that powers it's self.  Familiar with OTEC, Think of it as a desert version.  Hot desert air heating ammonia and pre-cooled evaporative air as the heat sink.  Heat exchanger design will be an important factor.  Good luck.
Post by: one on February 28, 2008, 03:48:31 AM
Quote from: FreeEnergy on February 13, 2008, 03:05:20 AM
FreeEnergy
By off the  shelf parts I assume that you  are  thinking of mostly  internal combustion  engine  parts .
A  normal internal  combustion  engine  can't  be  easily  converted  into a sterling engine  because  a sterling  requires  one  set of cylinders  to follow another by 90 degrees .
If you apply heat  to one set of cylinders   it  runs  one way ........if you  apply heat to the other it  runs the other way .
The  most  practical way I can think of   to make a  sterling engine  with internal combustion engine parts   would be to use  2 engines ...... link  the  crankshafts  together  90 degrees apart .     You would heat one of the engines  and cool the other
The   heads  from both motors could be thrown out
The  heads would be replaced with  manifolds
Each  manifold  would  go to  the  corasponding    cylinder(s)  on the other  engine .
Keep in mind that  the  sterling  engine runs on the relative  pressure  difference   in the different  parts of the cycle .
If you want   the  engine to have high efficency   you would need the manifold  to  have  a  high thermal  storage  ability .
The heat is  actually  shuttled back and forth  between the  hot cylinder  and the  heat  storage in the manifold.
The most practical way  that I can think of  to build  a manifold  like this  would be to  design a manifold   filled  with aluminum  or copper tubes.The inside of it would  look similar to the inside of  a catalitic  converter
Heat  exchangers could be built into both ends of  the  manifold
The  factor that   limits   the  power output of a sterling engine most is  the  ability to transfer  heat  in to it and out of it .
gary
Post by: sm0ky2 on February 29, 2008, 12:47:01 AM
low-temp boilingpoint fliud, in a can on a verticle shaft.
small heat source underneath.
fluid in can turns to steam, and lifts, raising a set of magnets to create one of THESE::
http://pesn.com/2008/02/19/9500471_Gravity_Lamp/ (http://pesn.com/2008/02/19/9500471_Gravity_Lamp/)
which then creates power on its way down, the fluid cools back into a liquid, falls down to the heat source and the cycle repeats.
Post by: Gearhead on February 29, 2008, 01:13:54 AM
Quote from: sm0ky2 on February 29, 2008, 12:47:01 AM
When a liquid turns to steam it does not lose mass.  The drinking bird works because the mass shifts beyond the balance point.  If I understand you correctly the can is sealed so the mass cannot shift.
The drinking bird can be made more efficient if the liquid can be shifted without turning it to steam as this will avoid the loss of the latent heat of vaporization.
Post by: sm0ky2 on February 29, 2008, 01:28:03 AM
 at below-steam temperatures.
there is a liquid more dense than the surrounding air, and the can falls.
when this liquid heats it turns to steam and rises to the top of the can yes.
the heat causes the can to rise.
there are working motors that operate like this, using 50-gallon metal drums
and a small camp fire. the drums rise 20 feet into the air.
