Overunity.com Archives
Solid States Devices => solid state devices => Topic started by: then00b on February 06, 2008, 05:56:27 PM
Title: Does the tesla turbine run on gas?
Post by: then00b on February 06, 2008, 05:56:27 PM
Does the turbine run on fuel? If so what kind? How much does it consume?
Title: Re: Does the tesla turbine run on gas?
Post by: Gearhead on February 06, 2008, 11:59:39 PM
The Tesla turbine was originally a steam powered turbine.  There have been attempts to run it with a compressor added in front.  It is apparently not efficient enough to run as a gas turbine.  Basically the turbine consists of a bunch of disks with a small gap in between.  The flow of steam or air or water drags the disks along to cause rotation.
Post by: then00b on February 07, 2008, 12:26:55 AM
I have read that they have been proven to work. I have seen 110HP modles. So If I built one the only fuel I would need to buy is water?
Post by: Gearhead on February 07, 2008, 11:10:39 AM
Tesla was such a gifted inventor that people assume and make all kinds of claims for his mysterious turbine.  There are also scams out there for working magnet motors of fabulous output that you can buy for the right price and some bridges also.  The Tesla turbine has found some success as a pump to pump abrasive slurry.  Other than that I know of no other successful use
If you chose to build one you will need a steam boiler along with that water.
Post by: then00b on February 08, 2008, 11:47:17 PM
The club that makes them does not give any power specs. They just say they have custome builds for the members if they want to buy one. The 110hp I got was from an original add by Tesla himself.
Post by: allcanadian on February 17, 2008, 09:37:36 AM
I believe Tesla's turbine was intended to operate like a gas turbine, He patented a mechanism refered to as a "valveular conduit" which has no moving parts but acts like a check valve ---- having one way flow. This valveular conduit would be combined with a gas burner on the input to his turbine producing a high output engine with one moving part.Tesla mentions water injection to cool the hot gases to prevent warping of the turbine disks. The machine itself would then act very similar to a valveless pulsejet engine only very much more efficient and having none of the issues of blade erosion found in present gas turbines. What everyone has completely overlooked is one simple fact--- the input was pulsed--- :D a slug of gas and air would ignite pressurizing the turbine input instantly which would destroy "normal" turbine blading but not teslas turbine, a pulse of water would then be injected at the input condensing the remaining gases rapidly and sucking in a new charge of gas and air through the valveular conduit. There is no turbine other than Teslas bladeless turbine which could handle these extremes of changing accelerations, none!
Post by: Gearhead on February 17, 2008, 04:27:08 PM
The web is full of turbine enthusiasts that have built bladed jet turbines that run.  There is not a single Tesla gas turbine on the web that is able to drive its own compressor stage to run.  Blades work on the same principle as wings.  Airplanes could not fly if lift from the wings was not an order of magnitude better than the drag. As simple as Tesla's turbine is it has been relegated to special purposes only.
http://www.youtube.com/watch?v=9PdzaYwgQBE&feature=related
Post by: zerotensor on March 09, 2008, 04:42:58 PM
I know that these have been used "in reverse", driving the turbine with a motor or other mechanical input so that the machine acts as a pump.  One application is a high-powered "water cannon" used for excavation.
