We are told that energy comes in many forms but actually energy only comes in one and the things we are told that in comes in forms of are actually products of what energy makes.
I have found that energy is nothing more then vibrations. We have positive and negative energy?s when vibrations are flown in opposite ways. The stronger being the positive and the weaker being the negative. When they are the same strength, they are thought to cancel each other out. I cant say they do or they don?t and I would have to see a experiment to see if that is true. When they are flown with out a resistance, they are a positive but when a resistance is present or applied, the resistance is the negative.
Now we have to assume that these vibrations fly within different frequency?s and that is why we have so many different frequency's. You must also note that is also why some frequency levels are illegal to use and why some are regulated with our governments.
The think that upsets me the most is that I can not be the only one that knows this and those that do, must be hiding it from the rest of us.
WHY??? I think it's because they cant make money from what is readily available. Every living thing puts out a vibration, that its ora. Every substance has a vibration limit. Those vibrations vary by frequency?s.
Why do we continue to brain wash our children with using statements that electrons flow through things and that electrons are a part of a atom? If we were to call vibrations, electrons, then it wouldn't be so bad but to keep them separate from what they both are, is wrong and misleading. I was lead to believe a electron was a solid object but yet it will flow through other solid objects. That is impossible. Then I am told it is because everything is not solid but yet poorest, that?s fine if true but it still does not justify these electrons flowing through objects. They would have to weave duck and jump through the poorest paths of objects and that would create restrictions causing hot and cold points in the wires. So that can not be true. The only other thing would be vibrations. Vibrations can be felt more miles through anything depending on the magnitude of the vibration. Earthquakes are a good example on this. Sound is another example of this.
Now that we know what energy really is, we need to start finding ways to harness and store the natural energy that surrounds us as well as ways to convert energy in to forms that we use.
These very ideas of waves of free energy surrounding us,always, untapped(as far as we know) has had me really thinking the past few years. Google earth energy grid. From what i have been reading(may be BS but you never know) that the ancient humans used the power grid for anything from transportation to communication. And something about the temples being an "antenna" to gain access to the power. i mean do you really think they lifted those very heavy bricks with wood and rope? Or slid them across the desert floor? What i think is a very cool material is pyrolytic graphite effects of a magnetic field.
pyrolytic graphite
interesting.
that would be OU? :D
http://sci-toys.com/scitoys/scitoys/magnets/pyrolytic_graphite_2/spin.gif
http://sci-toys.com/scitoys/scitoys/magnets/pyrolytic_graphite.html
saludos! =)
yep that would be the one! that is sooo cool! imagine the stuff you could do on a larger scale.
