I am releasing information about gravity. It is all a lie. Gravity is nothing more the magnetic force. Magnetic force is nothing more than electric particles. A vast amount of particles are circulating around Earth. South polarity particles leave the North Hemisphere, and North polarity particles leave the South Hemisphere. Both particles bend around the entire Earth and are attracted to their opposite. This means in the North Hemisphere, North particles are raining down from the sky to Earth. In the South Hemisphere, South polarity magnets are raining down from the sky to Earth.
You can test this with a simple experiment. Read the following web page:
http://www.lawofmagnetism.com/sog.html
@One,
Nice web page, but I think you are missinterprepting experiment results. At most places, the Earth's magnetic field is not parallel to the ground. In fact it usually deviates a lot from being parallel. When you magnetize the wire it will point along the Earth's magnetic field (which is usually at an angle to the ground) and thus the wire will no longer be level. Also, once the wire is magnetized it will be effected by metal objects near it. To check to see if effect is due to gravity or angle of magnetic field, you will need to use moving coils and measure currents produced by moving in different directions (this is not easy to do). If the field direction indicated by moving coils is same as angle of wire, then the angle is due to magnetic field rather than gravity.
EDIT: I just realized that there is an easier way to show if it is magnetic field or gravity. Just turn the wire around 180 degrees. If it is gravity, then wire will stay in new position and the North end of wire will still be higher or lower as before turning. If it is magnetic field then wire will spin back to same position it was in before turning. You need to be very careful that wire is hanging from exact center so that one side is not longer than other side. Another way to tell would be to increase the strength of wire magnet. If it is due to gravity the angle should increase. If it is due to magnetic field the angle will remain the same.
hello, i have a question relating the antigravity experiment,
they say the magnantized metal levitates on one side, ok:
- if i attach a magnet to a metal the metal is magnatized in the way the magnet's magnetic field is, right?
if i just swicht the magnet's poles, the metal would be RE-magnatized?
the magnatized metal would swicht poles too?
following that question:
let's supose i slide the metal from the gravity's webpage experiment througt several magnets forming a vertical line...
NS
SN ^
NS [METAL]
SN ^
the metal should act as a pendulum?
saludos! :)
Stan Deyo maintains anti-gravity was cracked over thirty years ago - interesting video lecture (8 parts)
http://www.youtube.com/watch?v=D8BCKcocgWE (http://www.youtube.com/watch?v=D8BCKcocgWE)
I revealed a LOT here:
http://www.abovetopsecret.com/forum/thread358046/pg1
earth electro magnetic field and gravity not the same. you ever try to electrise rubber baloon ? baloon don`t have magnetic field but electric charge affect like gravity . rotation of earth electrize earth matter with electric chardge and produce gravity effect
to make anti gravity effect you need to produce electrostatic vacum above object. you need to make electromagnetic vortex
Quote from: martinzurix on May 29, 2008, 08:08:04 AM
A balloon is made of electrons and protons which are electromagnetic and are effected by magnetic interactions.
b.t.w my theory is that Earth has a magnetic field because it's material compisition is made of electromagnetic particles. The mass of Earth is also a collection of mangets that attract. Not just the magnetic field.
Much like how a permanent magnet has a field that attracts, yet it has mass too, so if the magnetic force was gone in a vacuum the metal of the magnet would still attract. Because the atoms are magnetic too... sub-atomic attraction.
neodium magnets have external magnetic field but rubber don`t .
magnetic and electrostatic fields is in some ways similar but in some ways different.
electrostatic field affect all kind of mater, but magnetic only metals and other electro conductors
magnetic field is flow of particles and make pressure , but electrostatic field is something like vaccum and every particles is sucked in
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2Fgabals01.times.lv%2Felectric.jpg&hash=2fd38ed2d3c7bf7087eead1ab82f14d88417dd69)
Quote from: martinzurix on May 29, 2008, 08:45:46 AM
neodium magnets have atomicly aligned dipoles that are aligned in such a way to circulate extra magnetic force between the atomic particles magnetic bonds.
Rubber's atomic dipoles are really strong, so they don't align themselves with magnetic fields easly, or hold magnetic fields easy, and the magnetic domains of rubber are usualy unorganized?. But you can still use a magnet, or other material, and rub it against the rubber to magneticaly charge the sub-atomic particles inside the atoms themselves, which have their own little scale of magnetic attraction that I call mass attraction. This attraction at an unorganize fasion is why rubber would seem to have gravity effects.
if you see tornado then there are electrostatic effects too ... because rotating mass of water and air elecrilizes and produces antigravitational efeects that lead to easy lifting hauses cars ewerything ... this not only bay strong airflow (airflow and wind is electric based fenomena !!!)
electrisity have two different forms magnetism and elekrostatism
magnetism= pressure=explosion=outwards direction=dischardge (most known fenomena)
elekrostatism=vacum=implosion= inward direction =rechardge (very little studied )
There is not difference between magnetism and static electricity. They are the same force, at different scales. One is atomic scale, the other is sub-atomic scale. Still the same force...
as above, so below.
Interesting theory. Any idea why the planet Mars would have gravity appropriate for its mass and spin, yet have a magnetic field that's almost nonexistent?
By the way, water is Diamagnetic. It is repulsed by both + and - magnetic fields. Why doesn't it fly off of the face of the earth?
To One:
From House painter:
If gravity doesn't work, please define your definition. Can't have anti-gravity without gravity. Definition of terms, backed up by science, particularly mathematical probabitities, or probable actualities, are the way to present ideas,heretofore unbeknownst possibilities, for scrutiny of peers.
