Overunity.com Archives
New Battery systems => Other new battery systems => Topic started by: mrcharisma on October 16, 2008, 10:15:02 PM
Title: Vacuum Energy Battery
Post by: mrcharisma on October 16, 2008, 10:15:02 PM
Hi Guys and Gals,
Someone in Germany created a permanent battery similar to the "electrinium battery" only made from crystals. Apparently it has been producing significant electrical energy now for 9 years already! Even when the battery was short circuit for 4 years it immediately "self charged" when the poles were opened again.
Visit the web site and discuss...
http:// www.vakuumenergie.de
http://www.vakuumenergie.de/doc/Portfolio.pdf
http://www.vakuumenergie.de/energy/english/crystagg/index.htm
try google  "vakuumenergie" it is no secret!
Only get your skates on if you are to build your own working model because the competition is going to be hot  :-* lol
Matt
Title: Re: Vacuum Energy Battery
Post by: Koen1 on October 17, 2008, 09:05:23 AM
It is called the Crystal Energy Cell (or Unit) and there has been a thread on it
at this very forum for several years already.
The thread is here: http://www.overunity.com/index.php?topic=972.0;topicseen
I happen to personally know the German inventor you talk about,
his name is mr. M. Reid.
And indeed, his website is www.vacuumenergie.de
another inventor that claims to have Crystal Energy Cells is mr John Hutchison.
I have a few Crystal Energy Cells of my own too. Have been doing experiments
for quite some time now.
If you want to know more about them, visit the thread. And please keep in mind
that the very first posts were posted in the exploratory stages of my experiments,
while as time progressed and more experimenters joined in, the thread became
a lot more constructive and more of an information exchange. So you may want
to look at the later posts a bit more than the first posts. ;)
Post by: resonanceman on October 17, 2008, 11:46:55 AM
Quote from: mrcharisma on October 16, 2008, 10:15:02 PM
Hi Guys and Gals,
Matt
from  the   http://www.vakuumenergie.de/energy/english/crystagg/index.htm     link.
Since 1999 the crystal unit was operated almost uninterrupted all the time, so one can estimate the minimal total charge that it delivered over the years based on today's voltage/resistance as follows:
Total charge [Ah] = Amperage x Time
Total charge [Ah] ~= (910 mV / 1088 Ohm) x 9 years x 8766 h/year
(voltage/resistance taken from April 2008)
Total charge [Ah] ~= 66 Ah
can anyone explain  why  they are  measuring  resistance to  calculate power ?
Is  the amperage to small to be measured  directly?
gary
Post by: mrcharisma on October 18, 2008, 03:10:18 AM
Quote from: resonanceman on October 17, 2008, 11:46:55 AM
gary
Thanks Koen1,
Gary, maybe it is easy to measure the resistance as it is more or less constant. Doesn't the current draw depend somewhat on the application being used? I read on the http://www.vakuumenergie.de/energy/english/crystagg/index.htm page that the load was about 1mA.
Matt
Post by: sm0ky2 on October 18, 2008, 10:49:48 AM
they measure resistance out of convenience.
Current varies with time in this device.
resistance is a known value. voltage can be measured at any point. and thus current and power are derrived from these values.
the current value from this method is the 'mean current',  the 'real curent' increases and decreases along a logorithmic scale which is specific to each cell. (it is important to note that this scale is the inverse of the change in voltage over time)
each cell is slightly different, because of inconsistencies in manufactuing
so the scales for 2 similar cells may be slightly different.
Post by: Drannom on October 18, 2008, 08:09:26 PM
from the pdf
QuoteThe power output from certain crystal cells sometimes show at the same time small changes,
which are not related to changes in temperature. It is currently not known why this is so.
indeed it look like electrinium, if differents battery react the same way even if there are at great distance, then it is possible that those small changes are the changes in the superlight pressure, like and event far away in the universe like a supernovae can do this in the etheric field
QuoteThe silicate material was analysed with x-ray diffraction and EDX. The analysis has shown
that the solid material consists of XXXX, and a silicate compound. These compounds, which
are between the minus and plus pole, have a large resistance in the megaohm range.
why XXXX, is it a secret ?  did you get the complete receipe ?
QuoteConnecting crystal cells in parallel does not work too well. Connecting the cells in series,
works better but also not as good as with chemical batteries. It is assumed that the cells have
to be made exactly the same otherwise one cell has a dipole flipping effect onto the other one.
that seem to proove again the superlight theory, there is a break in the etheric pressure in the crystal battery ! so if they are in serie they have to get the same inner pressure
Post by: forsalebabyshoesneverworn on October 18, 2008, 09:54:20 PM
Is this what Ironman uses?
Post by: Koen1 on October 20, 2008, 10:55:32 AM
No it's not what Ironman uses. Ironman, aside from it being a fictional cinematographic novel,
uses what is called an "arc reactor" in the movie. It clearly uses strong arc discharges in some
form of toroidal chamber, and somehow turns out over unity. Seems to me they're suggsting that
it is a plasma fusion reactor that loops the arc discharge to allow collection of the released energy
by inductive coupling via a large coil construction. What exactly is fusing in there remains a mystery.
It could possibly be deuterium fusion, or it could be helium-berylium fusion, or it could be a more
funky yet not generally scientifically accepted process like the Correa Anomalous Glow Discharge
though Argon, or the Vallée Protelf process in Nitrogen gas, or the Richter proton-fusion in other gases,
or some other "cutting edge" process. (mind you, the "cutting edge" is the "border line", if you're too
"cutting edge" you're a "mad scientist". It's a thin line. ;))
@ Drannom: dude, stick to your Electrinium thread.
And really, if you only discover the XXXX now, you really haven't read anything about crystal cells before, have you?
Never mind.
Please, stick with your alum pyramids, don't confuse the crystal cell field any more tha you already have, ok?
If you must post stuff about Electrinium, go to the special thread for it, please.
Post by: Drannom on October 23, 2008, 10:12:07 AM
Hey koen1
i have read the crystal Hutchison topic, it's there that i have discovered the electrinium, and you...
i saw the Reid battery there too, and i have refer it from the electrinium to the Hutchison
i had not at this time the skill english level to read all, now i am able too
in my above post, i ask a question, and congratulation you have not answer it, i will have to read more
today my skill level in english is just enough to perform normally
btw in the Dajjal videos they talked about Koening, i suspect that to be the source of your name
in the electrinium i have make a quotation of your non understanding, and you fail to answer me as well
Drannom is an anagram of Normand
Post by: mrcharisma on October 27, 2010, 03:17:42 AM
So you don't think these crystal cells and electrinium are related at all then? Even though they work on exactly the same principles with the exception of the atoms alignment?
Matt
