Overunity.com Archives
Discussion board help and admin topics => Half Baked Ideas => Topic started by: Magnethos on October 18, 2008, 05:42:35 PM
Title: Energy fusion circuit?
Post by: Magnethos on October 18, 2008, 05:42:35 PM
A guy posted here a link about batteries and the results if we connect them in series, parallel, etc...
Serial Connection RESULT: The voltage is the sum of all batteries, the amperage is the lowest one.
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2Fimg185.imageshack.us%2Fimg185%2F6420%2Fpartone24aub3.jpg&hash=6a4956ac653ebe2cd436428655e1516bde8d9e52)
Parallel RESULT: The amperage is the sum of all batteries, the voltage is the lowest one.
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2Fimg505.imageshack.us%2Fimg505%2F9618%2Fpartone24crs1.jpg&hash=7063ca476f2182ec694a6e168a40dadad1104d8d)
4S2P Configuration Parallel/Serial     RESULT: 50% all Voltage @ 50% all Amperage
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2Fimg185.imageshack.us%2Fimg185%2F9325%2Fpartone24eph9.jpg&hash=b20b8619d56adcd309568c6ad0ec9c11a34da9c6)
My question is....
Think we have 2 batteries with a good amount of voltage and 2 batteries with a good amount of amperes.
Could we merge all the energy?
Title: Re: Energy fusion circuit?
Post by: BEP on October 18, 2008, 09:18:31 PM
Correct?
Sorry, but no.
Batteries are not only supply but also load. In the last circuit you displayed the low voltage batteries will act as a load to the higher voltage batteries. With nothing between the different types of batteries the low voltage batteries act almost as a short circuit.
The voltages will tend to level out. I suggest you do not connect them as shown.
Post by: Magnethos on October 19, 2008, 11:01:36 AM
Quote from: BEP on October 18, 2008, 09:18:31 PM
Correct?
Sorry, but no.
How would you connect the batteries to fusion the energy?
Post by: pese on October 19, 2008, 11:22:36 AM
If you open this circuit to use that as outlet ..
than you have:
480,2 volts @ 0,1ma/H
with rest rest of 0,2V 9.9999  A/h you can do
nothing , it you do not  use one this two 0,1 volt supplies
in serie for himself  (without the unloades 240volt suplies)
G.P.
If  the circuit is closed ring circuit , than this is an "short" circuit.
