Hi All,
here is a PDF File which shows how to build a woodgas system.
Pretty interesting.
Maybe this could be scaled down to run a 2 KWatts emergency power
generator ?
Regards. Stefan.
P.S: Thanks to Walter for finding this file,
Sounds almost exactly like the production of water gas. Run steam across hot coals and you get water gas (mostly hydrogen) with the byproduct of carbon monoxide.
I posted details about this primitive process (and others) on the Gathering of Scientists (http://science.mojforum.si/science-post-57.html#57) forum.
I think , some smaller items , will be also intersting.
see picture.
can onyone find more over this??
http://pixerve.de/39695/pese.html
The wood gas process uses limited amounts of combustion air in a sealed chamber so the wood only partially combusts. The wood gives off gas but does not have the adequate amounts of air to fully burn. The syn-gas is then piped into a diesel engine where the un-burned gas is used in the combustion process.
There are some issues with getting the off gasses clean enough because of fly ash in the gas.
I thought some on here like to see this.I have been working HHO and the plasma arc,But my brother has started playing with the ideal of compressing woodgas in a tank to run whatever with from a car to a generator. He plans on building a big enough wood gas processor to compress large volumes of gas if his testing plays out.Below is a short video of the burning gas after he compress a small tank to forty pounds.
http://www.youtube.com/watch?v=R2N0a6Swi00
Here is some more information on wood gasification-
http://www.fischer-tropsch.org/DOE/DOE_reports/2567/2567,%20986-10/2567,%20986-10.pdf
Fuzzy
Quote from: Slipmatwax on May 23, 2007, 05:11:06 PM
Not correct Slipmatwax, woodgas cannot be used in a Diesel engine, it needs spark ignition.
There were hundreds of thousands of vehicles fitted with woodgas generators during and just after the war because petrol was scarce. Here is a picture of such a generator fitted to an Opel sedan (about 1944)
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2Fupload.wikimedia.org%2Fwikipedia%2Fcommons%2Fthumb%2F9%2F9f%2FHolzvergaser.JPG%2F450px-Holzvergaser.JPG&hash=06669f1fe5da3e4e5c2168cf15876ed5f21a34e7)
Here is another one:
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2Fwww.bio-wasserstoff.de%2Fh2%2FKleinvergaser%2FKaefer_mit_Holzgas.jpg&hash=0b784c45d6cbbda5faedd8ad5dfa8ab7539aeac5)
Hans von Lieven
Hi All,
Here is a AKA "Lego Gasifier" a biomass Gasifier Experimenters Kit with excellent gallery photographs of the construction -
http://www.allpowerlabs.org/gasification/gek/index.html
Fuzzy
Hi All,
Here are some YouTube videos on vehicle "gasifier units" -
http://www.youtube.com/watch?v=kG8iR5DRLpw
http://www.youtube.com/watch?v=AksUuOckWpI&NR=1
http://www.youtube.com/watch?v=xF_zFimqTXw&NR=1
http://www.youtube.com/watch?v=6nQW0a081-k&NR=1
http://www.youtube.com/watch?v=14xrKKuQ8-Q&NR=1
http://youtube.com/watch?v=6wvIzzHSJuM&feature=related
And a simular but more expanded PDF posted by Stefan (post #1) -
From the "USA" Federal Emergency Management Agency (FEMA) construction of a simplified wood gas generator for fueling internal combustion engines in a petroleum emergency adopted in July 1989 -
http://www.global-greenhouse-warming.com/support-files/wood_gas_generator.pdf (http://www.global-greenhouse-warming.com/support-files/wood_gas_generator.pdf) ( 90 pages - 9.8 MB )
Some WWII gasified autos thumnails -
Fuzzy
It will be really helpful if you get success in this experiment we will able to run tractors for cultivation with this woodgas. That really good idea to run tractors with woodgas.
