Overunity.com Archives
Discussion board help and admin topics => Half Baked Ideas => Topic started by: krypt013 on November 17, 2008, 10:55:04 PM
Title: ORMES the secret WATER FUEL CELL ingredient
Post by: krypt013 on November 17, 2008, 10:55:04 PM
ORMES the Secret WATER FUEL CELL ingredient:
By: Jeremy William VanHaitsma
Dear Researchers,
   I believe that I could have some valuable information related to your current research into successfully replicating the late Stanley Meyer's Water Fuel Cell technology.  I have been researching many over unity systems and devices over the past several years and have taken particular interest in the Water Fuel Cell technology...  I have researched into the replications of the WFC as done by Dave Lawton in D14.PDF and the work of Ravi Raju.  Also, I have been following the work of various organizations devoted to the freeing/dissemination of these types of technologies such as PANACEA-BOCAF and the ORION PROJECT.  I feel that Dave Lawton was able to get alot of valuable ground work done for the WFC replication process and that Ravi Raju was able to make some major contributions to the work of Mr. Lawton with his modified voltage intensifier circuitry, longer and more numerous tubes, and his signature 'conditioning' process for the tubes which has shown to be invaluable in increasing the efficiency of the WFC in both lowering current draw and increasing it's hydroxy gas output.  I recently read some documents that stated that during the 80's of Stan Meyer's heyday that he had met with a couple of other inventors that were also researching into technologies related to free energy whom may have offered some ideas and inspiration to Mr. Meyers which may have had some influence upon his devices and processes.  One being John Bedini who as you may be familiar with had developed motors/generators capable of tapping into and harnessing so called radiant energy.  The other inventor being David Hudson.  David Hudson is an Arizona farmer who discovered a new form of matter that he named ORMES (Orbitally Rearranged Monoatomic Elements) namely from the platinum group metals that occur in nature in monatomic and diatomic micro clusters.  The ORMES material has been found through the research of him and others to be present in certain soils, sea salt, water and other sources in nature.  I don't want to go into the whole story about how he discovered it but if you Google ORMES, ORMUS, MONATOMIC GOLD, DAVID HUDSON, or visit www.subtlenergies.com you will get the basic jest of it.  Anyway, this ORMES material appears as a white powder in a dry purified state and it's superconductive.  It's surrounded by a meisner field like other superconductors; it has anti-gravity properties to it.  It can be turned into a glass if it’s heated to a rather his temperature.  It has the tendency to phase in and out of our dimension, now please bear with me here.  It has been called strange matter, white powder gold, the Philosopher’s Stone, MFKZT by the Egyptians, manna in the bible, etc....  Glacial water deposits tend to have rather high concentrations of it although it can also be found in ordinary tap water.  Which brings me to this material David Hudson discovered and it's implications with the Water Fuel Cell...  This material has been shown to have other strange properties as observed by David Hudson such as when he left a wet sample of the material out in the sun to dry it disappeared in a brilliant flash of white light scorching the material it was on, but with no explosion...  It simply turned into pure energy which released as bright light and gamma rays.  The meissner field that constantly surrounds the monatomic atoms of gold, iridium, rhodium, etc. that make up the ORMES is said to emanate from the zero point energy field coming out from within the atoms and that the material is superconductive, but only if you resonate with it with the correct input signal.  In fact, if you put a volt meter up to a sample of ORMES it will measure zero conductivity.  So what I’m thinking is that if this material just so happens to be in tuned with the zero point energy field, and some of the various devices that produce energy like the Bedini motors and the Meyer's WFC are said to derive their function from the zero point energy field that that is an inherent commonality that links these three things together.  They all have the zero point energy fields in common that is.  Now, remember I stated that in my research I read of one of the other researchers stating that the ORMES material was a superconductor but only if you 'resonate' with it?  What do the Bedini motor and the WFC have in common?  If you look at the signals of each device on side by side oscilloscopes you will notice that the stepped pulse train waveforms are very similar in nature, and this stepped pulse train is a unique type of signal that has the ability to coax the energy to bubble up and out of the zero point energy field and into the device to be received as output, whether that be strait electricity as in the Bedini motor or through the production of Brown's gas as with the Meyer's cell, and it's replications.  Now, after doing some more intense research regarding all the strange properties of this ORMES/White powder gold material, and all the weird stuff it does.  Like phasing in and out of this plane of existence, floating, displaying anti-gravity properties, disappearing into a bright flash of light after being left in the sun, making plants grow super fast, taller, with higher nutritional yields, curing cancer, LOL, etc. etc. etc. it’s almost like this ORMES material was the zero point energy in the flesh so to speak...  A small subculture of open source researchers has sprung up around the ORMES technology on the internet and people have discovered some pretty ingenuitive ways of getting this material...  Some companies synthesize it directly from the metals themselves like ZPtech.net for instance, whom you can purchase vials of the material, others have figured out ways to extract it from salts from the Dead Sea, Great Salt Lake, and Celtic sea salt.  And others have also figured out how to extract it from water using a contraption known in that community as a magnetic vortex water trap.  This device hooks up to your water source and spins the water around in a vortex which is created in a container surrounded by magnets, and since the ormes material is a superconductor and hence paramagnetic it is pushed to the center of the vortex and the normal water to the outside.  Then this 'magnetic vortex trap water' is then collected by a tube coming off the top center of the device and has shown to have a concentration many 1000's the normal concentration of ORMES as per the water sample.  So what does ORMES have to do with the WFC you may ask?  The conditioning process developed by Ravi Raju that takes so darn long to complete, constantly changing the water, eventually resulting in the buildup of this white powdery coating onto the outside of the tubes, which done improperly can flake off, etc. ...Wow, white powdery coating, ormes is a white powdery substance that can form a coating.  Ormes is present in water, but does not show up on any normal types of chemical analysis.  In fact it took David Hudson years to finally try out this Russian method of chemical analysis of burning the material in an electric arc inside of an argon gas atmosphere for an extended time before he was able to discover the presence of these platinum group metals.  So, despite the fact that other types of materials might have shown up and been thought responsible in the white coating that forms while conditioning the cells, such as calcium oxide, etc, unless the WFC researcher were to use the very unique analysis techniques used by David Hudson than they wouldn't even be aware of the presence of this ORMES material in the sample.  But let’s just say that ORMES was in this white powdery coating on the surface of the tubes, and that this played a part in the water fracturing process.  Lets assume that perhaps the more refined stepped pulse train signals that oh so resonate with the zero point energy field as made possible through the more refined voltage intensifier circuitry like that done by Ravi Raju and his use of inductor coils was working hand in hand with the ormes concentrated material collected on the tubes from the water as per the conditioning process, and that the signal was making the little itty bitty ORMES micro cluster do a mad dance and strike into the black gold of zero point energy!!!  ORMES could be what's rolling out the red carpet for zero point energy to join the party and the stepped pulse train is the music that it's dancing to.  But unfortunately I’m just a modest guy currently working for a low wage that cannot afford to purchase a pre-built WFC from the sources mentioned on the Panacea-Bocaf website or even build a Dave Lawton or Ravi Raju WFC replication to test this theory, which I strongly believe should be tested because it very well could be the secret ingredient.  But what I would do if I had a WFC laying around like Mr. Lawton or Mr. Raju is I would test the efficiency and outputs of the system before conditioning by adding ORMES to the water.  In magnetic vortex trap water form, in the sea salt extraction form, and also in the synthetic form compliments of ZPtech.net .  Maybe if you put a spoonful of ormes into the water you won't even need to condition the darn thing and you'll get Over unity right off the bat!!!  Just maybe anyway, and with its potential implications I think it's worth a shot...  Here is a link for a YouTube video that shows you how to make ORMES from sea salt in case you’re as broke as I am, no pun intended http://www.youtube.com/watch?v=68jtnuMAa00 Have fun and happy research
Sincerely,
Krypt013@hotmail.com
Title: Re: ORMES the secret WATER FUEL CELL ingredient
Post by: lon92 on November 19, 2008, 11:36:14 AM
Sorry to say this...  :D
Can you make it simpler to understand??  ;D
Thanks!!  :D
Post by: amigo on November 19, 2008, 07:22:09 PM
@krypt013
This is just my opinion, I am not an expert on ORME but as far as I understand it's origin, producing a sample of it requires quite a feat. We are talking about sustaining a burning at 5,000 C for 90 seconds or more. That kind of temperature in controlled environment (sustained not burst) is out of reach for 99.99% of people on this planet, and most likely out of reach for anyone reading this post. :)
So in order for one to even begin contemplating an attempt in testing a cell with ORME, obtaining ORME itself is a real roadblock. Somehow I am very reserved at these quasi methods of creating ORME, as presented in that YT video you linked to...
Post by: TinselKoala on November 19, 2008, 07:50:45 PM
"It has the tendency to phase in and out of our dimension"
That does make it pretty darn hard to work with. I think I could handle the 5000 degrees C part OK, but my dimensional phase-lock perambulator quadrifical brackets are out of frangilation, so I think I'd better just go cry myself to sleep.
Post by: krypt013 on November 23, 2008, 02:37:29 PM
You can extract ORMES material out of certain types of sea salt.  Like Great Salt Lake, Dead Sea, and Celtic.  Here is a link to a YouTube video that explains how to do this extraction http://www.youtube.com/watch?v=68jtnuMAa00   .  Also here is a link that explains how to do the direct synthesis from the metal itself  http://www.youtube.com/watch?v=ifFggud9ppQ&feature=related  .  Or you could just go to http://www.zptech.net  and purchase their Astralight product which is a vial of premanufactured ORMES material.  For those not too familiar with ORMES, how it came to be discovered, and some of its properties here is a link to a lecture given by David Hudson, the discoverer of the material  to get a little background on it so were all on the same page  http://www.eskimo.com/~billb/freenrg/hudson.txt   .
Post by: krypt013 on November 23, 2008, 02:42:58 PM
Another way to get ORMES is to make what is known as a magnetic vortex water trap.  Monatomic and diatomic platinum group metal in the high spin state "ORMES" are temperature independent superconductors and are thereby paramagnetic "repelled by magnetic fields".  The magnetic vortex water trap is able to extract the ORMES from water that contains it "e.g.-glacial aquifer source, etc." by spinning the water in a vortex surrounded by a weak magnetic field.  Normal water spins to the outside of the vortex whereby the higher concentration ORMES laden water is pushed to the center of the vortex to be collected via a tube.  Here is a link for plans on how to make the magnetic vortex water trap  http://www.subtleenergies.com/ormus/research/Vortrap.htm  .  And for those that might rather just buy one here is a link for pre-made versions  http://www.cherokeegold.net  .
Post by: krypt013 on November 23, 2008, 03:01:42 PM
I have read reports of some water fuel cell researchers that have reported
1)That the material composing the white powdery coating of a conditioned water fuel cell exhibited similar properties such a the David Hudson ORMES material.  Such as when the material is subjected to heat it loses some of its mass and volume which returns the temp normalizing.  A definate sign pointing to the presence of ORMES in the material sample.
2)Reports of researchers adding small amounts of sea salt to the water and noticing that the cells gain a white precipitate alot more rapidly, as well as more precipitate forming.
Now remember from the David Hudson lecture that is found at http://www.eskimo.com/~billb/freenrg/hudson.txt  that Mr.Hudson had to use a very unique form of chemical analysis to even identify the presence of the ORMES in the material.  I russian method in fact that had been buried in a trade journal that he decided to give a try after since dumping millions of dollars and years of time into trying to identify this mysterious substance that seemed to thwart all conventional methods of chemical analysis.  So unless the free energy researchers currently working in the field of water fuel cell research had used the same analysis technique as David Hudson then they wouldn't even of seen the presence of ORMES in the sample, and they would still be scratching their head wondering how some inert substance must be affecting the process. Perhaps the white powdery coating having a high dialectric constant does play a part in the reaction, but I feel that exploring the possibility of whether ORMES might play a role would be a worthy set of experiments to conduct.  Unfortunately I cannot personally fund this endeavor at the moment, and do not have a WATER FUEL CELL to conduct experiments with.  But if I had the funding I would try having one water fuel cell running distilled water verified not to contain any ormes what so ever as a control group, and several other wfc's running synthetic ORMES, sea salt extract ORMES, magnetic vortex trap water, etc and I would 'condition' them per Ravi Rajus method, and examine the data to determine if in fact it is having an effect upon the process.
and if it does then that really simplifies things for the water fuel cell community, because sea salt is pretty cheap, and the process not that difficult to extract it http://www.youtube.com/watch?v=68jtnuMAa00    ::)
Post by: krypt013 on November 23, 2008, 03:10:25 PM
 :)Or I suppose another method to verify whether or not ORMES plays a part would be to contact a bunch of water fuel cell reseachers that have 'conditioned' cells and are experiencing good output results and have them send samples of the white powdery coating material.  Then conduct DAVID HUDSON style analysis of the material to determine if it contains ormes and how much it contains.  Compose a graph with the levels of ormes in the material and the performance data of the water fuel cells.  This should show a veritable relationship between the levels of high spin elements to the performance, assuming that all the cells submitting samples are operating on the Stan Meyer's/John Bedine pulse waveform anyway, to keep the data constant.   ;D
Post by: krypt013 on November 24, 2008, 08:09:33 PM
Here is a source where you can buy ORMES extracted from sea salt for about $60/gal.  It would be a suitable form to test the hypothesis.  You could put a couple shots of it in the WFC each time the water is changed during conditioning I suppose???
Post by: krypt013 on November 24, 2008, 08:09:54 PM
http://www.sea-crop.com/
