Overunity.com Archives
Energy from Natural Resources => solar systems homemade and commercial => Topic started by: andrew_snwl on February 06, 2009, 03:58:38 PM
Poll
Question: ratio of displace to power piston??
Option 1: / votes: 0
Option 2: / votes: 0
Title: Stirling Engine Project
Post by: andrew_snwl on February 06, 2009, 03:58:38 PM
hey guys ,
I am a 19 yr old student and for my schol project I am building a stirling engine. I have encountered a difficulty which regards the ratio of the displacing piston to the power pistons??
Any help would be appreciated....
thanks,
Andrew
Title: Re: Stirling Engine Project
Post by: khabe on February 06, 2009, 04:09:05 PM
Go to Google, insert  _ stirling engine _ ... and you´ll have readings for all night + weekend,
cheers,
khabe
Post by: andrew_snwl on February 06, 2009, 04:16:53 PM
already done that..but I couldn't find serious data regards my query..easy said than done mate!!
Post by: nickle989 on February 06, 2009, 04:37:36 PM
The most common ratio is 2 to 1.
Post by: mindsweeper on February 06, 2009, 04:42:36 PM
Mine is about 30 to 1, can post pics if you need.
BTW mine is a LOW temp engine. It runs off the heat from your hand at about 16 RPM.  If you are using high temps then I cannot comment.
Post by: nickle989 on February 06, 2009, 11:03:15 PM
That would make sense for a low temp.  I am working on a total enclosure one ... using an old fire-extinguisher.
Post by: andrew_snwl on February 07, 2009, 10:15:36 AM
I would be using a small satelite dish to reflect off the sun's rays onto the displacer, so a high temperature is involved.. as par the ratio between bore and stroke, what is the most suitable one??
thanks in advance
Andrew
Post by: mindsweeper on February 08, 2009, 03:06:52 PM
OK then that would be a very high temp, I only know of one ever made with a parabolic mirror and you can find it for sale here http://gyroscope.com/d.asp?product=SOLARSTIR (http://gyroscope.com/d.asp?product=SOLARSTIR)
As for the design, it would be nice to get my hands on it.
If you do make a successful project then please post it here.
Post by: andrew_snwl on February 08, 2009, 03:20:32 PM
I have been to that websites, it is a very interersting project. Unfortunately you didn't manage to answer my question regards the ratio between the stroke and bore?? do you have any idea about that please let me know asap thanks
Post by: Moe R on February 08, 2009, 09:11:54 PM
02/07/09 - New Stirling design solves numerous problems
This invention is about stirling engine, which is an internal combustion engined heat machine known as hot air engine and converting the heat to mechanical motion. Invention in question is about stirling engine, having an accordion/bellows element with opening and closing feature, that is placed between the connecting rod and gas transmission pipe and moving in an expansion gap whether folding or stretching to achieve the radial motion without using the cylinder and the piston. The Advantages of Our Invention: - Sealing problem is completely removed. - Energy loss caused by the friction of the cylinder and the piston is removed. - There is no need for oiling. - Costs are minimized. - There is no need for special materials. And this causes the invention to be economical and low-cost. - It is possible to produce based on mass production. - It creates a point that, alternative energy is being reached by the individual user. To achieve the above mentioned objects, it has an accordion/bellows element with opening and closing feature, that is placed between the connecting rod and gas transmission pipe and moving in an expansion gap whether folding or stretching. To achieve the above mentioned objects, the point is obtaining the required linear motion by the hot working gas affecting the folding and/or stretching material. - Source
http://www.akuamarin.com/stirling/
