as crazy as it sounds i envisioned a railway that goes around the earth at the equator fitted with electromagnetic windings/stators and fitted with sails or fins which protrude high enough into the atmosphere to cause it to remain stationary while the earth turns(or nearly stationary)thereby producing electricity.remember the earth is spinning at approximately 1000 mph relative to it's atmosphere.the first two problems with this would be material and the possibility of slowing the earths rotaion.the next would be maintenance.tell me what you think but keep in mind i already know it's a crazy idea.btw...if build to accommodate passangers it could be used for transport also.
As crazy as it sounds , it's no more half-baked than anchoring a cable in space for the proposed
space elevator
if it were made to use crosswinds that could solve the rotaional loss problem.
For such an idea to work, this would slow down earths rotation. Try and get a permit for that. lol
You're better trying to harvest methane from termites.
I have a half baked contribution to your idea, what if you teathered it to a helium baloon (durigable) with turbine style wind generators mounted inline of the teather, in order to generate power for electromagnetic controls? Oh well, I still like the idea of an equitorial rail system.
Possible your idear is. Plausible it is not. The amount of required investment for such an undertaking (along with many others) far out weighs the INDERVIDUAL gains. There is no way you can recoupe the costs and provide profit from such an exercise. Other small problems and possible clarifacations...
1. Abuse - A single train (as i read it as you are suggesting) would work but would be inefficent Multiple trains would work great but too many would ruin it. Your investors would want every cent out of your exploit so you would be running as many trains as you could before problems started to occur.
2. You would need the trains to be magnetic and the tracks to be the recievers as this would make it easier to collect the power generated otherwise the trains will require stators or a for of electrical conductant (you could go the otherway with possible intervals of Tesla coil recievers on the ground and the trains could have the coils discharging to the recievers).
3. Kill the passengers idea - You would need to stop the train to pick up the passengers. Stopping the train means stopping power generation. Also any guesses on how much power would be needed to stop a large heavy train travelling at 1000MPH???
4.Offshore maintenance - As you would need to have alot of the track running over water there would need to be some sort of off shore maintenance scheme. Floating railways, though done, require a hell of alot of maintenace and downtime...
Great idea and would work if we were a utopic society!!! write it down publish it and hope future generations have a chance to build it!!!
Wood that mean the earth could be derailed ? :)
Regards...
seeing how the moon dose not spin around maybe it would be better to use that?....doh never mind we dont live on the moon.
Quote from: CrazyEwok on February 11, 2009, 08:01:59 PMA single train (as i read it as you are suggesting) would work but would be inefficent Multiple trains would work great but too many would ruin it
i was thinking more along the lines of a continuous "train" with a continuous line of "sails/uprights" every so often.also,the passanger problem could be solved by building a siderail and car and "shuttling" the passangers up to speed.
Quote from: wattsup on February 11, 2009, 07:49:05 PM
LOOOL. this one was supergood.
tanx, made my day.
