Ahh, me again. oh well.
I will try to give more details of our motor and how newton's laws as well as Conservation of Energy and Thermodynamics are not Avoided.
Take a mass, in our motor it is 17 pounds. Revolve the mass around a central shaft at a distance of 6 inches. at a rate of 400 rpm.
there are a number of equations to determine Cf. please use your own and correct me if I am wrong.
The effects Cf have on that mass make that mass " feel" like it weighs 463.76 pounds. In other words, if that mass "came off" and struck a scale, it would "weigh" 463.76 pounds.
So, to clear up what a lot of people on here have said, Cf is not usable, I think that is true, but the affect Cf has on an object..... that object can be used.
Now, we have figured out a way to take that outward affect on that mass and turn it in to the direction of the motion of the mass. ( this is the patented part) The mass now is instead of pulling straight out from the center with all that force, but is pushing with some of that force in the direction of the motion. I say some, i am sure there will be loss here, how much is unclear now.
Now, lets say i can capture 10 % of that exerted force acted on the mass and have it push that mass in the same direction that it is revolving, that would yield 46.376 pounds of force and 23.188 pounds of torque at the given rpm of 400. Hp is a calculation that equals 1.765 Hp. The pure electricity used to create the above rotation is 600 watts in the motor we have built. Our motor uses 2 masses so double the output and take into consideration, this is only a 10% recovery and at 400 rpm. the Numbers go up fast due to the calculation of Cf where you must square the velocity.
energy in = energy out , well, the energy in the system in electricity is the watts, but with what I have invented, we have to add in the affect that the Cf plays too. the electricity only produces the rotation, it really has nothing to do with the output power in torque. the Cf that I am manipulating and using as leverage is where the energy in needs to be derived.
It merely is a more efficient motor, that utilizes the Cf that almost every motor on this site and in the world tries to avoid.
What I would like to ask you is, what if he can do what he says?
I understand I am going to be blasted with the kitchen sink here, but this is a leap of faith.
Cameron
Cameron, I am going to ask you to do a simple experiment. You apparently have an apparatus constructed, and some way of MEASURING (not calculating) the output torque. Yes?
OK, here's the experiment. Set up your equipment as it is supposed to operate, and get it running to your favorite RPM. Say 400 RPM. Now measure the output torque. Do this several times so you can get an average. Call this the "experimental" condition.
Now, use some hardware, or tighten up the shafts, or do whatever to FREEZE the positions of the moveable weights that produce, or use, or redirect the centrifugal force. I suggest fixing the moveable weights in their half-way positions, but at either endpoint of their travel would also be OK. So the weights cannot move, the whole "CF" mechanism is disabled and might as well be dead weight on the wheel. OK.
Now run the device back up to 400 RPM and measure the output torque. Several times to get an average. This of course is the "control" condition.
Properly, you should then repeat the experimental condition trials, and then the control trials. So you are doing E-C-E-C. This is so you can tell if anything important besides the CF changes between conditions, like bearings loosening, etc.
Then come back and report your results here. If you clearly have a substantial increase in torque in the experimental condition over the control condition, you could be justified in getting excited.
(Needless to say, the torques measured have to be continuous outputs, not just momentary, and the input electrical power should also be recorded on each trial.)
Quote from: cameron sydenham on February 19, 2009, 03:07:13 PM
Cameron
First, as to the concept, it sounds just like a complicated flywheel to me. A flywheel on bearings is pretty efficient. Friction is the only inefficiency. However, you cannot get more out than in. The point of a flywheel is to store kinetic energy - it is not a motor.
So, what is the point of your motor? You have electricity going in, which is converted into kinetic energy, which is then converted back into electrical? Assuming losses at each stage, no matter how much "more efficient" your design is than a normal flywheel, what is the point? You start with electrical, and end with less electrical.
Lastly, why do you even need to ask these questions? You have a device. What it does, it speaks for itself. Does it produce excess power over input? If so, that is the holy grail, and you should just be able to plug the output into the input, and the world shall rejoice and you will be rich and famous. If it does not produce excess power (and by your subject line, you imply that it does not), but merely consumes some electrical while making fancy motions, then it is a fine and interesting apparatus that consumes power and looks pretty and hums, but qualifies more as art.
So what is the point of your device if "energy in = energy out"?
@ tinsel, i have done a test like the one you ask. we are using a generator as the load. as far as measuring the rotational torque, we need a dyno or a transducer, we have neither, well, we have a dyno, but the inputs to start are too high.
when i "lock" the motor's ability to use cf, and make it run like a fly wheel, i take the rpm measurements at 50 watt input intervals.
when i utilize the Cf in our motor , i do the same. the rpm readings when the cf is utilized, we get a larger and higher rpm at the same watt inputs, up to a certain point.
Tinsel, you are 2 for 2 as far as having an open mind at least and I appreciate that.
@ the other post, I am only presenting this post as a follow up from past ones to find a company or agency or person that i can divulge our invention to so we can be paired up with the people that can help us finish our concept. tinsel made a very valid point in a past post. I only posted this in the hopes that some , a tiny bit of details will help me find the right people.
as far as a fly wheel, the fly wheel is an inertia only system as far as i can tell, no utilization of Cf or Cp at all.
Cameron
Cameron, you can get a pretty good idea of torque if you can use the method that the guys use in this video (the torque measurement, I mean...don't be fooled by their improper power measurements).
http://www.youtube.com/watch?v=NuM5TNi2lbU
On second thought, if your motor violates normal Newtonian dynamics anyway...maybe this standard method of torque measurement wouldn't work. But if I were you, I'd try it.
Your description of your tests sounds tantalizing. I'd like to know some details about how you are measuring the input power.
"Tinsel, you are 2 for 2 as far as having an open mind at least and I appreciate that."
:'( Some people here wouldn't agree with you on that one...but I thank you. I know I've been tough on you in the past, and I intend to keep being tough, until you can solidly prove your claims. I hope you see that as being helpful...
Email susskind@stanford.edu, pack your stuff, buy a round trip ticket from Tampa to Boston, small change at most? Stay at Super 8 near edu after cab, and hope it don't turn out like OJ part two? It really is that simple. For less than a g-note you can fly you and your invention and sray in a hotel and have it viewed by any quantum physics major person with a lobster dinner just on claim, you dont even need merit, these guys live for this stuff, as we all do, good luck and some.
With that said, Lobster on me for everyone ! ! , only if i could. I would.
I have no problem with the toughest people on here being that way with me and my claims. What i do know is that if i can get in front of someone like that, and if they can see the validity, the path is golden. Like I said in the other post, I have met with 2 mechanical engineers, a nuclear engineer, and an electrical engineer, they all say the same thing. "mechanically, I see no problem, that should do what you want it to." this past Monday i met with the owner/president of an aero space parts machine shop. He reviewed the drawings and the pics of the motor, ... same thing. his exact words, " from a mechanical point of view, I see no issues with that concept".
I obviously dint have it working yet, I wouldn't be here, I am looking to find a person or lab that can evaluate what we are doing to either credit or reject it, than with their endorsement, if they so decide that, put with with the powers that be to help finish and perfect the concept and bring it to fruition.
@tinsel, the electrical measuremets are made from a couple of tools, one is a large gray box, sorry i do not know what it is, but i can provide a pic, than we did separate measurements with standard voltage testers and amp testers, like from radio shack, we have 4 of those. this is what the electrical engineer was curious about too. He double checked it as well.
Cameron
what I can do with the motor now is demonstrate that with the use of Cf, i get better results than without. I can prove that in our motor design, the impacts Cf have are a benefitting factor, not a hindrance.
Input power measurements are notoriously unreliable, especially if the motor is a pulse-motor type. There are all kinds of effects that could cause what you are seeing on your (no offense) cheapo meters and mysterious grey box. For something as important as Free Energy or more efficient use of motor power, real data should be taken.
You really should be using something like a Clarke-Hess power meter:
http://www.clarke-hess.com/2335.html
These are expensive. Similar meters can be rented by the week from
http://www.testequipmentconnection.com/
which is located in Lake Mary, FL.
They may also be able to rent you proper torque measuring equipment.
Extech 380801/380803 Power Analyzer
http://www.instrumart.com/Product.aspx?ProductID=22885
this is what we are using to measure power input.
Cameron
thanks X, but who is it that I am emailing??
Your emailing someone that will work for food ( for the life of this planet). It's that simple. Buy the ticket, bring your stuff and buy dinner. Don't complicate things if you seek honesty.
emailed him on friday.
cameron
Do you have a schematic or more detailed theory of operation so that the device can be more thorougly analyzed? However, I do understand that the critical information is private.
yes we have 3 built. all the cad drawings you could need as well.
Quote from: cameron sydenham on March 02, 2009, 04:26:19 PM
Can you display them here?
Unfortunately, I am not at liberty to display the details. ( I know, I am a quack now). As I have said in another post on here, I was not aware that this was strictly an open source community and the people I am working with do feel that patenting critical parts are appropriate. Again, I apologize for my missunderstanding and my oversight. I have tried to use this site to help me connect with people, groups or companies that can go over the project, (complete transparency) where we are at with the motors and the concepts, and if they see the viability, help with it coming to fruition. I have made a handfull of contacts through here, and I thank the people for helping, but one of the downfalls for me is, I am not "supposed to come up with an idea like this" because of who I am and who I am not.
Cam
Quote from: utilitarian on February 19, 2009, 07:30:58 PM
...and you should just be able to plug the output into the input, and the world shall rejoice and you will be rich and famous...
you know i have heard you say this stupid thing numerous times. i am curious, how did you come to this assumption that that you can just plug the output into the input to test an OU machine. did you read in some grad school book that this is the proper way to test any and all OU machines? have you tested an OU machine with this 'loopback', or are you just making assumption and conjecture as usual?
was that directed to me or utilitarian? ???
in this motor, you cant really "plug" the output into the input, the output is a stainless steel shaft that rotates with a measurable amount of torque(once operating properly). electrical input is just that, electricity.
Quote from: cameron sydenham on April 15, 2009, 02:22:06 PM
to utilitarian, thats why i quoted him.
Update please Cameron?
what would you like to know?
cam
Ok. Patent pending status has been acquired. I understand that a working model will be required for a formal issue of a patent, but this should give us the protection needed to meet or discuss project and details to discern validity or not. We are still hoping to find someone that can review our project.
Cam
