Overunity.com Archives
Solid States Devices => solid state devices => Topic started by: Hugo Chavez on March 08, 2009, 04:11:19 PM
Title: Had something strange happen in an experiment and want to share.
Post by: Hugo Chavez on March 08, 2009, 04:11:19 PM
I had something very strange happen.  Hoping someone will have an idea of what happened and be able to explain.  There may be something in this or not. :-\
I was doing a quick experiment involving saltwater, in the case epsom salts in a coil.  I warmed the water in a microwave, not to hot, just warmed so that I could dissolve the salts easily.  I did this in a thick dark blue glass coffee mug.  I mixed about 1/3 of a cup of epsom salt in the warm water and conducted my experiment with the coil in the cup.  The coil was around an aluminum tube, no core.  a 9v battery was used for my experiment.  The water temp was never hot at any time. At one point, just messing around I had a neo in the coil.  I removed the coil when finished.   I left the cup on my work table after I was done.  3 days later I went to clean up my work area and the cup which was thick glass was visibly warped like it had been heated very hot. That's odd enough but crystals had formed up and out of the cup and formed a path to a magnet laying near the cup.  The salt crystals were wet and the magnet was encased in the crystals, wet under the magnet when I lifted it.  I did get a small shock when I went to clean it up but that's not unusual in my work area, I get static shocks frequently--the climate is very dry.  The  magnet that the crystals formed toward and on was not a strong mag, just a Iron ferrite.
Maybe there is an idea in this or maybe just an oddity.  I thought it was really odd so I figured I should post it just in case.
Title: Re: Had something strange happen in an experiment and want to share.
Post by: tak22 on March 08, 2009, 04:48:25 PM
Interesting, do you have a picture for us?
tak
Post by: Hugo Chavez on March 08, 2009, 04:59:58 PM
Quote from: tak22 on March 08, 2009, 04:48:25 PM
tak
no, I should have taken a picture. I didn't even think on posting this until after the fact when the wtf factor started to sink in.
Post by: Hugo Chavez on March 08, 2009, 05:01:22 PM
I'll probably redo everything as close to what I did and see if it happens again and monitor it more closely.
Post by: innovation_station on March 08, 2009, 06:59:37 PM
it almost sounds like you have magnetic water
verry strange indeed
what is the make up of epson salts ...  and the water .. tap water city water bottoled water??
strange ....    are the crystals electrified still ?  also try a magnet on them perhaps you can push electricty out of the crystals ... with the use of a magnet ....... ;)
ist!!
Post by: Hugo Chavez on March 08, 2009, 11:02:32 PM
Quote from: innovation_station on March 08, 2009, 06:59:37 PM
ist!!
the water is filtered water from a hard water source.  Just changed the filtration system a few months ago.  The epson salts was just from a bag that I bought from Albertson's in the medical section.  I cleaned up the experiment so pretty much destroyed everything which was stupid.  I should have left it as was and documented.
Post by: vince on March 08, 2009, 11:41:16 PM
From Wikipedia;
Properties
Magnesium sulfate is the primary substance that causes the absorption of sound in seawater.[1] Absorption, in this case, means the conversion of acoustic energy to heat energy.
Maybe your coil and magnet caused just the right frequency in the water for this to happen.
Vince.
Post by: Hugo Chavez on March 09, 2009, 12:14:41 AM
Quote from: vince on March 08, 2009, 11:41:16 PM
From Wikipedia;
Properties
Vince.
that is very interesting, thanks Vince!
So thinking about this, could there be the right frequency to trigger energy releases from the saltwater?  Did my coil trap energy in the water that later heated the cup?  Did other frequencies hit the cup? A song I played?  Shit the options just got much bigger.
Post by: Neodymium on March 14, 2009, 07:20:06 AM
Maybe worth trying to replicate the experiment with steam-distilled water next time. Just to rule out any impurities in the water making a difference to the results?
Post by: lostcauses10x on March 16, 2009, 12:25:52 PM
Cold fusion reaction is being claimed here. How is an even more interesting question. Blue glass has the possibility Cobalt Oxide as the agent for color. Possibly a catalyst for a reaction. The aluminum tube of coarse, and am wondering what type of wire was used as the coil with what coating.
The salts with the copper coils if that is what they were would go to Another heptahydrate, the copper-containing mineral alpersite (Mg,Cu)SO4·7H2O, was also recently recognized
This would give the high H needed for such.
Yes this should be repeated and if is easily done, shown to the world.   More than interesting if this is real. Very well worth the time for the originating poster to try it again.
Wondering why folks missed the glass melted part of the post.
