...you can see,if you take a look at www.geocities.com/iacob_alex then click on "Some_Drafts/text051.jpg(the last position...).
You can compare a simple design of a windmill ,if we "reflect" this one,as in a mirror...but try to use it in gravity.
All the Bests! / Alex
...implies,assumes to discern the commom properties,as in a mirror.
We know the vortex shape,in a fluidic flow,as a powerful circular/spiral moving mass of water or wind.
In the "deeps" of the fluidic mass flow,we meet the basic invisible inertia.
Maybe aerodynamics,hydrodinamics can be better pictured with inertial property as a frame,a fundamentals.
Inertia ,with no action is passive.
Inertia,,answers for every action as in a mirror...you get what you give.
If you have a power source(water flow),and an asymmetric shape inside(wheel collector)you can notice the vortices,as an "autograph",an answer regardind this asymmetric play proposed by the wheel.
As we know,the gravity field is irrotational,follows the straight line only.
So,how about the vortices?
In a gravity fall,if we do not follow the vertical line,we interplay with inertia.
Now,if the vortices are a common marker of the power flow,how can we represent them for our topic?
.....we can use , if we take a look at : https://youtu.be/0jHsq36_NTU (https://youtu.be/0jHsq36_NTU)
The suggestion is to "copy" the vortex/spiral as a basic repetitive 360* trajectory for a possible gravity powered device...let's say a "modified" trebuchet...
Al_ex
