Overunity.com Archives
Solid States Devices => solid state devices => Topic started by: Doctor Whodini on January 26, 2006, 12:34:35 PM
Title: UPDATE: Testing the Perreault Valves
Post by: Doctor Whodini on January 26, 2006, 12:34:35 PM
Hello all,
http://www.intalek.com/Index/Projects/SmartPAK_xPOD/SmartPAK_xPOD.htm
Figure 6 shows a variety of valves I've been testing out on my Wimshurst generator. Its interesting to note that the my largest 2" dia. valve displays the greatest effect. The valves shown range in size from 1/2" dia. up to 2" dia. The capacitance of the 1/2" dia. valve is about 5.2pf.
Bill
William S. Alek
Exploring Gravitational and Inertial Mass fluctuations,
Radiant Energy, and Temporal Anomalies
http://groups.yahoo.com/group/intalek
  INTALEK, INC.                        PHONE/FAX: 219.924.2742
  3506-43rd. Place                            EMAIL: mailto:wsalek01@intalek.com
  Highland, IN 46322 USA  HOME PAGE: http://www.intalek.com/
Title: Re: UPDATE: Testing the Perreault Valves
Post by: Dimasen on January 26, 2006, 01:41:25 PM
Is it really easy to manufacter this Perreault Valves?
Steel pipe, tungsten rod, some isolator is it enough to produce P.Valve?
And what is the name of gaz uses in Valve?
Post by: Doctor Whodini on January 26, 2006, 01:53:47 PM
Dimasen,
A 7" long 3/32" dia. pure tungsten welding rod costs about $2.50 ea.
A 4" long 2" dia. steel pipe, pvc pipe fitting, clamp costs about $10.00.
In other words, it costs under $15.00 to build a "complete" Perreault Valve!
Bill
Post by: Dobermann on January 26, 2006, 05:21:58 PM
Quote from: Doctor Whodini on January 26, 2006, 12:34:35 PM
Hello all,
Bill
Great work!
It will be good to make your p-valves experiments data available to public. As I understand the excess energy produced by discharge inside valve comes from e-avalanche effect. So what kind of gas exists there, air ? It should produce a lot of ozone during discharges I think. Does tungsten rod get consumed on the long run ? Also 2" dia pipe requires the maximum voltage to initiate discharge along with the increased distance between pipe and rod, so its obvious that your 2 inch valve will show the best energy kickback (more air molecules ionized).
Please if possible post the data measured from experimets, like Ein, Eout, etc.
Thanks!
Post by: hartiberlin on January 26, 2006, 05:42:43 PM
All, try also with copper pipe and graphite rod inside the copper pipe.
The Newman machine did work best with these materials and had the maximum
back current pulses only with this material combination.
Although they did not try many other combinations..
Regards, Stefan.
Post by: Dimasen on January 27, 2006, 03:41:24 AM
Stefan, Is the graphite rod diameter plays important role?
And, what gaz I must use in pipe?
Post by: hartiberlin on January 27, 2006, 10:15:48 AM
have not tested the dependance from rod diameter, but I guess the more graphite the better,
cause it will contain more radioactive isotopes, which radiate more when struck with a high voltage pulse.
Air as the gas is just fine, but a Russian researcher (Chernetsky )used H2 at
about 0.5 Tor pressure and got
5 x overunity results.
Have a look here:
http://www.nuenergy.org/alt/chernetsky.htm (http://www.nuenergy.org/alt/chernetsky.htm)
Post by: Phil7218 on January 27, 2006, 01:39:17 PM
Couldn't you also use a electrolyte instead of the gas? I think the key is to have many ions between two different kinds of metall or metall and graphite. It's the principle of many free enegy devices. H2 is maybe good as gas because it's very easy to ionize. But an electrolyte has a higher density of ions and you don't have to create them first with high voltage. Maybe you have to use a lower voltage to pulse such a electrolyt cell. And you have to find the right frequency to trigger it.
Post by: Doctor Whodini on April 18, 2006, 09:40:54 PM
I don't think a vacuum would work. So yes, a gas would be required.
Bill
Post by: Ros-Co. on May 28, 2006, 10:18:28 AM
Hi!
Unfortunately the first link is not work...   I would like some informations about the valves. I posted my first experiment with it to a Moray devices topic
Ros-Co.
Post by: Doctor Whodini on July 10, 2006, 09:50:35 AM
Hello all,
I'll be covering these valves in my presentation at the upcoming Tesla Tech 2006 show.
Bill
