tell me what you guys think asap!
is the picture self explanatory?
Self explanatory..... no, not for my little brain.
Gravity wheel or magnetic wheel?
More details please. :-\
Quote from: overtaker on April 12, 2009, 11:47:31 PM
it is both magnetic and gravity powered.
if you know how a tri gate magnetic track work then it should help you understand how this wheel works: http://www.overunity.org.uk/cmps_index.php?s=7a0a2870fb023cbb500560013a20aa7d&pageid=tr1
the first arm of the wheel on your right side falls down because of gravity at the end of the guiding ramp right into the neutral point of the magnetic field of a tri gate.
anyone out there? tell me why this will not work. looks like it will work.
OK OK
lolollololol
The bottom left ball will never go up the guiding ramp. Too many other problems to start explaining but it is obvious.
Nice try though.
the hardest part about this wheel is calculating the timing of the arm release so it falls directly in to the neutral magnetic spot of the TRI GATE track.
you just need strong enough magnets to overcome friction and the weight of the arms etc.
prove me wrong
FreeEnergy,
Why don’t you consider making a plastic or wood wheel with multiple spokes at equal intervals (lengths and distances apart) and simply attach the cylinder type magnets at the end of each spoke. As the attached magnets pass by single or double trigates, they would be propelled by from one direction to the other.
Am I misunderstanding the function of the trigates? You shouldn’t need gravity in the plan that I am proposing. In fact, the balanced wheel is moved solely by magnetic energy/fields.
Chess Knight
Quote from: chessnyt on April 15, 2009, 12:59:37 AM
FreeEnergy,
Chess Knight
the spokes or arms would need to be able to "jump" the the opposing magnetic gate so gravity comes in to play in my design.
if you have a better idea post a drawing for better explanation. i could be wrong but i think your explanation has already been tried and did not succeed. unless i understood you wrong.
is this what you mean? http://www.youtube.com/watch?v=ChGB3delzoA&eurl=http%3A%2F%2Fwww.youtube.com%2Fmy_videos_edit2&feature=player_embedded
i dont know if that will work.
http://www.overunity.com/index.php?topic=7222.0
Quote from: FreeEnergy on April 15, 2009, 04:06:06 AM
FreeEnergy,
Yes. This is pretty close to what I was suggesting that is displayed in the last video that you posted. The only thing I was thinking of doing different is instead of the cylindrical magnets point straight out, have them positioned in the same direction as the wheel’s axle (sort of like a revolver pistol) and have two triangle (trigates) on both sides of the wheel (for a total of 4 trigates). The ends of the cylindrical magnets would pass through the middle of 1 pair of trigates on both sides at the same time.
Chess Knight
Quote from: chessnyt on April 15, 2009, 09:46:12 PM
FreeEnergy,
Chess Knight
hello,
i dont think that will work from the last video. i could be wrong.
your idea maybe it will work if no one has tried it yet, maybe. post a drawing.
i still think my idea will work better. my idea should work i think.
seriously i can't see why this wheel will not work. come on guys!
