http://butchlafonte.50megs.com/ till new site is up and running.
New paying web site being build at this time that will have latest updates on the Equilibrium Motor,
test data, and a video, plus in time all more than 1200 past design idea drawings from the last twenty five years.
The new site address when operating will be butchlafonte.com
Thanks,
Butch LaFonte
Norman and all,
The Equilibrium Motor can be configured using two magneto's, one in repulsion and one in attraction. The present design excludes cores in the coils because they complicate the setup due to domains having to be reversed and the rotor magnet wanting to stick to the coil cores which complicates balancing the repulsion and attraction force and EMF forces. The air core design operates in a NEAR magneto way because the voltage/current stays stable during the rotor movement away from the locked rotor/stator and the air core coils act as permanent magnets because their strength stays constant through the rotor exit, no generator drag. One coil tries to act as a generator, the other as a motor, but any EMF they produce is cancelled by each other so the coils just act like permanent magnets due to the steady main voltage/current source. This source energy is recycled or used for other existing needs. The coils try but never are able to function like a generator, or the other like a motor. The mail power supply to a degree never knows what is going on with the rotor, it is kind of like a team of 1000 horses pulling in a straight line, one horse tries to slow down, the horse in front of him tries to speed up, and the total pull of the team stays the same through it all.
What is interesting to see is what happens when you take one of the coils out of the circuit and move the rotor away from the fixed magnet and watch the volt meter peg to one side. Then take the other out and put the first back in the circuit and see the same thing except the voltage is in the opposite direction. Now put the two back in the circuit and watch the meter needle stay almost still when you move the rotor away. They cancel each out, making the coils act like permanent magnets.
Butch
PS Please read the operation sequence on my site,
Hi Butch,
are you now actually building such a motor
or are you only going to build a website of all your drawings ?
Drawings are nice, but the real expertize can only be learned by building
such a unit.
It all works out in hardware completely different than you would
think in theory and drawings...
Only via building you can learn the tricks and secrets the magnet fields
are playing on you.
Regards, Stefan.
Stefan,
Are you offering to help finance the Equilibrium Motor prototype?
Butch
Well Butch,
I have not seen any drawings from you, which will
make me say: "Well he?s got it..."
So until you can show a few first measurements of something
interesting, you will probably stay on your own...
By the way, what happened with the motor the father of Dave Squires
did built for you ? Why didn?t you report on this one and showed some pics of it ?
Regards, Stefan.
Stefan,
The pics have been on the web for years, I will get the address and post it.
I proved the basic emf cancelation theory with that motor but never could get the attraction sequence with the circuit open to work. That is when I started looking for different ways to do the attraction (work) cycle.
If you type in butch lafonte into google there are 25 or more Equilibrium Motor links and pictures of another test model also.
Butch
See first page
I have video if needed on principle of equilibrium.
Eddy currents will not be a problem with new materials available.
http://www.theverylastpageoftheinternet.com/ElectromagneticDev/lafonte/lafonte.htm
I have integrated the LaFonte Equilibrium Motor principle into the exit area of the SMOT.
You have seen my 10 minute video of the equilibrium principle being proven over and over. Now look at this drawing on my home page and you can see how the disk is simply rotated into equilibrium and the disk will then just move out of the "stick" spot with little to no work just like in my video. This can be built very easy, but you need to see my video to appreciate how simple it is. First drawing on my web page.
My web page > http://butchlafonte.50megs.com/
Thanks,
Butch
Remember the drag will be due to eddy currents from electricity flowing in the ferro-magnetic material and the reason they don't continue to flow forever is because of the resistance of the metal to current flow. The by-product of that resistance is heat, induction heating being one of the most efficient ways to electrically produce heat, you can say that this period of drag is the rotating magnets producing heat for heating purposes. If you think of it that way then it is not a loss but just more useful energy being produced by this machine. This is not practical but as a device to technically produce overunity then it serves a purpose. I think the first thing needed in this overunity quest is to technically prove to the world that overunity can be derived from magnetism.
I believe the sticky spot can be "tuned" out as it all but is in my balance fixture video.
I think the new crystalline materials will make the turning drag go down. Turning it very slow for overunity testing will help.
I'm very excited about the disk test fixture on the same page also.
I feel the cat is fixing to be out of the bag!
Quote from: Butch LaFonte on April 10, 2005, 04:16:34 PM
Thanks,
Butch
One side sticks and the other repells. hmm...
What about the turning of the disc ?
How much power is needed for this ?
I don?t see it yet exiting with no power need !
At the exit the fields are totally different as inside the track !
Butch, try to build something, this will never work out as in the drawings.
Regards, Stefan.
Stefan,
My video should be ready on my new web page tomorrow. It is on there now but aspect ratio is not correct for viewing.
It will show you how much energy is needed to get the rotor turned.
Butch
butchlafonte.com
We are working on getting the aspect ration for my video corrected on my new web site at this time. Someone was kind enough to convert it for me from real player and it will load up very quick when on line. Thanks for putting up with my southern drawl in the video.
Thanks,
Butch
I did not draw the 3/16" thick Teflon spacer between the two large disks in the Equilibrium device on my old web page. It keeps the disks from rubbing against each and acts as a bearing for the one disk to rotate on.
Thanks,
Butch
Butch,
check out the Magnetic Flux Turbine from Dave Squires !
This is a working unit to your idea of moving SMOT blocks
through a magnetic gate !
Your idea still needs the flux switching and 2 gates at least !
Check it out at:
http://groups.yahoo.com/group/free-energy/files/mft/
Your simple fluxgate will not work.
Regards, Stefan.
I don't see the two designs being anything at all alike? I believe my design will work without any flux gates at all, just the sequence I have stated, I will build in the next 7 days, let you know what results I get.
Butch
The Pseudo Solid Rotor and the Turbine are two completly different principles and designs the way I see them. I will build proof of concept this week and post results.
Butch
Butch
