I think its now time to discover the real secret of a TPU.
Please answer these Questions.
a) How would you demonstrate the slight increase in colapsing magnetic field?
b) How can we make it many ?
c) How can we make it strong ?
I think many here can answer this questions, and if these questions were answered then that's it! get a thinking chair and from there we can say that tpu is not really a big deal of electronics, simple as a piece of cake!
if we can make a slight increase, then that is an excess energy and if theres an excess energy then we can make free energy. GOT IT ? 8)
astalabista!
bye thank you and God Bless all of you!
Otit L. Noicaro ;D
Positive feedback ! Find example and you will find the real power
hi
even GK in Lord of the ring thread says that we can find excess energy in the collapsing magnetic field and he is right!
Quote from: forest on May 26, 2009, 04:45:31 PM
examples are already available in this forum :-X
Quote from: Tito L. Oracion on June 03, 2009, 04:04:18 AM
hi
where?
it is fortunate that we still don't know how to use that effects because we would not live long enough if that effects were cumulative
chargeing a cap from the colapse of the magnetic feild ...
http://www.youtube.com/watch?v=FVs_7uCbkbQ
from a 12vdc source .. useing an inductive tuned setup ... low self inductance and high self inductance the high selfinductance winding acts as a choke and forces the kick out the primary ......
ist...
with this set up and some efford it can be made run with gain
ps im ALREADY SHOWING GAIN IN SLOW MOTION HERE .... ;)
Quote from: Tito L. Oracion on May 26, 2009, 12:08:16 AM
How would you demonstrate the slight increase in collapsing magnetic field?
This is about back EMF spikes, isn't it?
Quote from: Paul-R on June 03, 2009, 10:07:49 AM
Right! 8)
Quote from: innovation_station on June 03, 2009, 07:22:56 AM
ist...
i feel that we're discovering the same thing. ;) ;D
Seems like Tommey Reed took this to it's conclusion and found there is no OU to be had.
Quote from: forest on June 03, 2009, 06:59:07 AM
where?
Re: Lords of the Ring
« Reply #1 on: January 07, 2007, 06:39:15 AM »
I am listing the instructions here to wind and drive a TPU that produces kicks. Guaranteed!
A word of warning: There is a high degree of danger in doing this!
Overunity comes from the collaspe of the magnetic field.
Devices such as lifters, the ECD, the Turbo coil, and this one here all exhibit the same
physical property called the wing edge effect. That is where the Radiant energy flies off.
The rule is: DO NOT TOUCH THE RING! when it is on. You've been warned. I accept no responsibility for your attempts at completing this project. You are at your own risk. If you follow the instructions and end up in a dangerous situation, it is your fault, not mine. I have had my dangerous moment already and it isn't pleasant.
Quote from: Asymatrix on June 05, 2009, 06:09:25 AM
i'm always saying that it depends on the arrangement! >:(
@asymatrix
Quote:
"Seems like Tommey Reed took this to it's conclusion and found there is no OU to be had."
LOL, I would say Tommy Reed has not even scratched the surface, doing a few basic experiments and getting negative results is hardly a conclusion of any sort, it is a good start. I have done all the experiments he has done and hundreds more years ago and from these experiments I gained insight, they were a stepping stone to understanding things on a more fundamental level. Personally, he does not seem like the kind of person to give up, I think he will keep at this until he finds what he is looking for and I wish him the best of luck.
AC
That's because it is not based on BEMF.
Look again at the Tesla bifilar magnifying transmitter patent. A field pushing inside another field all on the same pulse. Then it collapses on itself. It works like an inductor and a capacitor. But not an LC circuit. You could treat it like that though. The BEMF is inside the field.
If you want to have fun at the Edison / Cromagnon level then sandwich between two plates of aluminum. Just don't touch the edges. OR charge a capacitor in parallel with the coil but use a switch to connect the fast discharge cap into the coil. Place this in a plastic trash can lid lined with aluminum foil. Mount on back of vehicle and fire at vehicle behind you to alleviate any chasers, thumpers or swine fortresses. The charge comes from the alternator. Cruel, huh? :o
--giantkiller. Better living through stun guns. :D
Don't you think that is about the first thing we guy's tried?
The collapsing voltage is higher, and thus it an charge up caps to high voltage using low voltage pulses.
But there is loss in the form of heat, and especially when using a low resistance primary to create a strong field.
I have tried many,many,many things regarding inductive kickback, because that is it's real name, but never was able to extract more energy out then i had to put in.
The collapsing field travels close to C, that is close, not over.
When it does go over it gives rise to RF and the energy will start to radiate away in the form of radio/microwaves.
If you are sure about your statement, feel free to back it by demonstrations.
Marco.
Hi everyone
Do you know that making circuit design like a cross, gives you free energy, believe me its true, there's the secret "the way to the cross where JESUS died for you."
hope you got it. :-X
God bless
otits
marco ...
2 freq shit changes ...
espically when RAN AT ITS NATURAL RUNNING FREQ!! :D
then intrupt that :o :P
ist!
http://www.youtube.com/watch?v=AtGSk33ssAY
2 freqs intrupted ... ;) 1 aa battery
and 1 more video ..
http://www.youtube.com/watch?v=068l0trm6TI
;D ;D ;D
Quote from: Tito L. Oracion on June 09, 2009, 12:54:27 AM
Hi everyone
God bless
otits
Very well put, Brother.
And did you know the reference to 'Living Water' is a reference to the aether?
Quote from: giantkiller on June 11, 2009, 04:55:23 PM
Wow! what a co-incidence
its a great info sir thank you.
I know this may be a bit overplayed, but this guy seems to have proven that there is indeed free energy in a simple collapsing electromagnetic field. First he shows that 50% of the energy is lost in between a DC power source such as a battery and a capacitor and then calculates the amount of energy stored in a capacitor in the form of joules. He points out that we now know that those joules are only half the energy that came from the battery and then proceeds to show how over 100% is stored in that very same capacitor from a single pulse with a starting voltage of 0V, he calls it the "The Single Pulse Experiment." I think this guy maybe on to something and seems to have found a pretty good way of measuring this by simply calculating joules of energy stored in the capacitor, and joules of energy that came from the battery. It also has a link to a capacitor charge calculator to help prove his point. Here's the video of it. https://www.youtube.com/watch?v=6qDccTUsF40
