Here's another one from the realms of youtube.
http://www.youtube.com/watch?v=V-MQvzOCNSI
Besides the question I posted there I was also wondering why he couldn't just close the loop. If the output current was too high a simple light bulb in series like he has should do the trick. He says it's easy to replicate.
The guy is a relentless con man. He's the one with the key ring 'proof of concept' nonsense. The batcap obviously bumps up the output on a short term basis. It's funny how he took the magnets from the other scam video and used them as a linkage, as if it somehow facilitates overunity. Watch out for this guy, he's selling plans on a scam website and will likely keep trying.
Yannick is supposed to be (Belgian) French.
The man speaking on this video is definitly not French. Not even Canadian French.
I agree that yannicksonic is a con man because he is selling plans via PayPal and he is using videos from various sources to attract the unsuspicious YouTube visitor to his site which he mentions in the description of those videos.
Yannick has not made this particular video, he is only using it to attract visitors to his site where he sells bogus plans.
Can we now actually discuss this video?
First off, any setup with battery banks or caps is suspicious and should be shown to run without draining.
If we need more info I would suggest tracking the maker of this video down.
AZ
From the title it looks like a replication of one of Léon Raoul Hatem's devices.
His son is Frank Hatem, they are French.
So the video supposedly depicts a replication of a Hamel device.
http://www.hatem.com/indexeng.htm
http://www.hatem.com/scienceENG.htm
A bit new age.... But hey, you can become a member of the academy for only 60$!
AZ
Quote from: AquariuZ on June 10, 2009, 12:49:27 PM
AZ
Hi all,
here is some information on hatem:
http://ecoledevie.fr/39.html
http://picasaweb.google.com/sellier.bruno/Hatem#
http://www.dailymotion.com/video/x3yool_fimgenehatem_tech
http://www.dailymotion.com/video/x6lmit_leon-raoul-hatem-lhorloger-de-luniv_tech
Tom.
First he runs it without the light (topping off that batcap I suppose), and after it's switched on, he doesn't show the power taken from the grid to run that master motor. I'm gulable and an electric rookie, but I'm suspecting already. Nice equipment though. Should be donated to an inventor ready to do something new.
AquariuZ, I went through his comments on youtube and none say it was his video so you shouldn't threaten him like that. It is a bit misleading yes but in his defense he never states he made the setup or video. I assume this is the owner of that website that is selling the "plans".
tbest
Thanks for the links
broli can you translate this?
I used to have a link for translations ,lost it in a crash
Chet
Quote from: ramset on June 10, 2009, 07:46:58 PM
tbest
Chet
I speak of this man Hatem a few years ago see here
http://www.overunity.com/index.php?topic=1225.msg38067#msg38067
this scam does not works !!
Quote from: broli on June 10, 2009, 10:25:25 AM
this stuff does not works
this man is very dangerous
this is a con man , he is not in ZPE research
but in research of lot of money
AZ
yes it is Hatem like
it was tested here :
http://www.econologie.com/forums/prototype-machine-de-hatem-photos-et-explications-vt4375.html
Quote from: tagor on June 11, 2009, 02:31:01 AM
another replication
http://www.econologie.info/share/partager/3plateaux.jpg
http://www.econologie.info/share/partager/alignement.jpg
http://www.conspirovniscience.com/forum/index.php?showtopic=270&st=360#
Naca au rapport ............
J'ai copier/coller ce que je viens d'ecrire sur le "forum d'en face"
Mis en place ce week end des nouvelles masselottes sur les 3 machines afin d'augmenter la force cinetique préconisée dans le brevet de Mr Hatem.
Les mesures :
Moteur N° 1 avec une tension de 60 Volts Dc (vitesse 3750 Trs/mn)
entrainant les generateurs 2 & 3 . Entrefer 2,5 Mm. les generateurs 2 et 3 ne sont pas en charge.
Consommation: 3,323 Amp/h X 60 volts = 199,38 Watts
Production= 0
L'amperemetre de gauche corespond a la conso du moteur d'entrainement. A droite, amperemetre de la charge.
http://www.econologie.info/share/partager/mesures-0001.jpg
entrainant les generateurs 2 & 3 . Entrefer 2,5 Mm. les generateurs 2 et 3 sont en charge.
Consommation: 5,48 Amp/h X 60 volts= 328,8 watts
Production : 1,85 Amp/h X 60 volts = 111 watts
Bilan : 328 - 111 = 217 watts de perdu, rendement pour le moins médiocre......., voir miserable .........., j'ai honte ............
http://www.econologie.info/share/partager/mesures-0008.jpg
Test suivant . enlever 2 rangées d'aimant pour augmenter encore plus le rapport force d'attraction > force cinetique.
La cata, trop d'effort a fournir, couple magnetique insuffissant, même en lancant les 3 machines en mode moteur puis en coupant l'alimentation des moteurs 2 & 3, le couple magnetique est insufisant pour entrainer les 2 et 3 sans charge.
Le test est pitoyable .......
http://www.econologie.info/share/partager/...lottes-0001.jpg
http://www.econologie.info/share/partager/...lottes-0002.jpg
Bon, si quelqu'un a une autre idée, je suis prenneur.....
Je ne baisse pas les bras, prochain test, je vais augmenter le diametre du moteur N°1 pour aumenter la vitesse sur le 2.
Merci pour vos commentaires....
Ps, une vidéo des test ici
http://www.dailymotion.com/videos/relevanc...arch/naca4412/1
Cordialement
Naca
328 watt in
111 watt out
Sorry for this. I don't know how to remove a message sent by error
Quote from: exnihiloest on June 11, 2009, 03:45:42 AM
He is 80, he is not a all dangerous, he doesn't search for money.
He is just a mystic enthousiast and a believer and yet, surely a pleasant person, but has not a working machine!
I do not speak of HATEM !!
I speak of yannick supersonic the con man :
( you need to contact NACA , this man have used his replication TO SELL PLAN OF THIS SCAM !!! )
you have to read all this link
I explain what i think of HATEM
Quote from: tagor on June 11, 2009, 03:49:05 AM
yes I know. You are too quick. I have seen the mistake and removed my message just after having sent it!
is it clear now ?
this man use all the video on the net
for selling plans of all the no working devices on the web
to get a lot of money , money and money
is it clear ?
Quote from: tagor on June 11, 2009, 04:01:04 AM
is it clear now ?
is it clear ?
Sad but true.
It's a great idea,running pulleys without belts or chain. I wonder.......
