Poll
Question:
Which buster schematic just might work (produce "free energy") in your opinion?
Option 1: 1 - 2 bifilar coils
Option 2: 2 - 1 trifilar coil
Option 3: 3 - 2 bifilar coils
Option 4: 4 - none of them
This is in fact "double" Bedini pulse charger which uses 2 batteries which charge each other simultaneously. I called it "buster" because if the Bedini circuit does not do anything unconvential, the batteries will eventualy be both depleted... however if the charging captures some of the "energy of universe" this circuit have a good chance to be perpetuum mobile :) which I doubt.
There is no need to swap batteries or anything, first battery is charging second and vice versa...
you are welcome to comment and to build this circuit of course and tell us all what's up
oh yes, please dont mind the exact parts instead try to understand the circuit...
this should be same thing only with just one battery which charges itself and you would need trifilar coil...
funny, so many views but no comments, maybe if I named this topic "self runner" I would be having at least a dozen of replications already ..
dont mind coil winding orientation, I just could not find better element in eagle... idea is that both trigger coils are energized at the same time and they "open" both transistors, current flows through main charging coil and energizes it, than after some time both transistors are "turned off" at the same time and induced current from the charging coil goes back to battery...
ok, thanks for your comment.
Silvije,
Nice work and a very good idea.
Attached is my try at your circuit. I have also attached the Eagle CAD files if anybody want
to make a PCB later on. What are your plans for rotor on this setup? A bicycle size type or
something smaller? Is the intended use of magnets all facing North out or do you plan for
an alternating North South system?
Groundloop.
thank you for your reply and files..
to be honest I have experimented with pc fan circuit something similar to Imhotep's version of Bedini circuit if I am correct, that is why my idea also differs from ssg motor...
but as you all guess I had no real success with that circuit so I put that aside and took pencil and paper just to write down some ideas..
that is the reason I do not have any plans for size of the rotor or magnet orientation at this time...
Maybe those of you with more experience with Bedini circuits or Mr. Bedini himself if he is reading this, could suggest some good setup...
I started with pc fan because I have a few fans and it is very simple to modify them... I do not have any other motor setup and I guess it would not be that easy for me to make one because I am limited on resources and time at the moment... also I do not have any lab for experiments as some of you might have... :)
so, if anyone finds some of this ideas good and is willing to give it a try, you are more than welcome...
and if some of you make one of this circuits please publish the results here
s.
Silvije,
I maybe try out your setup later on when I get more free time.
Thank you for taking time to answer my questions.
Groundloop.
Silvije what are R1 and R2? Can you please tell me those resistances?
Groundloop that circuit works as well as Silvije? cause it's modified a bit.
Thanks guys
I guess those resistances depend on coil and transistor characteristics.
Try with values about 1k.
But I will point out this again: you should look at this schematics as an ideas for circuit, you should not look exact parts and their values... that needs to be determined, I guess according to values of Bedini setups which are "known to work"
regards
Quote from: Silvije on September 04, 2009, 11:43:33 AM
I voted yes on the survey, but I couldn't say, "With reservations." You'll still need a rotating wheel and several North-pole-side-out magnets glued to it, for this to begin working.
Using something like a relay to trigger the transistors would make more sense to me.
Counter-winding the coils for a Caduceus coil /Joule Thief effect might also be useful.
Adding an additional coil to the trigger coil and then harvesting the EMF created was also done by others.
--Lee
Quote from: the_big_m_in_ok on September 09, 2009, 06:05:36 PM
--Lee
I hope you have noticed my poor wheel graphics on both circuit images... so I got that covered.
If you like to add another coil to the schematics you are welcome.
Please post here the circuit with your idea.
NB: It should be sufficient to explain something in words but lots of us likes images :) so everyone with some idea for modification please make a schematic (eagle is easy but you can also draw it with hand) or modify Groundloop's eagle files and put it here...
thanx
a Bedini circuit does do somthing unconventional . It makes use of the wasted BEMF and also as a plus spins magnets which can be used to harvest more excess energy from coils . . I have built a self runner with My own modifications to the ihotem idea althought i did do this with out knowing about him first . My bedin does feedback to the source and is not isolated . With the proper resonance and parts placment one is able to attaing the primary run battery and see gain without a secondary battery . . I have also filed you project as i have several ongoing perpetual products already and are being sold to the public . One is the E-light (patent pending) which uses magnetic rotation rater than a rotor to run Leds lights on one depleted aaa battery and charge another aaa battery simultaneously allowing indefinate swapping . you allways have a spare battery ready . there is no one else on the market offering such a daring device as the E-light yet in a sell able form . .
Gadget
Quote from: gadgetmall on September 10, 2009, 08:20:15 AM
Nice Circuit . I have built a self runner with My own modifications to the ihotem idea althought i did do this with out knowing about him first . My bedin does feedback to the source and is not isolated . With the proper resonance and parts placment one is able to attaing the primary run battery and see gain without a secondary battery . . I have also filed you project as i have several ongoing perpetual products already and are being sold to the public . One is the E-light (patent pending) which uses magnetic rotation rater than a rotor to run Leds lights on one depleted aaa battery and charge another aaa battery simultaneously allowing indefinate swapping . you allways have a spare battery ready . there is no one else on the market offering such a daring device as the E-light yet in a sellable form . .
Gadget
If you have self-running device please post a circuit schematic, or if there is already topic on overunity.com about your device please give as a link..
this part about patents I don't get... for example, If I would have free-energy device I would give it to everybody
for free, no patents...
but that's just me..
Silvije but that schematic that you posted worked for you? Did it charge the source battery or you're still expermenting cause I don't want to loose time building it without knowing if it works or not :).
Quote from: Silvije on September 10, 2009, 08:41:34 AM
:) i gave already !Check out Threads on me and My aka fusionchipSome things are not disclosed because i signed a non disclosure agreement . Huge Dollars in Free energy machines . you can buy one @ www.sunpowerwindpower.com . The units i sell will self destruct if tampered with and render them usless another patent in the process for that as well . Free energy is free money . who do you know that give free money ? I would like to meet him .
Gadget
Quote from: guruji on September 10, 2009, 11:06:01 AM
I am sorry for your lost time, than again I wonder what are you doing on this forum anyway? do we have free energy device anywhere? no?
If you read carefuly this topic from the start you will see that this circuits have not been build yet. They are just an idea. Idea for those who claim to have self-runners BUT are unable to show us overunity because the need for interchanging main and charged batteries... than again if I am right this circuits will not show any overunity just the same as any other Bedini pulse charger circuit... which only work if you are high or if you have specialy conditioned alien batteries from outer space or something ...
I hope you dont mind my jokes... but you have to answer yourself what do you expect from this circuits than I would be able to tell you if it works or not!
Please do not loose any more time...
goodbye.
Quote from: gadgetmall on September 10, 2009, 01:30:59 PM
Gadget
Ok, thanks but I am not interested to buy anything from you. I am certainly not selling anything either. I give my ideas for free. I also give my knowledge and my time for free.
About non disclosed things you mentioned: of corse I have a full basement of free energy devices which are powering my house and few other houses. I just cannot disclose it to you because I signed something... oh yes, a nda.. so basicaly I am just here wasting everybody's time on this forum!
How? Well I have it and I will not give it to you ;D And best of all is if I keep saying this after some time I will believe it myself but still will not give you any proof. To cut the crap, if you dont want or cannot reveal what you have, than you are of no use to this community. So goodbye to you too.
I will not visit your page and I am not interested in huge dollars so you might abandon your campain at least on this topic.
ps. my basement will also self destruct if tampered ;D and I am preparing patent for self destructing basements!
:) i gave already !Check out Threads on me and My aka fusionchipSome..
Gadget
I have checked your circuit and all I have to say that it is a nonsense. But let's say I am too ignorant, maybe even stupid, so I am asking from you to draw me a return current path which is supposed to charge your battery onto your circuit schematic! And I expect that you close that path. Can you? Could you?
Quote from: Silvije on September 10, 2009, 02:39:19 PM
Well Jr. what can i say except i guess your a total Loser ;) My Status Quo Speaks for itself and nonsence Like yours deserves no respect . your an ass plain and simple . Go away i would not take your money anyways because you already have "free Energy " It's comming out your ass hole !!
Gadget
Quote from: Silvije on September 10, 2009, 03:17:37 PM
My work Is continuing by other inventors Like fausto . he has modified it a bit . Also there are 60 Videos Documenting His replications of the Selfrunner along with mine on youtube "4Christonly1" and yes looking at your schematic i see you are stupid and ignorant just as you suspected confirmed wonderland garbage . Don't waste our time here unless you actually build something rather than dreaming and leading true inventors and contributors astray with untested junk .
this is a waste of space is all .
Gadget
Funny Little boy you are ! . Maybe one day you can play with the big boys .Oh but i see you have all the money you need so sit there on your but and play everone who had the mind to comment or take there time to play along with your imaginary circuit not even you built . Maybe i'll patent this circuit here just cause i want too . you going to stop me ? ANSWER : no unless you patent it first .
I suggest you read up before you stick your foot in your mouth again . bedini 's deal with positive charge .
Gee gadget looks like you need some help-
I went to your site http://www.sunpowerwindpower.com , and it looks like someone has hacked it.
most of the links are to bogus sites, and the few remaining items that are for sale are missing prices.
one link completely crashed my desktop
A real disaster
Quote from: gadgetmall on September 10, 2009, 08:37:30 PM
Hey gadgetmall, you sound really bitter for one "..Baptist Christian a good father.." as you call yourself.
Please do not come to this topic any more to spill your bitterness. After all I have never called you names as you did to me. You have just burried yourself...
To others: as you see, this gadgetmall character cannot show return current path for his self running imaginary device as one does not exist therefore his circuit cannot work even in a dream. BUSTED!
could not delete this
Hi Silvije I did not want to offend you about the time comment but did you build that circuit?so that I will replicate as I build others of bedini devices.
Thanks for sharing after all.
[/quote]
Quote from: Silvije on September 11, 2009, 03:02:49 AM
**Deleted** Good Morning No Comment Except . OK Well this is about your Idea > I am in the process of replicating this idea of yours for the Heck of it . Good time to set up the 200mzh Scope !
Quote from: gadgetmall on September 11, 2009, 07:54:35 AM
Even Good Christians have there opinions and anyways its for him to decide who the fools are . Fact is it Feedback to the source run battery on my Schematic is proven to work . How Many projects have you built ? i got over 22 bedinis 200 Jt's and a hundred other device i have actually built and shared . What you got ? can you light 400 leds from a 1 volt battery ? how about a CFL lamp from a 1 volt aa battery for 18 hours ? a self charging bedini ? you are full of talk and no action . I try to teach people here from my 38 years experience in the Electronics field and have not been shot down by the likes of you. I speak my mind and if you come off as a jerk then your a jerk . dosnt affect My friendship with others here one way or the other .I won't waste anymore of my precious time with you anylonger bud . GOODBYE !! :o
To all : Most people here know me and know what i have contributed . Not Imaginary Circuits . What i have posted are real live schematics that i built personally and have shared . one of them is an automatic switcher for a bedini and another is a zero volt oscillator among countless modifications to the fugi camera circuits and the tuned tank for the Jt . If anyone is experiencing problems with My web site it was ADBRITE the advertiser . I have removed them . If you could contact me with the offending link i will relay it to them . thanks
Gadget
well you do not need even 1V battery to light a cfl... you should read up about Tesla before you bragg about your great achievements... and you did not prove anything with your poor quality rubbish youtube videos... have your parents taught you to call others jerks? I pitty you.
Quote from: Silvije on September 11, 2009, 08:17:32 AM
**Deleted**Good Morning . anyone else care to replicate this idea of Solvije and post some comparing results with Mine ? Sorry Didnt catch your Real Name ? Mine's Albert and they call me Gadget and i have been called Worst :)
Quote from: gadgetmall on September 11, 2009, 08:43:03 AM
Don't pity me / Pity your sorry excuse for a proclaimed experimenter self . and at 52 yea My parents would agree your an idiot . If your a retard then i apologize . I dont make fun of the Mentally handicapped /
Gadget
If you will keep calling me an idiot I will have to report you to moderators. Please go away from this topic you are not contributing to anything.
I asure others of you that good christians does not behave like this gadgetmall caracter. Shame on him for giving this false image of other christians.
Quote from: guruji on September 11, 2009, 05:51:46 AM
Guruji I believe I have answered you this question already but I know it is hard to read through lot of nothing left here by characters like gadgetmall.
Question for moderators: is it possible to delete some posts or/and to ban somebody from posting on some topic if the person is writing off-topic stuff and insulting others?
You Started it With your sarcastic about My Patents Man.And No Everyone has a say here and If i offended your Intelligence then Sorry Just a Space in time and you caught me in a bad mood son . Sorry .At the Very Least I can show My Interest to help others even if you don't see i was trying to help because of My success in self charging Devices I am Now Offering you a Truce and a test of Integrity .I am Going to Build this Dream Circuit and offer to compare it with your Results If you Dare ? .using Quad Coils with that one extra Bi Coil and Pots In place of the resistors to Compensate however Groundloops Cleanup Is a Nice Clean render of the Idea In 12 volt form and i Will attempt to build it in a rotor design . What will it do remains to be seen. We will See. Could also Build this without a rotor If it Does trigger Properly I do Think By placing the coils close together . It could also cancel each other out if the phase is exact and without capacitors the out put will have hardly any affect other than maybe self conditioning . a Bedini needs caps for Bemf Amps to amount to anything . As you can see in the piggyback Crappy video here http://www.youtube.com/watch?v=JRnYQvYEwkM you so call it i light a 130 incandescent lamp from One of My Bedinies running 12 volts at a Fraction of input current less than 50 Ma . . This is only because of the caps on the output circuit. , As far My proven Circuit Located here http://www.overunity.com/index.php?action=dlattach;topic=6519.0;attach=29140 The return path is isolated unlike here http://www.overunity.com/index.php?action=dlattach;topic=6519.0;attach=30403 which uses only one battery and is proven to work by many even though you yourself have not tried it or it failed do to another factor explained . And Yes you can feed the output from a Standard Bedini Back spike circuit directly in the run battery . If i was to put Two identical circuits on one rotor out of phase i would expect more power required to run the extra coil . The Perk here is to get the Minimum amount of trigger circuitry to the absolute minimum below the output level . I have done it and its not that hard to spin a magnet at less than 1 milliamp . Also remember you can capture the remaining generator energy with more coils . the composition of the Core Would negate Drag down and as you see excess energy is produced in excess of the input . after all the spin is free and is only a trigger component for a bedini . Al this Is History stuff that is proven. The Key is How Little and how fast does it take to trigger induction to obtain current excess from magnet generated coil output plus series Bemf from the Bedini electromagnet/Back generated Capture . To achieve this is a matter of how good you wind your coil and its resistance . Your going to need over 60 ohms worth of good copper wire and more to achieve this .
Quote from: gadgetmall on September 11, 2009, 10:21:13 AM
apology accepted,
I am sorry if I hurt your feelings too.
You did not realy explained to me how that self runner circuit of your works,
I believe I still do not understand it. I see how the current loop should close but there is a problem. Isn't a diode D2 really shorting C1? How can that work?
Silvije (that's my real name, not nickname)
here is another idea, with two coil windings...
both have a triger coil and one have main and other have recharging coil
edit: I have re-uploaded circuit image bacause I made a little mistake with diode orientation...
somehow this first schematic seem to have most sence to me,
and we could add third coil which could be also used for recharging or
wound trifilar both coils and use extra windings for recharging
@gadgetmall:
also induced current spikes go back to the coil (red path) and not to the battery..
which is exactly with what my circuits deal with...
although I cannot see how your schematic can work it gives me an idea for another circuit...
Quote from: Silvije on September 12, 2009, 12:11:53 PM
@gadgetmall:
I can only account this to the properties of that rare Diode I use . It is no longer in production however i have been able to get it to feedback with other diodes . several people have n explination and Validate My Circuit here
Hi, This utube video by comwarrior69 will be off interest.He has a circuit which feeds back from the trigger coil and it also validates gadgetmalls claims. ;D
http://www.youtube.com/watch?v=rY4pSOsqNvY
regards jonnydavro
and Pengo's explination :am trying to accomplish with the slow speed is to have 50 or more pulses per rotation which ARE the radiant spikes that recharges the battery while the transistor is turning off, therefore sending the signal back to the battery when the current is NOT flowing FROM the battery. It is very tricky because Bedini said many times that you can not charge a battery when it is in running mode. In other words, one can not take current out and put it in "at the same time", BUT one can take current out, stop and put current in, which is exactly what we are doing here (current or radiant energy in this case).
Dup post Deleted ..
ok here is another idea, circuit might need some correction but logic behind it should be something like this:
while the trigger coil turns on transistor t1, high voltage capacitor should be connected to the battery charging it. while the transistor t1 turning off, the rest of the circuit disconect c1 from the battery and connects it to the diode rectifier so the current spike charges the capacitor... than again next trigger pulse turns t1 again, that disconnects c1 from diode rectifier and connects it to the battery and so on... this is kind of crazy and seems to me that this voltage through circuit would build up until something blows :) .. we need third step between I think.. please comment..
someone suggested that Bedini magic cannot work without high voltage capacitors...
here it is, slight modification of my first circuit...
I was asked earlier by gadgetmall what have I build so far. I did not answer that question. I have built a lot of circuits but none of them were "free energy" devices. I haven't build any of my ideas shown here on this topic yet. And the reason is very simple. For starters I wanted to publish all my ideas than to try them. Why?
First I wanted to show there is no free energy in this "Bedini like" circuits whatever some of the experimenters may claim. Second, if there is maybe something, which I doubt as I said on my first message here, than I would be tempted like anyone else to keep that finding for myself (remember huge dollars) and think of patents, selling, NDAs and other unimportant stuff. So even if there is some free energy hidden in this circuits, it would be shared and published and there could not be anything undisclosed, no secrets. So I could not prevent anyone to replicate. And that is something in my opinion what should be done if free energy device is to be discovered. Free energy has to be free, free for all and not just free to someone.
I noticed huge number of visits to this topic but still no report of a built device...
There may be 2 reasons for that: first, you have built it and it showed nothing special (no free energy) so you might be embaraced to report anything (please do not be) adn second, you have build it and now you have a self-runner and want to keep it a secret :)
So which one is it?
I will wait for some more time before starting to build those circuits because I still have some ideas which I want to publish/share first and would like to hear what you have to say..
s.
Silvije I'm building your first circuit but still winding the triple coil.
It's seems that you're professional to electronics and knowing what you're doing much more than me :)
Thanks keep sharing
I am slowly starting to test my own circuits. I have built a motor rotor so far using a inline skates wheel with integrated leds powered by little built-in dynamo. I have added to it 8 neodimium magnets north facing outward. Coils are going to be problem because I still do not have enough amount of proper wire... but hey, I'm in not hurry...
what's your status? anybody?
Hi Silvije this my motor with trifilar winding. I am going to try on this coil lenght about 4ohms if I detect heating I continue to wind to 6ohms.
About those transistors of the trifilar winding are they good for a 12v car battery or I have to use like 2n3055?
I guess 2n3055 and similar "power transistors" are prefered. But as I dont have much experienece with Bedini circuit we should ask people who have.
The 2n2222 transistor is a low power transistor. Lets
esimate approximately 1 watt internal dissipation.
The 2n3904 - 2n3906 are medium power transistors that are
pnp/npn pairs with similar specs. Lets estimate 6Watts maximum
The 2n3055 is a general purpose audio frequency power
transistor Lets estimate 10 to 20 watts internal power
dissipation.
If you think you are going to be dealing with HV pulses
you may want to consider using a power (metal case)
transistor built for Horizontal Deflection Final Output (CRT)
Service. These should be more robust in the face of high
voltage pulses and be more consistent behavior one-transistor
to-the-next than the 2n3055's.
You will need a power transistor (metal case) transistor
for running at 12 volts and above if you want to use a low
resistance coil of less than 50 Ohms dc internal impedance
or so.
All of the above numbers are estimates, your milage may vary.
:S:MarkSCoffman
this CRT transistors you are mentioning... do you have any part number in mind?
thnx
Usually with the 2n3055 a neon bulb is connected across it for HV pulses so that transistor is not burned off in Bedini motor.
unfortunately my job prevents me to give more time into this and probably for next two weeks no progress will be made with my setup...
later..
hi all,
I just wanted to say that for me, work on this Bedini buster project is finished.
I am now giving my attention to Orbo..
my rotor setup for this "buster"
http://www.overunity.com/index.php?action=dlattach;topic=8017.0;attach=37841;image
http://www.overunity.com/index.php?action=dlattach;topic=8017.0;attach=37842;image
looks usable for Orbo replication and my "buster schematic2"
http://www.overunity.com/index.php?action=dlattach;topic=8017.0;attach=37626;image
looks fairly similar to http://www.overunity.com/index.php?action=dlattach;topic=8411.0;attach=40523;image which is used now by one user in Orbo replication...
and my goal was to recover back EMF back to battery with this schematic and not to chase some non existent effect...
this mentioned Orbo circuit recovers back EMF in toroid trigger circuit of Orbo to minimise input power or to enhance eficiency... which is nice :)
bye
Hi Silvije did it work as you thought? Did you try that circuit?
I havent tried it as I stoped working on this project due to lack of time.
