David Hamel (1924-2007) spent over 30 years of his life seeking to understand the ancient physics of what he considered to be "Perpetual motion. Creation physics."
Supposedly, the "3 cone device" or "3CD" gives forth the principle of perpetual motion via 3-body interaction physics to the zero point energy field via the usage of duality/magnetism and of vibration. Chaos physics induced through 3-body interactions. Chaos induced to provide runaway conditions of acceleration in the apparatus. A method of 'straining the aether' through torsion field interactions through magnetism and extreme vibration.
Ancient Historical Origin
The physics are presumed to be encoded into worldwide ancient sites. Most noteably, Giza plateau, stonehenge, Teotihuacan and others. It was considered to be Atlanteian in origin. Remnants of a once high society (higher than ours currently). A direct reference in heiroglyphs would be the Holy Djed or the Osiris pillar. The Thoth Emerald tablets also reveal an importance towards this technology. This technology being outside of our historical understandings of science and nature.
Using sacred geometry or the geometry of nature in the designing of apparatus' (cone shapes, or PI involved, curved geometry) which in operation displays an unusual function outside of established technologies of today, which are mostly axial rotational driven/solid state etc. Sacred geometry occuring in all sorts of ancient sites worldwide, it is a marker for an earlier/previous civilization of high magnitude achievements. This is not world known and is hard to prove without technology such as the Hamel 3CD. The 3CD makes clear of the actual usage of this geometry.
The usage of sacred geometry is a misunderstood aspect of natural science of today. It has a much greater usage than known widely by today's populace. It belongs to the science of zero point energy and energy extraction. Also, a form of black hole and white hole creation physics through vibration. Another label also being "Creation Physics".
How It Works: Hamel Advanced Physics
Weight Into Speed:
A WIS generator was placed at the top of the 'first stage' of the craft. This is a heavy weighted granite sphere/ball (non-magnetic materials), rolling in circular path in a restricted space. It has a more exotic function as understood by D.Hamel for being a more scalar method of propulsion.
"Weight Into Speed" takes on the characteristic of always "falling forever". The large granite sphere on it's circular path is always falling in it's forward path (in a restricted space), as the curved surface platform (also being granite) behind it always raises. Magnetism involved in the picture (right) keeps the curved granite platform or pivot at a level height. The weight of the sphere augments the position of the pivot and as the sphere moves around the circular path, the magnetism corrects the pivot position. The sphere will tend to accelerate in it's circular path, as magnetism keeps up with the changes in the pivot. With increasing motion, the weight of the sphere is translated into momentum and speed. Hence, "Weight Into Speed". Magnetism force fields work at the speed of light or thereof. If the mechanism can work it's way at incredible speeds, it will start to generate free energy at the zero point between the magnetic fields of the pivot. Greater speed means greater energy output.
Note: The usage of granite is for the mohs hardness rating of 9 (quartz) for durability. It can resist high friction and also maintain a pinpoint low friction while in use. It is/was the most abundant material in nature.
An example was David Hamel's last project of two twin and very tall machines (10 feet plus in height). Sorry there are no direct pictures. Both were generating apparatus' which used granite spheres, each weighing in about 200 lbs each. Two spheres over top one another. The top being 'snared'. The motion of the top sphere being circular over the bottom. The bottom sphere having a cone cut out of it's bottom and a rod placed inside. The rod then connected to a base granite piece, easily over 500 lbs, which was on a bearing. The granite was circular and about 1 foot thick. It would thus turn. Small electric generators, 3 of them, would be placed 120 degrees apart...and would be driven by the turning granite slab...given energy through the the WIS spheres above. WIS can be used in any application requiring continuous motion without the usage of magnetism. It was David's goal, to use the granite slab (circular) to move the generators and generate electricity. The two twins were not completed due to his death.
In theory of ancient and advanced civilizations (such as Atlantis or Egypt), there is a theoretical correlation of WIS with the spheres of Costa Rica. In theory only of course and not hard fact.
3 Cone Device or 3CD:
The "3CD" is a vibrational apparatus (picture at right), which resonates to the high frequency of the ZPE field. It is used as a starter or beginners understanding into these realm of physics. David's first project involved only this machine. It was successful. 3 cones suspended in magnetic fields. The 3 cones touch each other through very low friction points. The base is a multi-ball and cup assembly which also, by low friction and attraction magnetism, sends the kinetic or standing wave back up into the cones. The top is a repulsion magnetic assembly which keeps the anisotropic line off balance when activated. The anisotropic line is a structural characteristic of the 3 cone setup. See image at right.
Magnetism is required in order to achieve the high vibrational rate in unison to 3 cones for chaos/runaway conditions. Air is also a requirement in the operation of the 3CD. Air is ionized between the bucking magnets for each cone to generate an electric field. The shape of each cone controls air flow/movement. This shape forces air to pass between the bucking magnets to increase the ionization potential. Upward draft being created in the process. Cool on the bottom of the machine and heated near the rings and above the 3CD. It is stated that the machine/3CD reaches an operation temperature of 900C in full operation.
The outcome of any 3CD is mechanical (cones) into electrical (ions/plasma) function. Purely mechanical, althoug overunity in all design aspect, into purely energetic function (plasma field). At full operation, the apparatus ceases to appear to be moving, all the while the electrical function takes over. A plasma envelope covers the entire apparatus and colours in the visible light spectrum (magnetic light) can also be witnessed. It is said that the colours of the rainbow would be detected by the witness eyes. Violet to red. Violet closest to the machine, where the zero point energy extraction occurs (between magnets), and through doppler shift the frequency elongates to the red spectrum away from the machine. At the core machine 'zero point' the "Violet Flame" is witnessed.
The cones themselves do not produce energy as this would violate thermodynamic laws. They tap another dimensional realm/power source (aether/zpe) through magnetic interaction (via vibration) and syphon that power into our reality/local physics realm. This energy is not created nor destroyed, but tapped. The cones can also provide propulsion when the geometry was altered to a saucer craft shape. In the 3CD form alone there is no propulsion means as the design was not intended for that function.
The 3CD, in theory, has a direct correlation to the Djed Pillar of Osiris. It has also been written that the technology is related to the Tree of Life.
Galaxy Trinity StarShip: A Great Task Held By David Hamel
David Hamel's quest was to build a duplicate starship of this image: Star Ship The name of the ship David was replicating was called the Galaxy Trinity.
The principle behind the replicated technology is vibrational vortex implosion (air currents moving due to vibrational movement and geometry design via suction and expansion of the wings). Two 'wings' would thus work against each other, translating vibration and also creating a vortex within and between them through suction/vacuum and expansion/release thus moving charged air through the mechanism. Charged air to later become a plamsa envelope which takes on the role of a force field.
The 3CD or 3 cone device or Hamel drum is the basis of understanding the core physics. Later on, the Galaxy trinity (above links) is also encorporating the same principles for flight. Verifiable, through drawings and through written words from the references/books (further reading) below.
The Galaxy Trinity was supposed to take the first stage design and replicate it upward in dimensions. The total craft was to have 3 stages of perpetual motion 'engines', all working together. The larger the stage, the greater the power potential in capturing from the zero point energy field.
The wings (which are inverted cones and larger) of the First Stage were made from stainless steel. Rivetted pieces of sheet metal with stainless steel support substructure, i.e. hollow square tube welded to the solid stainless steel rings. It was David's goal to weld all metals together, making the wing assembly all one piece (no rivets). Rivets tend to fail over time from contraction and expansion processes through metal heating and cooling.
The wings in the first stage (picture below), are but two 'pie plates' magnetically suspended in repulsion/attraction containment. Both wings are connected to each other through 'motion limitters' known as pinions. These pinions acts as guides to prevent the wings from moving too far from a central point in the z-axis. The pinions are made from granite and the contact surface is extremely small, almost virtually frictionless. The magnetism involved in repulsion for the wings easily overcomes this friction. A central rod with a magnet at it's top, suspends in magnetic repulsion. This rod is connected to the lowest wing though an 'adjusting' contact point which is also a vortex point for air flow. As the first stage speeds up in vibration, this rod is slowly raised from it's contact point which is a hole on the lowest wing (center), and air flows through. The wings, and rod assembly are all contained within another structure which acts like a 'case' or 'enclosure' for the wings. For the picture below, that would be the outer hull. The outer hull secures repulsion/attraction magnets and pinion/cup assembles in fixed positions on the inside, so that wings float effortlessly and without vibrational dampening.
Sacred Geometry and the Science of Nature:
All of David Hamel's physics are designed according to the sacred law of sacred geometry. Most noteably for any 3CD or WIS or ship design is the Star of David geometry. This geometry goes back to the time of the pyramids (Egypt and likewise) and much further back. It does not belong to any religious order or faction solely. It is the geometry of nature.
Sacred geometry is the geometry of nature. It is microcosmic and as well macrocosmic in pertaining to all things natural. It describes all of nature at the most basic levels of creation and beyond. Great strides in physics and cosmology can be made through sacred geometry and it's application. More so, than any other application used presently. It is dimensional geometry, and can explain the purpose behind the universe's functions/operations. Proof of such claims comes with the experience and know how of the ancients who existed prior to the current established race on this world.
Why sacred geometry in any 3CD or equivalent machine/apparatus? In order to tune to the aether field/zpe field with full resonance, sacred geometry is the means. No other means works fully, only the angles and proportions in sacred geometry can fullfill this. Any deviations from sacred geometry and the results will not be as complete. The 3CD at full resonance vibration, will in turn be guiding in energy from the aether/zpe realm to tune to the cone geometry and magnetic proportioning for maximum coupling efficiency. Another analogy is that when using sacred geometry only, applies to strict natural law, and thus prevents any abnormalities to be sent back into nature. An example of abnormality would be our automobiles, electronic devices and any power lines plus generators which we use today. They create harm EM pollution or just pollution in general in regards to nature and environment.
Any 3CD or implosion device utilizing sacred geometry can be explained through sacred geometry as far as operation is concerned as well. Starting with the 'zero point' which is the circle and dot in the center, which explains tapping the 'zero point' of nature or singularity according to black hole physics/worm hole physics. Then onward, up to the Vesica Pisces (picture at right), which explains magnetism/duality. Onward, it goes to the equilateral triangle, then to the square, then to pentagram and so on and so forth. The basis for zero point energy extraction simplicity, is the circle and dot (zero point) and the vesica pisces (magnetism). This clearly states, that magnetism is the key to unlocking the door to the zero point energy field.
Star of David geometry can benefit mankind in regards to health. It is higher geometry than the pentagram which describes life and it is integrated with life geometry. Since it is slightly higher, it therefore can invigorate life. The only way this geometry can invigorate life is by applying plasma which has tuned to the aether field which is tuned to this geometry.
Sacred geometry emerges from the aether field or zero point energy field immediately before any creation. That means anything subatomic and under will follow the laws of sacred geometry first before being created. Sacred geometry sets the rules for all things in creation. So does PI and it is integrated fully with sacred geometry. Therefore, PI also emerges from the aether field as a fundamental law of creation before anything material in form is created. Sacred geometry and PI can therefore be called energy laws which are ahead of matter/material laws of creation. Energy comes first before matter. Aether or ZPE field follows or creates the sacred geometry laws.
Hence, sacred geometry is hyper dimensional, since aether or zero point energy field is regarded as hyper dimensional. Using sacred geometry can be used by us, to enter into the hyper dimensional realm. That is why any propulsion systems based in sacred geometry will work. As long as the geometry is at the heart of the core operation of the craft. Tapping into the aether realm through vibration.
Again, vibration equates to geometry or dimensions. Vibration can equate to sacred geometry.
The physics of Time Travel and Hamel Physics:
Any 3CD or Hamel flying saucer relies on the interaction of 3D space, and as well as the 4th dimension which is time. This would be in the apparatus operation as much as the plasma being generated. It takes 'time' to generate plasma and it take 3D space to accumulate the plasma. Vibration is frequency or oscillation. Theory has already proven that frequency is time inverted. Any 3CD or equivalent physics uses vibration in the operation. Therefore, time is intrically involved in the operation of any 3CD. Theory has provided that any 3CD or equivalent physics can actually defeat the time domain or the time dimension will cease to have dominion, based on how the 3CD can achieve over unity and resonation to the aether field. Thus the aquistion to the 5th dimension is undertaken, by-passing the 4th dimension. Since the 5th dimension is aquired, the 4th dimension is now traversable or manageable. Around a 3CD an envelope of charged plasma which vibrates at or close to the aether resonance can slow time down, and if the rate of vibration is great enough, time will cease to exist. That would mean that the total 3CD mechanism would be cut off from local physics at full resonance vibration and therefore it would also be removed from the time dimension.
Whether this has been proved in example, this is unknown, but the theory of time travel and Hamel physics remains open for debate. Energy is directly involved with 3CD operation at the zero point, and this energy can be deemed negative/exotic energy, needed for wormhole physics and time travel.
Note: Planck-Wheeler length: The Planck-Wheeler length (1.62 x 10-33 centimeters) is the length scale below which space as we know it ceases to exist and becomes quantum foam. Time no longer exists below the Planck-Wheeler length. Or 10^-43 seconds (Planck-Wheeler length) is the interval in time where time shuts off. This can also be seen as a frequency of 10^41 Hertz.
Amos Ori has given the world an idear of how time travel can be achieved. Possibly related to Hamel physics in that a local warping of space-time is required.
David Hamel: The Man Behind The Physics
David Hamel (1924 - Sept 2007) was a carpenter and an inventor who claimed to be inspired by extraterrestrials, living in Ontario, Canada with his wife, Nora. Hamel claimed to have been contacted by aliens from a UFO on October 1975, who were from a planet called Kladen.
In October of 1975, while watching TV (residing in MapleRidge, British Columbia, Canada at the time), Hamel claimed that a male-female alien couple from another dimension appeared before him using the TV set as a conduit.
He claimed the aliens taught him the principles of free energy and perpetual motion, anti-gravity, alternate reality|alternate realities, the truth about the Bible, the Dead Sea Scrolls and ancient architecture such as egyptian pyramids|the pyramids, Stonehenge (which he said is a landing pad for a flying saucer), Atlantis, and other "Out-of-place artifact|ET artifacts". They also taught him how to build a flying saucer.
On the walls of the Egyptian pyramids/structures and the Papris of Ani (Egyptian Book of The Dead), David Hamel claimed, the "Neubians", whom he described as "the small people", inscribed the theory of "Free Energy".
According to Hamel and his wife, after alien contacts "mystical flower buds", which David said have been left by the extraterrestrials as a sign of hope, appeared everywhere, some of which Hamel kept in a plastic bag and claimed to have stayed green for over 20 years.
David Hamel believed his purpose was to share the information given to him by the extraterrestrials with the public/world and help get rid of the old and polluting energy systems (fossil fuels). He also believed that this knowledge was for the hope of mankind in escaping a very near cataclysm. Hamel claimed that this would happen on Dec 21st, 2012, as written in the Mayan Calendar and also the alignment of the Giza Plateau to the Belt of Orion.
His story can be read here: http://groups.yahoo.com/group/hameltech/
http://www.peswiki.com/index.php/Directory:David_Hamel_Motor (http://www.peswiki.com/index.php/Directory:David_Hamel_Motor)
http://www.davidhamel.com/index.html (http://www.davidhamel.com/index.html)
http://www.granitestarship.com/ (http://www.granitestarship.com/)
Further reading
The Granite Man and the Butterfly by Jeane Manning - ISBN 978-0-96-993450-9
Sacred Geometry: The Word Made Manifest by Robert Thomas - PDF file
http://rapidshare.com/files/185694374/The_Word_made_Manifest_through_Sacred_Geometry.pdf (http://rapidshare.com/files/185694374/The_Word_made_Manifest_through_Sacred_Geometry.pdf)
Granite StarShip by Paul Coulbeck Granite Starship Website
The Twelve Planets Speak! by Carl Van Vlierdan UFO CONTACT FROM PLANET KOLDAS
They All Told The Truth: The Antigravity Papers by Rick Crandall They All Told The Truth Website
Billy Meier Wiki - The Future Of Mankind Billy Meier
Star of David = the simplistic design of a prototype starship, using the most basic principles of energy generation based upon vibration.
A star ship which uses magnetism, since magnetism is behind al things in nature. Magnetism is what connects planets to planets, stars to stars, solar systems to solar systems, galaxies to galaxies and so forth....even up to universes to universes.
Through magnetism, the light speed barrier can be surpassed.
The ancients of Earth were GIVEN this knowledge.
They were given help, and of this magnitude they were set FREE forever from Earth.
All stone formations, that bear ancient value and which have been marked by crop circles, are telling of this transformation from earthling to star traveller.
The Star of David, is the invention, through transformation via access to the HOLY TREE OF LIFE.
A machine which turns on the light body inside the person, and the light body excedes the physical body, thus giving the person power of mind via light and thought over environment. When the light body surpasses the physical body, the person will live forever....for eternity.
Both the Tree of Life and Star of David craft are based upon the same physics. Cones are a basis for this vibrational device, which uses magnetism to float the cones. They move and form a line of symmettry called the isotope line which is continually breaking, and thus vibration is achieved.
This vibration breaks through the fabric of reality, and the underlying cosmic power is tapped and used for great purpose.
Through this raw cosmic power, crop circles are created, since the magnetism plays a key role in life enhancing, it can explain why crop formations are 'added with benefit'. Crop circles explain the power of the circle. Which it is. Powerful, since all creation is bound to the circle.
DUALITY X 2AETHER = PERFECT BALANCE X CELESTIAL
or
MAGNETISM X VIBRATION = RESONANCE X PLASMA
MAGNETISM = VESICA PISCES
VIBRATION = GEOMETRY IN THE FIELDS WHICH EXPRESSES VIBRATION
FLOW or PLASMA = SWATH AND LAY IN CROP CIRCLES
ALL THINGS IN NATURE VIBRATE
WE USE VIBRATION TO COMMUNICATE
WE SEE VIA VIBRATION of LIGHT
WE TOUCH THINGS IN THE WAY OF VIBRATION
NERVE IMPULSES ARE INDEED A FORM OF VIBRATION
THOUGHT PATTERNS, DELTA AND ALPHA WAVES ARE VIBRATION
THE CHAKRA'S ARE INDEED VIBRATION and VORTEX
and then there is
GEOMETRY
ALL LIVING THINGS AND NON-LIVING ARE GEOMETRICAL
SACRED GEOMETRY THUS MAKES IT THE CAUSE FOR ALL THINGS IN THE UNIVERSE
All very interesting, but Hamel only left us with his 'Hamel Spinner' which extracts energy from human muscles (the most primitive form of energy), not even a single working perpetual permananet magnetic wheel, much less a starship.
Quote from: spoondini on October 18, 2009, 09:36:07 AM
Only left us with the Hamel spinner? That's foobar!
Actually he left a starship plans, in which prototypes were created which worked. Other machines too. You obviously do not take his work seriously, otherwise, you would have known about his other important works.
It's really too bad many people down here on earth have not paid attention to him and his works. The physics are actually more important than most people would think.
Hamel spinner is not true perpetual motion either....it's more of a distraction away from the other more important machines.
magnetic wheel? No there was no such thing with hamel's works.
Fascinating stuff, thanks for bringing it forward here!
First link I found looking it up:
http://rimstar.org/sdprop/hamlshfs/hamlshfs.htm
Are we not thus? Our Chakras are in fact the same as the tree of life (Sephiroth), sacred Geometry. We vibrate at certain frequency, with environmental pollution effecting that vibration. It's ironic that aliens would use TV as a means of transportation, but what do I know. My instinct is that our bodies are the ships, they are just so polluted they won't 'fly'. This is not by accident however, for as we know power corrupts. We have to take back whats been slowly drained from us by a few greedy people in this world. Yeah, the world is in a transition state...it is retuning itself, I think we must do the same. Has anyone ever seen 'Dr. Who' ? I see the world as his tardis, it phase shifts through time. The world is now in that phase shift. If your personal vibration is not in tune with everything else, my guess is you would be left standing, in well....nothing. Like it or not this is happening. Exciting ain't it! :)
I had a dream of a spaceship some time back, about a year gone now. And it did have a spinning ring inside a translucent hull. This is gods honest truth! I knew that it used magnets to operate, not sure how I knew but I did. The ship was longish with a slightly bulbous shape to one end. Not a round bulb, there were strange angular protrusions off of it.....so not really a bulb at all. There were curved surfaces and also angular parts...hard to describe. Would love to talk to someone about this. Oh and it hummed! It emanated a strange glow around the ring, bluish white light.
I believe that it was being 'shown' to me. I had no prior knowledge to David Hamel's work before today when I all of the sudden got the words 'cosmic interplay' floating around in my head! so I googled it :) Very cool stuff.
peace
Quote from: Wacrer on December 17, 2010, 03:50:30 PM
peace
Hi dear Wacrer,
Im interrested in your dream, i had made many things from my dreams, please share it with me, could you make drawings?
EELRIJUE: I just found this site, and found your post, on this subject. I was looking for information on David's inventions. I found a post on him through u-tube, while looking for information on free energy. This is very good stuff. very interesting, and informative. I would like to learn more about what you have to teach on this subject. Please contact me at mjedens@yahoo.com. Thanks for your time and your post. Michael J 553
