i produce 9100 watts or 3500 amps @ 2.6 volts from 5 1000ths of a volt from an aa battery charged to 1.495 volts 2500ma . after test and secondary Bcap charged ,volts from the primary aa battery were 1.490 .
The Worlds first Heater discovered and now invented by me in a simple OU demonstration . I claim so and welcome replications .
introducing
The Worlds First AA battery Heater / Light Source
And you may replicate it to verify My Findings and Invention . Its Build in about 5 -10 minutes and cost less than 100 dollars each . here is MY schematic .
Gadget
I would strongly suggest you start your own thread as a take-off of the JT thread, and clearly illustrate the circuit (which I think you have already posted), along with an explanation of the measurements you have made, and what you are claiming.
.99
Quote from: poynt99 on November 21, 2009, 01:39:13 PM
.99
Thanks you Ponynt99 . there is a full explanation on the jule thief thread from page 997 to page 1003 . and also there is a new thread second stage joule thief where advanced information can be discussed . i am officially entering the contest and also anyone can replicate this in 5 or 10 minutes . the 2500 amps or 9100watts is a fact and a spec. for the ultracapacitor i am using here are some of the specs.
Short circuit current Is 3500 amps
maximum continuous current is 105 amps
maximum peak current for 1 second is 875 amps
weight is 0.02 kg
power dissipation max is 15,100 watts per kg
emax energy is 3.29 wh/kg
My circuit charges one of these then it is discharged into a load be it nichrome wire or other devices requiring large amounts of current @ 2.5 to 2.7 volts .And like your slogan . its so simple and right under our nose .
gadget
Thank you for clarifying your diagram. It is still a little unconventional, but I think I get the idea ;)
I read through all the pages starting at P.997. There are a number of voltage values, but not much else to go on. I also read the SSJT thread.
Could you please explain what has led you to believe that this circuit is producing OU?
Thanks,
.99
Quote from: poynt99 on November 21, 2009, 06:15:24 PM
Thanks,
.99
OK what is OU . Its Over UNity . What is Unity in this circuit . Its the AA battery start voltage and amp. which was 1.495volts @ 2500mah . ok primary source . running a simple STANDARD Joule thief circuit with a tank on the base . and a secondary of 22 turns for the leds. In this case you really dont have to have the leds . its a plus free energy . i use two .5 watt 5 chip leds . with the circuit adjusted to 13ma with teh ultracap 650farads 2.7 volts connected and discharged to .500 volts or a half a volt . the reason its at .500 volts is this is where transistors stop working and is the normal for my discharged caps . they dont work a Jt any more with a silicon transistor . I turn on the circuit . the Leds are approximately half bright . 14 hours later i have a full ultracapacitor with a causal 2.6 volts . I never charge these caps up to 2.7 volts the highest before they become extremely dangerous and could blow the pop off screw on the side / . Ok . So now we have a 2.6 volts with a maximum capacity of 3500 amps as per specs on the maxwell web site . before i kill the circuit after looking at the run AA battery voltage it stands at 1.490 or 5/1000ths of a volt dropped and theleds are now 3/4 bright . too bright to stare at .. BUT ALSO i have 2,6 volts Charged in the Bcap At a VERY HIGH AMPERAGE well beyond the tiny AA battery that burns nichrome wire . Simply Hit the AA battery for 5 seconds and the aa battery is well above its staring voltage . It's like hitting an aa battery with a 100 amp charger . Only for a sec the battery gets hot quick and charges up fast . Now . i still have 2.6 2. 5 volts to light up Nichrome Wire coil and get warm and light up a cigarette. This is way over the Unity of the run battery . See now ?
Gadget
Stephan I am making a video so i wont have to pay shipping on My massivly Ou device . It is Very easy to build and cost 100 us dollars . the device is The worlds first AA battery heater/light . . the only parts are one 2n2222a transistor one 2 k resistor , one 10 k pot one 102 capacitor. some #26 wire a one inch torroid some white leds one ultracapacitor 650f 2.7 volts and one Everready rechargable Ni-mh AA battery rated from 2500ma to 2800 ma . To complete this unit i will be selling the boards that make up that make the circuit self run . TBD . and some Nichrome wire and a switch . Simple . To describe the unit again Its a Standard joule Thief circuit with a tank circuit comprised of a resistor capacitor and a pot . . this circuit has been calculated as have a cop of 2,26 with an out put over 3000 amps @ 2.5 -2.6 volts maximum amps are 3500 amps short circuit. . I will take you up on the offer for the prize as i doubt anyone here can come colose to such a simple heater /light generator of this kind . I discovered this and i so claim and take you up on the free shipping although you can make this unit easily yourself in 5 or 10 minuits with the parts readily available anywhere . If you really need me to make you one then i will . But i need the free shipping so so the units will be on loan only . you have an option to buy My unit . the others do not have that option to keep it . I will nail down the self run circuit shortly with help from some other contributing members who are making circuit boards for this device . the total unit will be less than 6 inches Square and run for the life of the Ni-mh battery . 3-5 years they are readily available for less than 10 dollars per 2 aa batteries that this unit will run on . If i win the prize i would like to share it with a group of people here that has inspired me to release the very first PROOF of OU in its simplistic and most powerful form .furthermore ,to prevent "COPYCAT"entrants and Because i am the one who Discovered and invented this device no other entrant shall be allowed to enter a device using an ultracapacitor or joule thief in there Invention .
Gadget
thanks .
here is the required official phase 1 prototype document as stated in the rules for entry and to prevent a Patent Application Attached is the schematics . I will post further information as time allows pdf is updated with a summary
Gadget
Okay, I created this board
Devices applied for the OU prize
for devices like this which apply for the prize.
The status of this device on today 2nd of Jan.2010 is still open,
as I have not yet received anything from Gadgetmail and he is still
waiting for the shuffle switching circuit from Groundloop.
Please Gadgetmail let me know,
when you have something to ship,so
I will update this topic.
Many thanks.
Regards, Stefan.
Sorry to post here but I am really trying to get up to speed on the JT and would like to try the circuit gadgetmall has posted. However I cannot find any page "997 to page 1003" on a Joule Thief thread as the seem to end at page 858. Also I sent email to gadgetmall on his web site but no response yet. Can anyone tell me what a 102 capacitor is - that is what is the value in farads and working voltage? I purchased a 650 Farad Maxell cap and am trying to round up the rest of the parts. I also don't know which is the 'advanced Joule thief message thread' - does anyone have a link? I have an idea on the JT that I think may be valuable if I can just get up to speed on it. I think it may be part of why gadgetmalls first one worked and subsequent ones were not as efficient but I need to get one put together first myself. Please help. TIA
http://www.overunity.com/index.php?topic=8334.0 (http://index.php?topic=8334.0)
2nd stage JT topic link.
Hope this helps.
Bill EDIT: For some reason, the link is not forwarding. That is page 1 of the topic so just copy and paste it into your browser.
http://www.overunity.com/index.php?topic=8334.0 (http://index.php/?topic=8334.0)
@All,
I wanted to test the claim from Gadgetmall that a Joule Thief charging a Boost capacitor
(650 Farad 2,7 volt) was a over unity process. Gadgetmall claimed that one could recharge
the input battery (one NiMeh AA battery 2500mAh) from the Boost capacitor every time the AA
battery needed charge. I then did build a circuit that automated the process of recharge
the AA when the battery needed charge. The newest revision of this circuit (with software) is
attached. This circuit connects as shown in the attached drawing. This new circuit uses
only 0,6mAh from the input battery. The circuit will monitor the AA voltage and the BCAP
voltage. If the BCAP voltage is charged too much then the circuit will dump some BCAP
charge to a load to keep the BCAP voltage at a safe level. If the AA battery voltage drops
to a preset level (adjusted with a variable resistor) then some charge from the BCAP is
dumped into the AA battery to keep the battery charged. The attached circuit is doing
this without any operator input. I have run numerous tests on the system and I have not
found any evidence yet that this circuit is over unity. It may be the extra 0,6mAh circuit draw
that "destroys" the over unity process. Gadgetmall uses a manual method of charging
the AA from the BCAP battery and claims that this method is over unity. It may be so.
Groundloop.
Thanks much for the help Pirate and Groundloop. I did just find the JT threads and spent the last 15 hours reading them so I'm beginning to get a handle on all this. whew!
@Groundloop
Wow...I want to thank you for your apparent honesty...
and your really professional circuit construction techniques...
I think your circuit is going to become of use to the greater
overunity energy community as a whole, and I will always
give you credit and reference your circuit if/when I use
parts of it in the future...Thank you again, very much.
BTW By the way, I feel that 0.6ma at 5VDC = 3.0milliWatt
up sleep current should be sufficiently low as to not
destroy overunity while using with a 1Watt net user load
resistance with reasonable duty cycle.
:S:MarkSCoffman
Quote from: e2matrix on March 02, 2010, 01:42:12 PM
@e2matrix
The Jt circuit is shown eight posts up from this one.
and he meant "2nd stage Joule Thief" under "Forum"
heading. The 102 cap means .1uf cap at 25Vdc - this
is standard notation for a 5Vdc<->12Vdc mylar
digital circuit bypass capacitor...Note: Your post is an
OTP off-topic-post here...please direct future inquires
to "2nd Stage Joule Thief" thread. Thanks.
:S:MarkSCoffman
@mscoffman,
Just to clarify, the circuit uses 0,6mA hour from the 1,3 volt INPUT battery.
So this gives approx. 0,78 milliWatt hour of usage from the AA battery.
A ceramic capacitor with a marking 102 is: 0.001uf = 1nF = 1000pf
Thanks,
Groundloop.
Quote from: Groundloop on March 03, 2010, 03:31:40 PM
@mscoffman,
Thanks,
Groundloop.
Except for the "hour" designations, which I think should
be left out, meaning 0,6 ma continuous at 1.3 Vdc =
0,78mw. (An AA battery equals about 2560ma hours.)
I agree with the above corrections...It seems that
Gadetmall has some work cut out for himself, if he intends
to apply for the prize...I will remind that he probably hasn't
tuned his Jt circuit for this application, also a rechargeable
battery may make some difference. But, It's amazing the
difference between discussions of overunity and proof using
a circuit!
:S:MarkSCoffman
@mscoffman,
Yes I agree, the hour thing should not have been in the post.
It was as you say it, 0,6ma continuous. But that is not bad
for such a circuit. The JT uses approx. 14mA to run. The JT
was made by Gadgetmall and sent to me for testing. See attached image.
Groundloop.
I got this message from Gadget a few days ago and I wish
him all the best for his health.
Too bad it did not work out this way...
Re:Please withdraw My device from Contest
« Sent to: hartiberlin on: March 12, 2010, 02:44:52 PM »
Hi . I cannot get the device to work with the Gl board . It will work manual without the controller but i guess the free energy is being ate up or snuffed by the electronics in the GL controller . also I have Contracted Cancer and No longer have the strength or energy or desire to experiment anymore . I am dying . I have Enjoyed the time i got sharing My research with you guys and appreciate you letting me share them . I had many more things i wanted to show and draw and share like my Jt Hho generator that runs a torch from an aa battery but i never got around to making diagrams and also the light i was going to give the diagram i never got the change to do it either . I am sorry . there are others that will get it i am sure .
take care
Albert
AKA gadgetmall
