thought this one up, finally drew it out, let me know what you think
basically the wheels are on an axle with a slip, the red bars are the same weight, as well ass the grey bars on the bottom
this keeps the wheels always "upright", meaning the position of the red bars on the wheel will stay relative to the event horizon, the counterweight maintains this
if we hung a wheel by itself with the current red and grey weight set up, the counterweight will not be enough for it to move at all, which means that while it "overbalanced" it actually is stationary, however if we put two of these on a wheel, they will offset the weight with distance
does not matter where you put your off balance weights on the green wheels, the weight will not change at the blue points. If you locked the green the wheels at the blue points you would get a slight rotation until it tried to move the grey weights higher than your off balance weights
yes, the blue axle would need to be locked at specific points, possibly four
heres a better explanation with a new drawing
this time the counterweight is inside the "inner wheels"
1. inner wheels locked, main wheel rotates
2. main wheel locked, inner wheels unlocked
3. lock inner wheel, unlock main wheel
4. lock main wheel, allow inner wheels to reset to starting position
the main issue i see is step three, if step three works then i think the rest of it would
oops, heres the pic
