Overunity.com Archives
Solid States Devices => Joule Thief => Topic started by: innovation_station on February 01, 2010, 10:40:58 PM
Title: IST`S HIGH OUTPUT 0 ZONE GENERATOR 12VDC
Post by: innovation_station on February 01, 2010, 10:40:58 PM
WELL YES YES ANOTHER TOY!
FROM MY SIMPLE COIL ...
THIS THING 0ZONE YA OUT IN 2 MINUNETS FLAT!
DAT THING IS QUICK!
I WILL DO A VIEO ON IT TOO   I ALREADY DID BUT
I WILL MAKE IT A BIT BETTER ...  BY   ADDING WIRES TO IT ...
its SELF RECHARGEING TOO  PLUS IT HAS SECONDARIES ...  WICH POWER GROW LIGHTS!
WHOLE LOTTA LOVE !  BABY!
FIRST YOU GONNA LEARN TO PLAY IT ON GUY TAR MAN!
http://www.youtube.com/watch?v=isq8ZQSgnBs&NR=1&feature=fvwp
THEN YOU ALL GONNNA SING ALONG!
http://www.youtube.com/watch?v=zB_DOA2AL7Q&NR=1
W
Title: Re: IST`S HIGH OUTPUT 0 ZONE GENERATOR 12VDC
Post by: jadaro2600 on February 01, 2010, 10:44:15 PM
Wonderful; can you estimate the voltage it produces? I would like to make one of these.
Post by: innovation_station on February 01, 2010, 11:52:20 PM
I WOULD SAY WELL OVER 2000V   MAYBE 30 000
I HAVE NO TOOLS TO MESURE SUCH OUTPUTS!
BUT SHE STINKS UP A STORM ...
I PUT IT ON THE SCOPE 1OOV PER DEVISION
and i almost blew it up ...  so
i could only guess at the output voltage   secondaries  gonna be 500v there bouts .. will lite un modded led lights loa right out of the pack!
i will make a new coil  the same  way and video it in pictorial olny ..  im sick of the talking bit ...
then you can watch then go build it   and you will have the same results ...
but i put a lot of secondary wire on it ...  miles !  28 gage magnet wire ..
H
Post by: wattsup on February 02, 2010, 12:00:38 AM
Just make sure you don't breath that shit. It is pretty potent stuff.
Post by: jadaro2600 on February 02, 2010, 01:36:02 AM
Quote from: innovation_station on February 01, 2010, 11:52:20 PM
H
Measuring high voltage is simple really, all you have to do is create a series of capacitors of like makeup.
Say, 12 1kV ceramic disk caps will be able to safely measure 11-12kV ..all you have to do is measure the voltage across one of the capacitors and multiply this times the number of capacitors.
I would recommend 14 3kv in series (42kV) ...then measure the across one of these, as series capacitors will divide the voltage safely, when they are all the same, then the math is simple.  If you have these you are still limited by the DC, the voltage reading on most DMM's is 1000v max. ...so, using 30 1kV caps could get you 30kV or, to be on the safe side, 31 1kV.
The series strip becomes a tool for determining the over all voltage of the output ( DC measure ).
Axial capacitors are probably more appropriate for this type of high voltage, as the electricity may want to arc between leads ( so spread them out a bit ) or use shrink tube to help prevent such things.
Post by: innovation_station on February 02, 2010, 02:07:38 AM
THANK YOU!
jadaro
i made a video ...
whole lot of LOVE!
H
http://www.youtube.com/watch?v=NKAvG4mSK-U
Post by: innovation_station on February 02, 2010, 10:54:55 AM
IF ANYONE IS GOING TO BUILD THIS ...  BE CAREFULL!
IT WILL BURN YOUR SKIN ...
EVEN IF YOU JUST TOUCH A INSULATED SECONDARY ..  WHERE THE PLASMA COMES FROM
EVEN LIGHTING CFLS  TOUCH 1 WIRE IT IS GONNA BURN ...
LIKE LEAVE YOUR SKIN A WE BIT BLACK !
SO
be that knowen!
keep fingies back !
W
Post by: Magluvin on February 02, 2010, 11:32:51 AM
Da fingies.  lol
Cool vids Ist  Keep em coming
Mags
Post by: innovation_station on February 04, 2010, 12:28:50 AM
well i was playing with this unit today  and it lit an un modded cfl ...
like it was in the wall ...  off plasma ozone zero coil secondary ...
then  when i went for the plastic buttin to turn it off
i got me a good proper zap ...
i was holding the unmodded cfl in the 1 hand and presed the button with the other !
oouch
how bout a wire round the cfl to earth ground through some lights ... <
also i powered FULL BRIGHT LOA  off 1 air core secondary at the same time ...
still haveing recharge ...
as it apears soon as i hook up back side i loose front side ...  so i should cap back with neon
might try that ..
or just leave back side alone work off front side É
we will see
ist
Post by: innovation_station on February 04, 2010, 02:29:59 AM
i think i found my HIGH SPEED BOOST CAP CHARGER ...
and i mean HIGH SPEED ...
runs on 12 vdc ...  boost off the back ...
thing charged darn fast then blew my diode .. 4007
like smoke show...   even works ok from 9v battery ..  but small 12vdc ..  looks like a few min thing will be full
wow!
ist!
it went from 1.6vdc to 2.1vdc in like 1 min!
yikes almost blew it up   3 min flat!
IST BOOST CAP SUPER CHARGER !
SOME BODY WANT 1 ?
TRANSISTOR REMAINED ICE COLD ...     BUT COULD NOT TAP FRONT END ...  SO I TAKE IT OUT ...
EVEN CHEEPER TO MAKE NOW !
BTW ALMOST LOST NOTHING FROM DRIVEING BATTERY ...  VERRY LITTLE!
Post by: jadaro2600 on February 04, 2010, 09:31:21 PM
Keep us updated, I want to see some prints from your design. :)
Post by: innovation_station on February 05, 2010, 12:15:27 AM
im working on a multi jt low volt 2 stage SUPER SIMPLE UNIT TO RECHARGE 12VDC BATTERY! HIGH SPEED ...  then i just flick the boost cap charger ...  to recharge BOOST CAP IN A FEW SECONDS !
lol
but i got a little problem with blowen up them tin cans ...  2222a's    eating them like candy!
we gonna iron that out ..  then insted the leds on a jt ...  we gonna drop a freq mutiplyer ..  fed 30 vdc  high freq ...  on the input!!!
ok back to the lab !
ist
Post by: innovation_station on February 06, 2010, 12:02:43 AM
so i stuck my quartz crystal to the crystal LOA and i found an old toroide cap to hold it ... looks like supermans wand!
neat stuff ... i power it wireless cupleing to the 0zone generator ...  i think as per config it is useing the led to pump some saclar
it is neat how the tip lights up ...
and some one droped off a 35 mil camera ...
HAS A NICE LENZ   run backward!  lol   thats ok i strigented that one out ...
see i have a floro on when i saw the lenz and it puts out white light
then in the lenz i saw black light   green and red ...
hummmmmm
i bet there should be a bit 0 distance between the crystal and the lenz
orgone clown mover ?
healing maching?
I THINK WE CAN SWING THAT !
W
here a few pictures
and it is produceing a small amount of o zone at the same time NO SPARK GAP
so i got to thinking i might just TACK I ON  them smitter mittes right out here ....
went to see the old boy .. he try to give me a piss jug a dragon piss !   i says does that stink ...  he says a wee bit ...   but it will kill everything for miles ...  i says its ok   we just gonna use a little sclar !
stay away from the dragon piss!
Post by: innovation_station on February 06, 2010, 01:09:37 AM
so if we have a better look at the lenz  we get a few spin offs
like this one
led 7w super bright from a jt going into the mulit lenz  actavating the crystal dixie dust
and growing stuff!!  flicker style!
or
we go plasma spark gap   crystal coated lenz
what ya think
i could whip it up in a flash
W
Post by: jadaro2600 on February 06, 2010, 02:42:45 AM
Approaching Superman are we?
..Won't you please post the schematics? ...are we to be forsaken?
I was hoping to build one without a great deal of copper, have you any alternative coils; do you have any suggestions?
Post by: innovation_station on February 06, 2010, 02:57:51 AM
Quote from: jadaro2600 on February 06, 2010, 02:42:45 AM
SUPERMAN ooo  i KNOW SO
whats gonna happen if i coat the flash tube ..  of my mod ?
that some damm  fast flicker effect  kinda power full!
REAL BRIGHT ...   think i can pull output ...  ?
think i can get the flash tube to dubble bang?
ist
FOR LOWER MASS COIL
go to rs buy the 3 spool magnet wire  take  22gage and 26  ...  winde bifillar on empty spool  and you can throw the 30 gage on top for a secondary ...  but i doubt you will get plasma ...  but perhaps you may ...  i have not tryed ...
BUT I WILL
ill make the pictorial how you build a ALI gator coil!
useing thease materials ..  and   the skinnyer the spool ..  the more concerentrated the effects ...  AS PER THE OLD FORMULS  for electromagnetis!
i did this only on a taller spool for the origonal GATOR GETTER COIL! but i used a tonne of wire ...  may not be required ..  if i squish the coil!
we will find out soon enough ...
W
Title: ISIS ALI COIL!
Post by: innovation_station on March 07, 2010, 05:26:42 PM
HERE IS A HOW TO BUILD THE ALI COIL
http://www.youtube.com/watch?v=s95te2vP21w
H
Post by: innovation_station on March 11, 2010, 09:43:57 AM
4" ALI COIL ...
same way as the others ...
air core plastic bobbin ..  toroide inside ...   useing my magic feedback coil ...  then there is a long secondary on top of the bifillar electro magnet that vibrates ...
NO FANCY SACLAR SPITTING JUNK!!!  :p
STRIGHT UP ELECTRO MAGNETIC  INDUCTION AIR CORE ...  TRANSFORMER THAT TAPS THE BIG WHEEL ..
NO FEED BACK LOOPS THAT RUN AWAY ...
APERENTLY BULL FROGS HAVE NO CLUE HOW MY TPU WORKS ....  THEY CANT EVEN GRASP A JOULE THEIF AND HOW AND WHY IT WORKS ...
LMFAO
W
Post by: innovation_station on March 15, 2010, 12:50:03 AM
so i was thinking about building the tryfillar ... lol  ALI COIL 4"
this would be made of 3 rs spools of wire full spools ...
22ga 26 ga 30 ga ...  wind all 3 at 1 time ... untill all spools are empty ...
so you will have 40 feet 22 ga trifillar then it will drop down to bifillar ... for 35 feet ...  then it will end singular  secondary ...
22 = pulse coil 26 trigger 30 secondary ...
that will make the bottom coil .. of the multi stack ..
wound on some big 0
W
Post by: innovation_station on March 15, 2010, 02:19:54 AM
zoom zoom ...
that one is done took bout 20 min to build it ...
ALI COIL 3 WIRE ..  TUNED 4"
ALL COILS same  MASS ...
22ga 35 turns .. 40 '  26 ga 70 turns  75' and 30 ga 180 turns 200'
ist ..
Post by: innovation_station on March 15, 2010, 01:28:59 PM
here is the ALI 4" coil construction video
cheers!
                 !! WARNING !!
          electric shock hazzard
service by qualified personnel  only
W
http://www.youtube.com/watch?v=hARy2Mu1vWk
Post by: innovation_station on March 15, 2010, 02:40:00 PM
afew pics ...
: 0
ist
NO MASS CIRCUITRY INVOLVED ..
its just the knowalage of the coils and how they interact!
Post by: innovation_station on March 15, 2010, 03:59:52 PM
so now we have a 4" ali coil ...
if i were to jt it as showen ..   and take off the back side of the jt as a normal jt to fill a cap through a bridge ...  it does this no problem ...  now  i have it in a cap and allow some buffer time ...  i could diode it out of the cap to the secondary coil
inputside and use the other end of the secondary with a diode on it and a negtive feed from the cap ..
wich is common to the battery in a npn configuration jt ..
ist!
Post by: innovation_station on March 15, 2010, 06:43:06 PM
im testing out this coil as we speek ...
so far it works quite well
i have been rechargeing a cordless drill battery from a aa
it uses a 2n 2222a tin can and 2 db107 bridges ..  the 4" ALI and a cap ...
i back loaded the jt with a cap ... REALLY THE VALUE DOES NOT MATTER AT ALL..!!
its more a regulator .... ; )
and i then attached another db107 to the secondary ...  and hooked it dirrectly to the cordless drill battery it is a 12vdc battery ...
so i also placed a neo on the ring ... in the right oreaintation ... it causes my battery to charge faster 1 way than the other ...
it took bout an hour to fully charge the battery ...
ist
im building it right up and will make a video ...
Post by: the_big_m_in_ok on March 15, 2010, 11:43:24 PM
I think jadaro2600 is right.  For me to actually see a schematic would be visually definite in my mind.
--Lee
Post by: jadaro2600 on March 16, 2010, 05:59:57 PM
I'm definitely interested in an ozone generator.  I would like to see such a thing posted here - build my own, replicate, etc.
The thing is, the same such thing would be capacble of lighting many CFL's - so it's a two birds with one stone approach.
All that would remain is to tweak the input down to minimal levels and tada - simple low power consumption high voltage lighting.
Post by: innovation_station on March 17, 2010, 04:52:51 PM
Quote from: jadaro2600 on March 16, 2010, 05:59:57 PM
the unit as showen does not consume much at all i ran it for hours and hours .. from that 12vdc  3.6 ah gel.. battery ..
i used the back side to pull amps to fill the boost caps the front end is floro light or oz .. or god only knows what you could put there
ist ..
GOOD THING MY KIDS ARE COMEING TO SEE ME ...   to forget about life for a while ....   : )
i cant waite to see them ...
Post by: FreeEnergy on March 17, 2010, 07:45:22 PM
Quote from: the_big_m_in_ok on March 15, 2010, 11:43:24 PM
--Lee
lol good luck with that.
This guy talks a lot to himself if you haven't noticed. He has a couple of pictures/videos here and there, but no real math behind it to show us! Check out his previous threads/post, nothing but useless information. yeah sure he's posted schematics and things of that nature but it is all pretty vague. Oh wait thats right, we are too dumb to understand his superiority!
But then again to each his own.
Post by: innovation_station on March 17, 2010, 08:12:20 PM
Quote from: FreeEnergy on March 17, 2010, 07:45:22 PM
your words mean so much guy!
lol
comeing from someone who starts a thred " SELL ME YOUR WORKING JT "
go excercize your fingers on some wire ....
clearly i HAVE DONE SO ...
clearly you have not !  or why start the thred ?
W
Post by: FreeEnergy on March 18, 2010, 02:01:17 AM
some people don't have the opportunity to own tools or even wires to build things, in fact there are lots of homeless people out there that the only thing they own is the clothes and shoes they are wearing, some people are handicapped, sick, some blind, full body parallelization even, some are too old, weak, etc.
Post by: jadaro2600 on March 18, 2010, 04:49:22 AM
Quote from: FreeEnergy on March 18, 2010, 02:01:17 AM
This is totally off-topic, but I think that we should all invest some time to posting more information about alternative structures ( which don't look like crap ) ..materials science has a long way to come in the housing market.
Sad really.
I do want to keep this thread alive though, the Ozone generator idea in interesting.
If he doesn't post something soon, then I will - of course, I'll probably start my own thread - I just want High voltage, low milliamp usage, if I have to use a 9v battery, then so be it.  But it would be nice to get things on the road.
I've been mulling over some alternative transformer windings lately. ( And yes, I've seen all the crazy windings showing up on the internet, Rodin, ..then there's that spider-wound coil on the JTC thread. )
Post by: Doug1 on March 18, 2010, 07:27:10 AM
Jadaro
Just as a note of observation.
The windings are playing on the rate of change with in the domains both in time and volume based on the structure of the material. Differences in how the core material was formed may cause a shift in the structures of the domains even if they are outwardly seen as having no uniform direction. In the end you may have to learn or come up with a way to make your own cores so you can attempt to have or maintain a constant formation. Every store bought core is a little different even within the same batch.
Post by: innovation_station on March 18, 2010, 09:41:20 AM
how do you know im not homeless..
you own your fingers ...  i shared all there is to it ...  it is simple my little girl at 3.5 years old built  the damm coil and says here daddy!
you think i own more than the cloths on my back and the shoes on my feet ...
clearly you dont know me ...   i worked harder than  a lot at the THINGS I CHOOSE TO WORK AT ..
MY QUESTION THEN BECOMES WHAT HAVE YOU DONE ?
IT IS ALL WELL KNOWEN FACT WHAT I HAVE DONE  WITH THE JUNK PEOPLE THROW AWAY ..
so if you have issues it is with in your self ..
btw go read a TESLA PATTEND ..  WHEN YOUR READY TO DISCUSS IT ..
so am i ..
stop wineing for my work and do your own ..
i have paved a path through WONDERLAND FOR THE ONES NOT AS FAST .. I WAS KIND IN DOING SO ..
i did not at all have to do what i have done ..
agin i ask what have you done for me today ... ?
right ..  and you wonder why people get angry .. !
not rocket science here ...
W
Post by: innovation_station on March 18, 2010, 09:47:39 AM
Quote from: Doug1 on March 18, 2010, 07:27:10 AM
Jadaro
i do agree ..
cores are all diffrent and you must tune it ..
however im not useing a core at all in this unit ..
pick up just wire and a spool ..  and wind a coil bifillar ..  both wires same lenght diffrent gage ..  then wind a long secondary on top of it ...
thats all there is to it ..   if you fire it 12vdc you need resistance some where between 200 and 300 ohms
as i have seen ..
W
Post by: FreeEnergy on March 18, 2010, 03:16:54 PM
uh i was not talking about you, i meant what if i was handicapped or whatever. would you still tell me or others in similar situations to go figure it out for them selves and just give vague info about the technology? i am not going off topic here thank you, just making a point.
Post by: innovation_station on March 18, 2010, 03:32:27 PM
Quote from: FreeEnergy on March 18, 2010, 03:16:54 PM
i appoligize then ..
this is not vague
this is cut and dry ..
turn it on  turn it off that is all there is and ever was to it ...
W
tesla was hired to resolve the problem of the KICKBACK ... from the DC generators ...  as it was killing people when they turned off the generator ..
why ?
well this is teslas solution for the discharge ... lol
brill i think !
lol
Post by: FreeEnergy on March 18, 2010, 03:46:25 PM
i also apologize for my rude comment(s), i was pissed i wont lie to you.
anyway im done here.
goodbye.
