Overunity.com Archives
Mechanical free energy devices => mechanic => Topic started by: Rapadura on March 07, 2010, 04:49:33 PM
Title: V Gate Wheel or the "SMOT wheel"
Post by: Rapadura on March 07, 2010, 04:49:33 PM
Well, the last few weeks have been very busy for me here in overunity.com, but today is my last day of vacation, and tomorrow I go back to my job, so the time I can dedicate to the cause of overunity will be reduced considerably.
So, before it happens, I have to start a new thread about "V Gate Wheels" and my conclusions concerning this kind of "SMOT wheel", a thread in the correct place, that is here, in the "Magnet Motors" section.
For those not familiar with what would be a "V Gate wheel", the two videos below show two examples of working devices (with a little help from the human hand):
http://www.youtube.com/watch?v=ux4qfizL0xg
and
http://www.youtube.com/watch?v=hbj3rIFVb5w
Title: Re: V Gate Wheel or the "SMOT wheel"
Post by: Rapadura on March 07, 2010, 04:51:05 PM
As I posted in another thread, I have imagined an experiment to try to clarify some things about the "V gate wheel".
This experiment involves a large neodymium magnet attached to a spring that is fixed to a wall, a magnetic ball of neodymium and a inclined track.
The large magnet will atract the magnetic ball, accelerating the ball and making the ball go up on the track.
Here is a visualization of the system before we release the magnet that is attached to the spring under tension:
Post by: Rapadura on March 07, 2010, 04:51:59 PM
When the ball is half its way going up on the track, we release the large magnet, and the spring under severe tension will very quickly pull the large magnet to the wall, at a large distance from the track, so there will be no more attraction between the large magnet and the ball.
Even so, I imagine, the ball, that was accelerated already, will continue its way up, until the end of the track.
Post by: Rapadura on March 07, 2010, 04:54:25 PM
In the other thread i had asked two questions:
1) Will this really happen? When the magnet is quickly pulled back by the spring, the ball, that was already being accelerated, will continue its way up, and it can reach the end of the track? (My simulations on Algodoo software shows that yes, the ball will continue its way up);
2) If this happens, someone can imagine any relation between the magnetic force of attraction of the magnets and the force of the spring pulling the larger magnet to the wall? Or those are two separated systems?
Post by: Rapadura on March 07, 2010, 04:57:43 PM
As explained in the other thread, I had imagined this experiment because, in the "V gate wheel", apparently the attraction between the stator and the wheel at the moment when the stator begins to rise, lifted by human hand, don't cause deceleration in the wheel, maybe because of the angle of departure:
Notice as the direction in which the stator departs from the wheel is the same direction of the rotation, it departs in a direction that favors the rotation, rather than undermine the rotation. The same principle of the experiment I imagined above: the departure of the larger magnet favours the upward movement of the ball, because of the angle of departure, the direction of the departure (same direction of the upward movement of the ball).
And  this periodic "departure" is NOT the main thing that is causing the wheel to spin. The magnetic attraction between the stator and the magnets on the wheel along the REST of the rotation (let we say, 300 degrees of a 360 degrees rotation) is the main thing that is causing the acceleration of the wheel.
Post by: Rapadura on March 07, 2010, 05:00:39 PM
And now I have to repeat what I posted in the other thread again:
I think I discovered why the "V Gate Wheel" accelerates so well... In fact, I discovered that we don't really need any "V".  Instead of "V Gate Wheel" it should be named "SMOT wheel". And i think I discovered the power of the "circular SMOT".
Dear friends, everyone knows the "secret" of any SMOT is that the "next magnet" is always stronger than the "previous magnet". This is the principle of SMOT. The first magnet is the weakest, and the last magnet is the strongest.
The "SMOT wheel" is not different. Well, the difference between a SMOT wheel and a linear wheel is that usually, in a linear SMOT, the SMOT itself is the "stator", and the ball is the "runner".  In a "SMOT wheel", the SMOT is the rotor, and the ball (or cylinder) is the stator!
So, I discovered that, in a SMOT wheel, we don't need a V. We only need a gap, large enough to assure that, when our beloved stator approaches the wheel again, coming back from "exile", the "big bad" strongest magnet of the SMOT will be very far away, and the distance will make its attraction force towards the stator NOT be stronger than the attraction force of the WEAKEST magnet.
And I discovered a lot of other things that I will share with you in the image below. Please, analyse it carefully before start insulting me.
Post by: Rapadura on March 07, 2010, 05:10:06 PM
in short, what I mean is that everything in smot wheel plots for the acceleration of the wheel. It's a very promissing design.
There are many ideas about how to move the stator away from the wheel at the right moment (that is the moment when the last and strongest magnet is approaching), and move the stator back to the its original position at the right moment (that is the moment when the last and strongest magnet is far away enough to not make any "trouble", and the first and weakest magnet is approaching, restarting the acceleration process).
One of these ideas is the idea of using a cam.
Well, I hope someone take me seriously, and try to make experiments with the SMOT wheel soon, because I will only be in conditions to make my own experiments in late April.
Thanks.
Post by: Paul-R on March 08, 2010, 11:39:31 AM
Quote from: Rapadura on March 07, 2010, 04:49:33 PM
and
Looking at these videos, I would suggest that the motion of your hand is putting work into the system.
Post by: Rapadura on March 08, 2010, 03:57:23 PM
Quote from: Paul-R on March 08, 2010, 11:39:31 AM
Yes, Paul, the hands of those two different people who made those two different wheels is putting a little work into the system. But, as I tryed to explain above, this is not the main source of work. The main source is the acceleration caused by the attraction between the stator and the magnets along the wheel, going from the weakest to the strongest (as in any SMOT).
And the best thing is that, when the stator starts to go away, it don't decelerate the wheel, in fact, it gives a little more acceleration to a wheel that was already accelerated by the "SMOT".
Having the stator far away from the wheel at the exact moment when the strongest magnet is passing, and in the next one tenth of a second, when the "gap" is passing, is sufficient to avoid any sticky spot, any "gate", what means avoid any deceleration.
And is not absurd to imagine that a well constructed cam, that can make the stator be far away at that exact moment, with the less possible friction, may cause only a little deceleration in the wheel, a deceleration that is so small that the acceleration caused by the SMOT (what means "going from the weakest to the strongest magnet along the wheel") can easily compensate for that.
Someone gave the idea of having two stators, and just one cam, in such a away that, in the moment that one stator is in friction with the cam, the other is in the middle of the SMOT, helping accelerate the wheel.
Post by: Rapadura on March 08, 2010, 07:58:31 PM
The ugly animated GIF below (I tryed to do my best with Paint and GIF animator) is a demonstration of the principle of the SMOT wheel applied to a linear SMOT.
It's an  attempt to show which is the principle of the SMOT wheel, if it wasn't a wheel, but a conventional linear SMOT.
Of course, for obvious reasons, the circular SMOT (SMOT wheel) has a lot of advantages over the linear SMOT.
Post by: Rapadura on March 12, 2010, 04:38:32 PM
It is very clear that a small movement to depart the stator a few centimeters can make we pass along the gate (sticky spot) easily, with zero deceleration, in fact, with positive acceleration. It's the death of the sticky spot.
What's missing for people to realize that moving the stator is a minimal problem? It is very clear in the videos that the task of move the stator requires very little energy. If you doubt, watch again:
No one could make a wheel that size and with that weight spin so fast just by moving the hand a little bit like in this video. If it were a wheel with no magnets, and people try to make it rotate just moving a hand so little as in the video, the wheel won't accelerate so fast.
Post by: happyfunball on March 12, 2010, 06:20:40 PM
Quote from: Rapadura on March 12, 2010, 04:38:32 PM
Surely you have a few bucks to buy a few magnets, make a simple v gate wheel, stick a little ramp on it, and discover that the v gate is a simple circular SMOT which follows the same rules as every other SMOT. The guy in the video figured this out after spending what looks like at least $1,000 on CNC.
Post by: Rapadura on March 12, 2010, 08:08:08 PM
Quote from: happyfunball on March 12, 2010, 06:20:40 PM
The guy in the video was unlucky enough to have the unfortunate idea of seeking for electromagnets instead of thinking of using a cam.
I will certainly build my wheel, even if it means spending much of my wage. Right now I'm moving to a new apartment, and I can't spend so much. But you can be sure that as soon as I can, I will build the wheel and show that a circular SMOT is not the same as a linear SMOT, and the advantages over the linear SMOT are plentiful.
If people don't want to see the obvious truth that perpetual motion is possible, the only thing I can do is paciently wait until I have conditions to do it myself and show everyone this truth.
Post by: happyfunball on March 12, 2010, 08:16:25 PM
Quote from: Rapadura on March 12, 2010, 08:08:08 PM
~ a dozen magnets, a wooden dowel,  and a couple of small toy wheels = $10- $15 bucks tops. Go for it, Einstein.
Post by: Rapadura on March 12, 2010, 08:27:29 PM
Quote from: happyfunball on March 12, 2010, 08:16:25 PM
It can cost $10- $15 in your country, not here in Brazil. Here I need to spend no less than 100 dollars.
Ah, and remember that Einstein was considered a bad student in school when he was child. I bet that many laughed at him the same way that you laugh at me now. But he who laughs last laughs best.
Post by: happyfunball on March 12, 2010, 09:05:23 PM
Quote from: Rapadura on March 12, 2010, 08:27:29 PM
MORE in Brazil than the US? Lol. You must be planning on using a silver plated ramp...
Post by: Rapadura on March 12, 2010, 10:25:13 PM
Well, I have no time to waste with naysayers.
For those interested in the principle of using a cam to move the stator, I just posted a video on YouTube showing a simulation I did on Algodoo software (not involving magnetism, just a demonstration of the principle):
http://www.youtube.com/watch?v=0XIMPmhMJlY
Good night, I have to sleep.
Post by: Rapadura on May 02, 2010, 06:18:07 PM
I should have thought of that before: if there were multiple stators equally spaced around the V-Gate wheel, it would probably make the gate overcome one stator at each time.
If there were 6 stators equally spaced around a  V-Gate wheel, each time the gate on the wheel was "confronting" one stator, the other 5 stators could give the impulse to the wheel to overcome that stator at the gate.
It probably should work.
Post by: teslaalset on May 03, 2010, 03:45:58 AM
Rapadura,
You might find the YouTube channel of a guy that seems to be related to Brasil, but lives in Germany interesting:
http://www.youtube.com/user/ZZ2SVA
He seems to claim a solution for this technology and has patented it.
According to his channel his patent will become public on the 6th of May
(or it could be the 5th of June, depending on the intended date format).
I personally think it's not working, but that's just my own opinion.
You might find his work stimulating anyhow.
Post by: Rapadura on May 03, 2010, 06:15:47 AM
George Soukup... I think he is german but he had lived in Brazil during some time, because he speaks Portuguese very well, as I saw in one of his videos...
So far in Soukup's videos I could verify that his ego is very big, and he likes to compare himself to Albert Einstein. I didn't saw any proof of a working device.
Well, I hope his devices can work... I think he uses something like a V Gate, but I don't know if he uses a cam, or multiple stators.
Post by: happyfunball on May 03, 2010, 06:52:08 AM
Quote from: Rapadura on May 03, 2010, 06:15:47 AM
It's just a v gate wheel. It doesn't do anything. What these guys are looking for are sucker investors.
Post by: Poit on May 11, 2010, 07:29:39 PM
Hi Rapadura (and everyone else :-) )
I too am very interested to find out if the cam idea will work. I like the idea of having two different wheels running side by side. So one is in motion of gathering speed whilst the other needs to over come the gap via the cam. Both would work as a team.
I am kind of on both sides of this smot business (works? doesn't work?)..... the wiki page explaining why a smot would never generate more power than it started with kind of makes sense.... but at the same time I feel that you can>??? my head hurts lol..
heres the wiki page i talk of.
http://en.wikipedia.org/wiki/Simple_Magnetic_Overunity_Toy
at the bottom of the page there is a link to testing it
http://www.lhup.edu/~dsimanek/museum/smot.htm
Pete (poit)
Post by: Rapadura on May 13, 2010, 10:38:45 AM
@Poit: I think the idea of the cam should have a chance of work... But I think that, better than the cam, is the idea of multiple stators equaly spaced around the wheel. Each time the gate is stuck at one stator, there are other 3, or 5, or 7 stators giving torque to the wheel.
Post by: Poit on May 13, 2010, 06:46:06 PM
Quote from: Rapadura on May 13, 2010, 10:38:45 AM
I am playing with an idea (just theory at the moment), I figure that the motion of going around the wheel can generate enough electricity to power a solenoid (that pulls the stator away at the start/end of the gate). The faster the wheel spins the more power generated and less power required to operate the solenoid (i.e. because it only needs to operate for a fraction of a second to pull away from the gate).
I will draw a pic soon.... and post it obviously..
the maths should be fairly straight forward... power generated by wheel - power used by solenoid = usable 'free' energy.
Post by: wings on May 20, 2010, 04:08:07 AM
interesting document EXPERIMENTS WITH SPIRAL AND WANKEL MOTORS, with Ted Loder, Ph.D. :
http://www.scribd.com/doc/18992609/EXPERIMENTS-WITH-SPIRAL-AND-WANKEL-MOTORS-with-Ted-Loder-PhD?secret_password=&autodown=ppt
Post by: kallstrom_74 on June 05, 2010, 06:57:36 PM
have you got any news about this?
Post by: markdansie on June 06, 2010, 10:35:14 PM
Look up Paul Spains work, he spent many years and lot of money on spral motor looly based on Wankel design. He got as close as any to overunity
Mark
Post by: FatChance!!! on June 09, 2010, 02:26:44 AM
Quote from: markdansie on June 06, 2010, 10:35:14 PM
Look up Paul Sprains work, he spent many years and lot of money on spiral motor loosly based on Wankel design.
He got as close as any to overunity.
Mark
Meaning what? How close did he get to overunity?
We are dying for some more news about Sprains progress....
....it's been a while since there was any updates from him.
Have you any new info about Sprain that hasn't been told yet?
Please tell us. We would really like to hear how things went!
Post by: AnAppleSnail on June 23, 2010, 09:44:21 PM
Quote from: Poit on May 11, 2010, 07:29:39 PM
Pete (poit)
Magnets aren't quite intuitive.  The simple SMOT ramp works by fooling you about potential energies.  We're used to thinking of going uphill as taking energy, except that with a SMOT ramp, there is a magnetic hill encouraging the ball to go up.  Simply put, the ball in its initial position at the bottom of a SMOT ramp has higher potential energy than the ball at the top of the ramp.
Lots of people want to use magnets, more magnets, or clever bits of metal to get free lunch.  But simply passing through the field of a magnet, in one side and out the other, is a zero sum thing.  Putting a metal plate in to 'block' half of the field simply makes the change in the field more dramatic.  If you doubt this, look at all the people who have failed to link any number of chained SMOT devices with a ramp going back to the beginning - if it generates any energy, the only failure mode will be the ball flying off the track!  If the ball stops, that's because friction has overcome kinetic energy and stuck it at low potential.
Post by: mscoffman on November 20, 2010, 03:57:53 PM
See Link;
http://www.overunity.com/index.php?topic=10034.0
Post by: asifshabir on June 13, 2013, 09:27:24 PM
I have an idea for you, try using pulley's to pull back magnet at sticky spot(instead of using your hand).by using the the pulleys less force will be required to lift the magnet back . 8)
