Overunity.com Archives
Solid States Devices => Joule Thief => Topic started by: innovation_station on March 19, 2010, 12:33:11 PM
Title: IST'S CAM CAP CONVERSION DEVICE !
Post by: innovation_station on March 19, 2010, 12:33:11 PM
well
i have decided to build a power box ..  that is solar pannel driven  uses 2 rechargeable batteries .. and powers  ??
well  i will say at this point ... the limits are UNKNOWEN..
WILLIAM A. FILSINGER
DESIGNER , INVENTOR..
ONT. CANADA!
as per time and date ..
got to get chuch back here .......
as this is a power device for the young ring ..
Title: Re: IST'S CAM CAP CONVERSION DEVICE !
Post by: innovation_station on March 19, 2010, 01:51:26 PM
i have an old plastic dremmel box i will mount  the cams in and the solar pannel and the aa's
i have a small plastic box for the caps the relay and the pwm ..
i have room to add a wall outlet ...  to plug in light bulbs and lamps ...
FOR NOW!
W
i have enough room for 3 cam boards .. if i require more output at 1 time or if i choose to run the pwm faster ...
i will INSTALL A TURBO BUTTON !!
LMFAO!
Post by: innovation_station on March 19, 2010, 02:08:28 PM
the device as explained is still only a single stage device ...
and im simply draining the first stage  the ideal design it a 3 tear cascade device ..
however ..
i want safe stable clean renewable power SECOND TO NONE !
and i can achieve more than most require from a single stage ..
Post by: innovation_station on March 19, 2010, 07:58:55 PM
here are a few pics ..
ist!
Post by: innovation_station on March 20, 2010, 01:03:27 AM
this is going to be the
!CUBE !CON
IT IS A CONVERSION DEVICE IT OPERATES ON A SINGLE AA BATTERY TO 4 AA ..
depends upon required operation of the device
i am adding a outlet for lights .. loa's many it will drive UN MODDED ...  tested and released public!
aswell it will burn filiment bulbs of higher wattage!
it will power heaters .. of small scale
i will also add the young ring recessed plug .. it is also a stage 2 power supply  system
this output can be used for MANY THINGS. I will further explain ..
ist
Post by: innovation_station on March 20, 2010, 03:05:25 PM
well i better get back to work ..
ill whip this one up and post some more pics ..
this can charge 12vdc batteries ...
this can and will work with the FREE ENGERY RECVIEVER DISH ..  I HAVE COME UP WITH ...
I WILL LOCATE A DISH AND BEGUIN ON THAT ROAD TOO ...  IT SHOULD NOT BE HARD TO GET SOMETHING OUT OF IT!
Post by: innovation_station on March 21, 2010, 09:54:49 AM
i managed to finish the 1 side of the !CUBE !CON
it has 2 switches 2 aa's 2 solar pannels 2 bridges.. 2 cam boards 4 output wires ..
thats it !
W
Post by: innovation_station on March 21, 2010, 02:20:28 PM
the !POWER  POD  #1 in the i cube .. is compleate i took it out side .. the rechargables are too dead to run the cam boards solars are installed .. i went out in the sun with the meter  to check it to make sure it was working as per design ..
and yes all worked well ..
infact i was in the sun less than 2 min  and i said it would not run the board inside as the batteries are brand new not charged ..
i flicked the on switch to see if it would work ..
yes infact..... bang  goes the cap when i shorted the wires... : )
a smile comes on ist's face ..
W
Post by: innovation_station on March 23, 2010, 06:25:25 PM
well i was out and about today .. went to the grocery store ..  asked if i could have a few cams... : )
infact i asked if i could get a hole bunch ..
they SAID SURE  HOW MANY DO YOU WANT?
i said 50 or so ...  lol
they took MY NAME AND NUMBER... : )
there gonna call me when my ordor is filled ... : )
COST BIG FAT 0000000000  : )
IST!
the funny thing is ... the bags from the store are 5 or 10 cents each...
not only was i given free power BUT A FREE BAG TO CARRY IT HOME IN ..
plus i saved ALL THE LENZES AND EYE PEICES ; )
Post by: innovation_station on March 23, 2010, 08:15:37 PM
hummmm
i wonder ......
think i can ? string a HOLE BUNCH OF DEAD 9VDC BATTERIES TOGATHER IN A CHAIN AND FIRE IT WITH A CAM ..
and an aa
ist!
sounds like 1st place to me .....   ; )
LOL
welcome to the great wide open ..
http://www.youtube.com/watch?v=xqmFxgEGKH0
eddy waited till he finished high school  ... he went to holywood got a tatoo ...
he met a girl out there  with the tatoo too
THE FUTURE WAS WIDE OPEN .. !
Post by: FreeEnergy on March 23, 2010, 08:53:03 PM
whats a CAM?
Post by: innovation_station on March 23, 2010, 09:09:28 PM
Quote from: FreeEnergy on March 23, 2010, 08:53:03 PM
whats a CAM?
FREE ENGERY!
THIS IS A CONVERSION DEVICE IT OPERATES ON 1.5VDC FROM AN AA IT IS FOUND IN MOST PICTURE TAKEING DEVICES!
I CALL THEM CAM'S
SEEN 1 ?
IST!
Post by: FreeEnergy on March 23, 2010, 09:14:42 PM
uh i dont think i have seen one. could you show me how it looks like? i searched google for cam but that didnt really help.
Post by: WilbyInebriated on March 23, 2010, 09:34:33 PM
Quote from: FreeEnergy on March 23, 2010, 09:14:42 PM
it's the circuit from a disposable camera...
Post by: FreeEnergy on March 23, 2010, 09:36:21 PM
oh ok thanks
Post by: innovation_station on March 24, 2010, 11:29:23 AM
Quote from: WilbyInebriated on March 23, 2010, 09:34:33 PM
witch is a what ?
right a tesla method conversion device ...
you apply a small amount of imputted engery .. for a large one in return .. it runs high speed ..  and compounds in a cap !
it can then feed other caps to do work !
ist!
