Overunity.com Archives
Discussion board help and admin topics => Half Baked Ideas => Topic started by: ckreol1 on June 24, 2010, 11:19:12 PM
Title: how to cut round plexiglass
Post by: ckreol1 on June 24, 2010, 11:19:12 PM
I'm wondering how people build such well-balanced motors with perfectly round discs of plexiglass and pefectly centered holes in the middle of the plexiglass discs.
Doug Konzen does this very well, for example.
Can someone here give some instructions for doing the above task?
George
Title: Re: how to cut round plexiglass
Post by: jadaro2600 on June 25, 2010, 08:56:38 AM
What you need is a router table, guard-free/guide-free ...   This need to be a large table with a means to drill and fix a peg at a known distance from the cutting edge of the router.
Make a center hole, use a peg the same size, fit snug, or something larger with an appropriate roller bearing for easy rotation, ..this is the axis hole.
Using a plunging/edging bit... you can rotate the piece around the axis peg while cutting.  Some router tables let you adjust the front/back position, this will let you fine tune a diameter.
Ideally you will need a high speed, sharp bit, it's always wise to get a new one and use it for finishing edges.
This is how they cut templates - , since it's got an axle hole in it, then it's a final piece too.
If I had a router, I would probably demonstrate this, but I'm lacking any tools right now.
Post by: ckreol1 on June 26, 2010, 07:33:03 AM
Great, thanks.  That's perfect.
Post by: ckreol1 on June 26, 2010, 08:28:05 PM
http://www.eplastics.com/Plastic/Plexiglass_Acrylic_Sheet
They claim to be cheaper than lowes (hardware store). It also seems that the stuff at lowes is hard to cut.
These guys will cut it for you too!
Post by: ckreol1 on June 26, 2010, 08:32:17 PM
Another followup question here.
I would like to emulate Doug Konzen's pulse motor setup. Since he has done a lot of this, I wonder if he or anyone here is able to provide some nuts-and-bolts descriptions of his work: like the thickness of the plexiglass, the bearings he uses, etc etc...
A list of suppliers would be awesome, too!
Thanks,
George
Post by: darkspeed on June 26, 2010, 09:08:53 PM
Bridgeport vertical mill + rotary index table
Rotate the index table to cut the circle, then tilt the table 90deg and drill the holes at exact degree marks around the radius
This is if you was a very stable high speed motor
Post by: NTesla on June 26, 2010, 10:08:05 PM
I have built several electric motors (e.g e-Orbo,  of concept designs) using Plexiglas rotor discs. Here is how I make them - without having access to a lathe which would probably be ideal:
1. Equipment needed:
- Vertical drill press - the larger the better. You want one that has enough  area on its drilling table (the vertical column gets in the way) so that you can drill a hole in the centre of your cut plexiglass sheet.
- Disc sander that has a table (e.g. http://www.ryobitools.com/catalog/power_tools/corded/BD4600). This is for finishing off the circumference of the rotor disc plus its a great tool to have :)
- Jigsaw (e.g Bosch or Makita) with a blade suitable for cutting plexiglass.
- Saw horses for placing the plexiglass on.
- Clamps for securing the plexiglass on the saw horses.
- Square sheet/off cuts of Plexiglas (e.g 8-15mm thick) with the protective adhesive layer on both sides - this is important for measuring and protecting the Plexiglas during construction. I got a few off cuts from a guy who used it for safety glass in racing cars.
2. Either use a school draughting compass to directly draw the circle onto the sheet or if you have some good drawing software, use it to make a 1:1 drawing that you print out and then glue to the sheet as a template (remember you should be drawing/gluing to the sheets adhesive layer not the sheet itself). Remember the diameter of your rotor must not exceed the working area of the drill press table.
It is important to accurately draw NOW the positions of any other components that will go on the rotor disc (e.g magnets). Note that even if the circumference of your rotor disc is not cut exactly, if the components are positioned on it correctly, that may be what is important.
3. Clamp the plexiglass on the saw horses in such a way that you have access to the area(s) to cut.
4. Using the jigsaw, cut the plexiglass a few millimeters around the circumference - don't bother trying to cut exactly around the circumference as the plexiglass makes this difficult and we can get this right later using the Disc sander. Tip: A larger area you cut around will make it easier to handle when drilling the centre hole.
5. Drill the centre hole of the rotor disc using the vertical drill press - it is crucial you get this correct so practice on a spare piece first, use good lighting, and if you can, clamp the rotor disc down first. WARNING: Drilling holes in plexiglass can be dangerous because the drill bit tends to bite into the plastic - DO NOT use drill bits intended only for wood. If you cannot clamp the plexiglass to the drill press table wear protective gloves - it goes without saying that you should ALWAYS wear protective eye wear!
6. After drilling the centre hole, finish off sanding the circumference of the rotor disc using the Disc sander - if you can't get sufficient accuracy an alternative is to use the vertical drill press. Use a bolt that fits snuggly through the rotor disc centre hole and secure it with a washer and nut, then use the bolt like you would a drill bit - you sand the circumference of the disc by holding a sanding block next to the circumference while the rotor disc rotates on the drill press. Use coarse grit sand paper intially and limit the speed of the sander else friction will create lots of heat and melt the plastic.
7. Once you are happy with the rotor disc, you can then peel off the protective adhesive coating - you will now have a nice and clean rotor disc for use! Tip: If you are going to glue anything on the rotor disc that needs to be secure (e.g magnets), BEFORE you take all of the protective adhesive off, use a modeling knife to scribe the areas that need to be glued (cutting through the adhesive layer). Then peel these areas off and sand them to increase the surface roughness for a better glue seal.
Done!
As I said at the beginning, an appropriate lathe machine would be preferred, unfortunately I can't justify the cost of one right now!
Hope this helps! :)
Post by: Mk1 on June 27, 2010, 01:25:27 AM
How big do you need it ?
Post by: ckreol1 on June 28, 2010, 09:59:12 AM
Great instructions, thanks.  I posted them up to my site, electropub.wordpress.com, under "other stuff"--for easy reference.
The size I'm looking for is between 9 and 12 inches diameter.  I'm not sure on the thickness.  I think 3/8ths inch would be good.
I don't have any experience with plexiglass.  What is a source that others have used for plexiglass in the USA?
Post by: DeepCut on June 28, 2010, 12:46:05 PM
I do it simply and cheaply and they come out fine.
I use a jigsaw (fitted with a plastic cutting saw, 20 TPI or more).
I buy the plastic in squares.
Then keep cutting rotated squares until you are left with a circle that you can sand any irregularities from.
The centre-hole is found by marking corner to opposite corner, where the two lines cross.
Gary.
Post by: ckreol1 on June 28, 2010, 02:51:48 PM
Jig saw is a good idea.  Where do you buy your plexiglass?
Post by: DeepCut on June 28, 2010, 06:08:15 PM
I'm in the UK and all my supplier links are in the proper forum thread, can't remember offhand what thread is called !
One of mine is the http://theplasticpeople.co.uk and the other is http://plastickstockist.com.
Gary.
Post by: sm0ky2 on June 29, 2010, 01:41:07 AM
this shows cutting a different material, but this is the proper way to do it.
http://www.youtube.com/watch?v=Q0AYnvKLvTQ (http://www.youtube.com/watch?v=Q0AYnvKLvTQ)
Theres a guy on this forum, who made some videos showing how to do the same thing using his Dremmell Tool.
basically you mount the jig with a single bolt.
it doesnt matter where you drill the hole, as long as the circle fits on your piece of plexi, it will come out perfectly center marked.
like a compass.
Post by: DeepCut on June 29, 2010, 05:52:06 AM
Nice one smoky,
that looks like a good way to skin the cat ! i'll try that method next time.
Gary.
