After so many years of mentions of quartz transforming force into electrical energy, wouldn't a pico element with a broad plate area near the coil to be tuned sense the "resonance" as force pulses and therefore increase output when your are at resonance?  Then another could be placed on each inductor to be tuned,then you have real time data so then a PAL circuit can be programmed to make tuning automatic? Also, It will be found that air slows sparks.  So perhaps a spark gap within a vacuum will be quicker (maybe a gas will help).
The quicker the magnetic field is interrupted and the quicker the uninterruption (not a word but is exact) the more "uncompressable force" due to partials traveling at or near light speed colliding with other partials which disrupts the fields in the quantum range also.   Then you get OU, and more OU if you return some to the input each time.  You can see how all these devices work with this Kunel theory, so if the multi-tool works then use it!  So it turns out the power in lighting is really the same.  I know there is lots of power in the initial strike, but nothing like the what is produced by the "Slapping" of empty vacuum being equalized which creates THUNDER.   It would seem that the reaction is similar to striking the surface of water,  slowly and very little resistance is returned. Strike it fast and it will Strike back (head biting the tail?). Kunel has a recent patent on a all mag-gen that is amazing.
