Overunity.com Archives
New Battery systems => Other new battery systems => Topic started by: derwood on August 10, 2010, 12:05:45 AM
Title: Simple DIY Copper Zinc Cell (high power)
Post by: derwood on August 10, 2010, 12:05:45 AM
This is a cell I have been playing around with and it shows promise. I am making another cell that uses a 12in. disk that is mounted vertical in a thin container (2in x 7in x 13in case).  The case is 7in tall and the disk, which is is mounted to a shaft and can spin freely. Half of the disk is exposed above the case and the half that is submerged is in koh and a solid zinc plate (6in x 12in) sets about 1/2 in. away from the disk. Current is collected at the shaft and a piece of felt soaked in copper acetate was mounted so that it applies acetate to the upper half of the disk as it spins. The disk spins very freely. I spun the disk by hand very slowly and a short circuit test showed 6 amps a little faster and it went past ten. This way the acetate does not come into contact with the electrolyte and the zinc and does not dillute. I need to perfect the acetate application sytem and a low power motor could easily turn it. Zinc plated steel did not work well, it disolved very quickly. You have to use solid zinc.
http://www.youtube.com/watch?v=eQBlJGLWYRA
Title: Re: Simple DIY Copper Zinc Cell (high power)
Post by: nievesoliveras on August 10, 2010, 09:10:16 AM
It is more expensive to use that battery than a normal rechargeable one.
Just imagine for instance to pay for the zinc electric cover every two hours.
Jesus
Post by: derwood on August 10, 2010, 04:22:37 PM
It is zinc plated steel..... I use it to test with. The layer of zinc is very thin. If you use solid zinc it would last a very long time.
Jesus
Post by: pese on August 10, 2010, 04:51:46 PM
Quote from: derwood on August 10, 2010, 04:22:37 PM
Jesus
Try to use pur Zinc, Metalls.
Use that material (recyle it ) from old zinc-carbon batteries.
the autside case, ist oure zinc !)
zhis way you can use your batty, some days.
Try it
Pese
www.alt-nrg.de/pese
german / englisch alternative link collections
Post by: derwood on August 10, 2010, 05:33:15 PM
A 1/16 inch thick zinc plate is 300 times thicker than the zinc coating. 2hours x 300= 600hours.
Post by: nievesoliveras on August 10, 2010, 07:06:34 PM
Let us see what happen.
Jesus
