Overunity.com Archives
Solid States Devices => solid state devices => Topic started by: CLaNZeR on August 30, 2010, 12:12:31 PM
Title: Looking at the Rodin Starship Coil
Post by: CLaNZeR on August 30, 2010, 12:12:31 PM
Thought I would make a Rodin Starship Coil and have a play.
Here are a few video links I made this weekend.
http://www.youtube.com/watch?v=M6qZUgaWMQs
http://www.youtube.com/watch?v=D5vL4WaPHoE
http://www.youtube.com/watch?v=tbfH5zo5j_E
http://www.youtube.com/watch?v=PlhrhcUSD8o
http://www.youtube.com/watch?v=5sm-Wqnkwb8
http://www.youtube.com/watch?v=EjQ6jNG1Cis
Cheers
Sean.
Title: Re: Looking at the Rodin Starship Coil
Post by: IotaYodi on August 30, 2010, 04:51:52 PM
Very impressive Clanzer! The cnc is tops.
Post by: CLaNZeR on August 30, 2010, 05:13:19 PM
Quote from: IotaYodi on August 30, 2010, 04:51:52 PM
Thanks Yodi
One more, explaining the simple switching circuit.
http://www.youtube.com/watch?v=7V7brdZUSog
Post by: ramset on August 30, 2010, 06:57:56 PM
ClaNZer
Wow its like "Outer Limits"!
A beauty too!
Thanks for sharing your hard work Bud.
Chet
Post by: Lakes on August 31, 2010, 05:07:31 AM
Its a prototype TransWarp coil! :D
Interesting as always ClaNZer.
Post by: CLaNZeR on August 31, 2010, 07:11:18 PM
New 24 point Rodin Starship coil all wound
http://www.youtube.com/watch?v=Ol7n3Z7vpMA
Will do some tests tomorrow.
Post by: Jimboot on September 01, 2010, 05:51:00 AM
Really enjoying the vids! I've been looking for more info on the principle. Any recommended reading?
Post by: Jimboot on September 01, 2010, 06:56:35 AM
Wow i am reading this http://markorodin.com . Makes a he'll of a lot of sense to me.
Post by: CLaNZeR on September 02, 2010, 04:30:42 PM
Few More Videos
First 5 tests on 24Pin Rodin Starship Coil
http://www.youtube.com/watch?v=4VehHJMYaPM
By using two windings and having the current run in reverse directions, you can get rid of BEMF all together. And the Rotor still spins!
CLaNZeR 24 Pin Rodin Starship Coil Part 2
http://www.youtube.com/watch?v=hGH2FyVHFw0
Another Config that shows no or little BEMF
CLaNZeR 24 Pin Rodin Starship Coil Part 3
http://www.youtube.com/watch?v=7gWR6nOPp28
Small load and wiring coils in series drops current in half but RPM remains the same..
CLaNZeR 24 Pin Rodin Starship Coil Part 4
http://www.youtube.com/watch?v=Y0OhFu_J4ao
Cheers
Sean
Post by: Jimboot on September 02, 2010, 07:08:41 PM
I'll be winding a torus tonight. Going to hook it up to my ossie motor
Post by: e2matrix on September 02, 2010, 07:15:22 PM
Quote from: Jimboot on September 01, 2010, 06:56:35 AM
WOW is right - quite the staggering implications across all realms if it all goes forward as it seems he is envisioning.  I always believed in the power of the torus and especially the Rodin style.
Nice work on Clanzer's setup too.  Does the Rodin starship coil create a toroidal field also?
Post by: Cloxxki on September 12, 2010, 01:50:34 PM
Could anyone hypothesize how a similarly wound coil would perform when:
- 9 pins are used
- 1-2-4-8-7-5 winding&stacking pattern for first wire
- interlaced with a second wire 3-6-9
- also a coil wrapping the stack of, say 30 winds as above, going up the 3 axis, down the 6, up the 9, down the 3, etc.
- then a simple coil wrapping the 0 axis.
Too random?
Post by: CLaNZeR on September 12, 2010, 06:08:35 PM
Few more videos
CLaNZeR adding Magnetic Bearings to the Rodin Starship Coil Config
Thought I would have a go at trying the magnetic bearings. Again a quick bodge, but next step it to get it mounted in a solid fashion and see what sort of high speeds we can hit
http://www.youtube.com/watch?v=Y-3RtEPfYgg
CLaNZeR trying Magnetic Spheres with the Rodin Starship Coil
The Magnetic Spheres turned up. So testing them out.
http://www.youtube.com/watch?v=f3tBt38VTkc
CLaNZeR Rodin Starship 85mm Coil and Axle Rotor Part 1
Looking to see if a an Axle motor using the Rodin starship coil produces much BEMF. 85mm Coil made for this one
http://www.youtube.com/watch?v=izBpoT3PPxI
CLaNZeR Rodin Starship 85mm Coil and Axle Rotor Part 2
Doing the LED test and pickup Coil on new Axle config
http://www.youtube.com/watch?v=OAa8nWm5AOI
CLaNZeR Dual Switching the Rodin Starship Coil
No Reed switches, No Hall sensors, just pulsing both windings opposite ways. Using a Pic Chip to pulse and two SSR relays to switch each winding
http://www.youtube.com/watch?v=rYtlWaI07WU
Post by: CLaNZeR on September 12, 2010, 06:09:17 PM
Quote from: Jimboot on September 02, 2010, 07:08:41 PM
How did it go Jimbot?
Cheers
Sean.
Post by: Paul-R on September 13, 2010, 08:35:50 AM
Quote from: CLaNZeR on August 30, 2010, 12:12:31 PM
Please forgive my ignorance, but what does a Rodin, or indeed the Rodin Starship
coil actually do?
Post by: ALVARO_CS on September 13, 2010, 05:22:47 PM
Quote from: Cloxxki on September 12, 2010, 01:50:34 PM
- 9 pins are used
Too random?
something like this ?
I´m on it
Post by: nievesoliveras on September 15, 2010, 11:24:23 AM
I do admire the work done on this thread!
Jesus
Post by: Jimboot on November 11, 2010, 07:22:59 AM
I've been a bit obsessed with the rod in coil. It drove the osier motor well. I have now wound four coils and have been messing around with them as speakers. I have also wound one tetrahedron coil. Im putting up vids here http://YouTube.com/jimboot2 a few folks a heck of a lot cleverer than I am  are working on a firing circuit and there is a google group. Also do a search for Randy powell on yt for more lessons on the maths.
Post by: penno64 on November 11, 2010, 02:05:13 PM
Hey Jimboot,
Nice to see you around again,
How's melbourne weather.
How close to a selfrunner did you get to ?
Have a good one,
Penno
Post by: Jimboot on November 13, 2010, 06:45:19 PM
Hey Penno, the weather is better than Sydney.. :) 32 deg on fri, 12 on Sat. I love melbourne weather. I got a long runner but not a self runner. I'm really over reed switches :) I had a neo sphere spin up to ear piercing speeds last night on 50mA so im focussing on the Rodin.
Post by: penno64 on November 13, 2010, 07:15:21 PM
Hey Jim,
Just starting to warm up in Sydney.
Nice to hear you're getting results with rodin.
Hope you'll put up a video soon.
Penno
p.s. btw, where are you getting the spheres or tube mags that are diametrically magnetized. I am having troble locating aussie supplier on ebay or local supplier?
Post by: Jimboot on November 13, 2010, 09:57:13 PM
I couldnt find any locally either so I just ordered from K & J Magnetics.
Everything's a bargaing given the AUD atm :D
