Overunity.com Archives
News announcements and other topics => News => Topic started by: kalakaflaca on September 21, 2010, 05:13:53 PM
Title: Polymer conductor help
Post by: kalakaflaca on September 21, 2010, 05:13:53 PM
Dear Friends,
I am working on a sensor project but I can´t continue because still I can´t find any polymer conductor reatil..polymer conductor is perfect for my project due to it´s flexibility.I have a small piece of this conductor  it looks like a rubber band or some kind of soft polyethylene but I need some more.
I really tried hard in google and everywhere to get some of this material but still I don´t see any supply.
Any info. would be gratly appreciated.
H.D
Title: Re: Polymer conductor help
Post by: mscoffman on September 22, 2010, 01:27:57 PM
@kalakaflaca
Hi! I think you are referring to "zebra strips", They are a micro stacks of conductive
elastomer layers separated by insulating elastomer layers built like a sandwitch.
They look like rubber bands. They are used to make contact between the the
(indium-tin-oxide) clear conductors on LCD display glass lenses with the PCB
printed circuit board connector pads.
Web Link to some;
http://www.alibaba.com/showroom/zebra-strip.html
Google "zebra strips" for more info.
:S:MarkSCoffman
Post by: kalakaflaca on September 22, 2010, 04:08:22 PM
Yes Mark, that´s perfect to my project..my bad minimun order is 500 up 5000!.. I need only 1 or 2 ft to say of that polymer.. :-\..now I´ll try to google : rubber connector..conecting pads..etc..maybe I find other supply to buy a few pieces only  of that conectors..maybe ebay ..who knows..
Thanks again mark for your tip..very appreciated  :)
Post by: DreamThinkBuild on September 22, 2010, 06:55:15 PM
Hi Kalakaflaca,
Not sure what tolerances you need on the sensor but you might be able to make your own with some polymer hot melt then mix with atomized copper. Hot melt is a pain to work with(pours like honey) but if you are making a thin sheet it is easy to use with a large cook pan. It usually melts around 250-350F, once it is melted you could sift a good layer of atomized copper into the mix and let cool, cut to the size or shape you want. I've used hot melts to create round pipe seals on one of my projects. The hotmelts are like Jello when fully cured but strong and stretchy. You can also cut them up and remelt them if a mold goes bad.
This place carries atomized metals...
http://www.douglasandsturgess.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=DAS&Category_Code=FILLERSTHICK-ATOMMETAL
...and hotmelts
http://douglasandsturgess.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=DAS&Category_Code=FLEXCASTING-HOTMELT
Post by: kalakaflaca on September 23, 2010, 03:24:32 AM
Thanks dream for your interesting post..unfortunately they don´t shipp international... i found this other where to make different conductive pads using easy to get materials  http://www.instructables.com/id/Make-Conductive-Glue-and-Glue-a-Circuit/?&sort=NEWEST&limit=40&offset=80  I am making a homemade dancing pad, not knowing how sensors under the arrows work I bought  a sensor  I found is two polymers strips encased in flexible plastic or rubber separated by a tiny line ..when stepped down the arrow both polymer make contact sending signal to the board..that´s all  science..40 of those sensors  cost me around 600 dls!!..much money..so I´m looking to make my homemade sensors ..finding the way to make mine by myself  it could save me a lot of money..I could make all of them for about 20 or  less..
again Dream thaks for your post
Post by: baboyes on September 27, 2010, 11:18:22 PM
Handling instructions are immediately relayed to "switchers," who operate tractors in the yard to receive trailers from over-the-road drivers. Switchers receive their pickup and handling instructions by wireless transmission to an Intermec computer mounted in the cab.
replica sunglasses (http://www.glassesite.com/faq.html),
Supervisors also are notified of arrivals in real time on their handheld Intermec wireless computers.replica sunglasses Supervisors use the computers to view all work activity, redirect resources, and make updates as needed.
age of conan gold (http://www.aocgoldweb.com),
Switchers deliver trailers to the designated dock door for handling.age of conan gold Workers then use an Intermec reader tethered to a wireless computer mounted near the dock door to scan a bar-coded number label that is applied to each item in the shipment.
replica sunglasses (http://www.fashionsunglassesale.com),
The scan triggers an inquiry on the dock and yard management system that matches the number with the manifest records.replica sunglasses Dock door workers then receive handling instructions without having to read through pages of manifest and customer The scan also saves significant time previously required to enter data into Old Dominion's host system. Once information is in the host system, it quickly becomes available to customers through web-based applications.
aion gold (http://www.aionkina4u.com),
The dock-door computers and scanners help get trucks loaded and back on the road quickly.aion gold Every number label is scanned as the item is loaded onto the truck. The scans automatically build a shipment manifest record, which eliminates the time and labor required to key-enter the information. System software verifies that each scanned item is part of the shipment and sends an instant wireless alert if there is a mistake.Old Dominion is saving more than 50 cents per bill using the system.
Designer Glasses (http://www.glassesale.com),
The Power of Information
The point of all this trucking technology is simple: Designer Glasses carriers deploy it to streamline operations and cut costs while at the same time providing better service to customers.
world of warcraft power leveling (http://www.wotlk-power-leveling.com/wow-buy-power-leveling.asp),
"Having real-time information helps us cut transit time and improve visibility,"world of warcraft power leveling says Old Dominion Vice President Chip Overbey. "That's where we start providing real value-add for our customers. If they can go from holding five days of inventory to two days, it lowers their inventory costs, improves their cash flow, and starts to reduce their overall cost of goods."
