Overunity.com Archives
Solid States Devices => solid state devices => Topic started by: Dadas123 on September 30, 2010, 05:49:41 PM
Title: Moray Radiant Energy device - connecting the dots
Post by: Dadas123 on September 30, 2010, 05:49:41 PM
1. Henry Moray writes about high frequency - the highest sun radiant power is at 600 THz which is just below visible light.
2. He got high voltages (10,000V to 250,000V) - P=U*I (P - power in Watts, U - voltage in Volts, I - current in Amps) - obviously, the higher the Volts, the lower the Amps in order to get the right Watts, so 1000W at 110V makes 9.1A and 1000W at 10,000V makes only 0.1A.
3. Somewhere above 1016Hz to just above 1021Hz is the HEF (High Energy Frequency range - X-rays, Gamma rays). Ultraviolet is from1015Hz to 1017Hz - the high part inside HEF range.
4. The Swedish Stone is Germanium - Germanium Diode - obviously, in Moray's times this was an amazing discovery! Moray also writes exactly which minerals he used for his Moray Valve and there are radioactive minerals there.
5. Moray was using Radon (half-life ca. 3.8 days) which is a product of Radium (half-life 1600 years) in his therapeutic device.
All this information can be found in the internet - Moray's books - available in pdf - all you need is google.
The energy is out there, everywhere, just waiting to be tapped.
It's no magic, it's not something from nothing.
We are not producing energy, just transforming one form of energy into another. All energy is already there, it is not created and can not be destroyed, just recycled!
Put the dots together and apply some electronics background and you should get very close.
Just remember that high voltage and high frequency are pretty dangerous and one must know how to deal with them so as not to kill himself.
And - naturally, all our everyday appliance don't work on high voltage, that's where the transformers come in handy.
Frequency is a different issue, for lighting and electric heating frequency does not matter a lot, but for many other device it does. But electronics can deal with this, too.
