Hello all.
A few days ago I received the link (presented below) about this product, which can reduce fuel consumption. Now, I realize this is not free energy product, but until we can buy one of them (soon hopefully) the only thing we can do is somehow reduce the costs of what we have. And this product seems to do just that. I haven?t tried it yet, because it will be available as from 15th of May (in Europe), but I know I will buy one set. There is nothing to loose. And judging from the description it can be used in biofuels also. And on top of that, this can be a business opportunity also, because as far as I can understand the marketing of this product has not yet begun (but I?m not sure about that).
The link:
http://www.fueladd.myffi.biz/en/section_100.asp
Please, tell me what do you think about this product?
sounds like a con. a catalyst is something that does not react yet you have to replenish it? It helps the piston slide more effectively? the fuel/ oil does that. Molyslip and teflon lubes work well and only have to be applied once - after the engine has bedded in
that will do the same thing as the ACETONE, i dont know about this product but use ACETONE its cheaper and its work!
go to this link and see and learn a lot of stuffS! http://peswiki.com/index.php/Directory:Fuel_Efficiency_Retrofits
with my jeep grand cherokee 4.7L (v8), on the highway, i go from 13L/100km to 10L/100km without the acetone (i changed my oil, better spark plug(haloplug), ground wire system etc...), and i need to try a lot of other stuff like Warm air intake, condensator etc... i used acetone on my older car, its cost mostly nothing to try btw! i will use acetone on my jeep when i will finish with some other stuff, but sine i dont drive a lot, its not really an issue for me :)
Add about 0,5 % Acetone in your fuel (gasoline or diesel)
you drive 20% longer .
pese
this is cheaoes and safest way to save your money
Hi Pese,
do you have to modify then also any hoses or anything else
inside the car. when you add 0.5 % Acetone ?
As Acetone is a very good solution to dissolve all plastic parts
in it, I wonder if you don?t have to change anything in the car then ?
fuel dissolve stuff too, on vehiclue for the amount of acetone you put, its safe. its not like putting 50%, its really a small amount and with this amount is merged in the gaz, this help to vaporize the fuel a little better and cleanup a little bit at the same time
in fact see acetone as a additive
@harti
notghing must be change .
no damages on plasik or rubber parts
(remember that als benzol is added to gasoline - in some countries) in pure condition this is also agressive to plasik and rubber.
i found this over 1 year ago in www , and test them , also some frinds in suisse , save 25 to 30% percent , the motor wilii give cleaner inside
I looked for some links about that.
it give a lot to "learn" about it:
http://www.pureenergysystems.com/news/2005/03/17/6900069_Acetone/ benzin diesel
http://peswiki.com/index.php/Directory:Acetone_Additive:FAQ zu benzin diesel UND wasser !!
http://peswiki.com/index.php/Directory:Acetone_as_a_Fuel_Additive !!
http://www.osti.gov/fcvt/2000-01-2214.pdf aceton not exeed 1,5% !!
http://www.lubedev.com/smartgas/hydrogen.htm gasoline diesel proban acetone enz.
