Interesting:
David Sannes - Theory of Everything Part 1: http://www.youtube.com/watch?v=LornoMpzFW8 (http://www.youtube.com/watch?v=LornoMpzFW8)
David Sannes - Blog: http://davidrsannes.blogspot.com/ (http://davidrsannes.blogspot.com/)
QuoteI thank God that a creative genius at Steorn in Dublin did an experiment in 2006 that led them to confirm the practical implications of my work. It is the only hope I see for the survival of the human race. I love their January 30, 2010 proof of principal tests, of my following scientific work. It was so simple.
I similarly thank J.L. Naudin, the great French scientist, for his proof of principle test device.
QuoteSIMPLE EXPLANATION OF THE SUN SANNES MACHINE'S INNOVATION
The patent application's exemplary embodiment graphic
representations depict a powerful neodymium iron boron rod,
permanent magnet, as a powered, weight bearing piston, cutting at
right angles through the magnetic fields of a relatively weak
electromagnet.
The electromagnet's controller first switches the electromagnet on
while its south seeking pole is opposed to the permanent magnet's
north seeking pole. The permanent magnet, as encased as part of a
weight-bearing piston assembly, will accelerate upwards toward the
south seeking pole of the fixed electromagnet. Just before the
opposing poles kiss with machine shattering force, the reversible
electromagnet will be mechanically switched so that the powerfully
sought south pole's magnetic field will collapse and "Morph" into
becoming a repulsive north seeking pole piece - which in conjunction
with the more powerful north seeking pole of the permanent magnet
piston - will serve to propel the aforesaid piston assembly away. As
the piston descends, it will be attracted by another reversible polarity
relatively weak electromagnet. The poles of the lower electromagnet
will then be reversed.
Thus, both strokes of the weight bearing permanent magnet piston
assembly will be "powered" strokes.
So on, and so forth will the generator/motor cycle. A fraction of the
mechanical force will be converted to electrical energy by this process,
and will power the electromagnet.
CONCLUSION
EXCEPT TO BE STARTED, THE MOTOR/GENERATOR
WILL THUS NOT UTILIZE EXTERNAL FUEL OR FORCE.
Test model where you can see one version of the concept. Both the EM and PM could be greatly optimized to achieve better results.
