Increase HHO with lawton
Started by guruji, November 11, 2011, 03:26:07 PM
a.king21
Yes it should increase production but you have to watch for the water heating up. If it heats up too much you could lose production. At the point of maximum production there will be a current draw drop and plasma will be produced. It is actually cold fusion if you want to develop it. The process is still only COP> 300% however as at presently configured.  If you are using the phase locked loop circuit it can go to 6 amps but again watch for water heating up. It is not recommended to push the system. If you want more output, better to just make a separate system. 6 cylinders is the maximum recommended but your output could actually drop. The problem is the ions are magnetised and don't want to move. Some people have experimented using magnets to shift the ions. Make sure your cylinders are in resonance. Good luck.
guruji
Hi King thanks for the info. I am using two chambers right now connected to one outlet.
Ok so I should increase more cells than.
Thanks
