nasa has invented a device to obtain energy from earths rotation
Started by raaaid, August 26, 2005, 08:54:54 AM
mscoffman
Yes it's a Faucault pendulum. The Faucault pendulum does not go back and fourth based on free
energy but if energy is supplied to it, its pointing direction will rotate once around every 24
hours. Using the same force that turns rotating weather systems in certain directions; The
Earth's Corealis Force
The trick is to convert this very small amount of round-the-clock energy into drive energy to make
the pedumlum go back and forth, which is very easy to do with a Bedini drive.
It turns out that a person working with the original Focult Pendulim acutally built this into a
perpetual motion machine based on these principles but it probably involved operating the
pendulum in a vaccume.
I have a clock software that uses a photocell to convert a computer microcontroller into a
a sun dial apperatus that can convert the changing of length daylight of the into a time and date.
Over time with continuous electrical energy the clock will reduce it's phased locked time error to
something very close to the minute clock time. I made its equation-of-time fixed but it's, actually
quite variable really. It requires 32 bit calcs. Starts up from powerdown. Method won't
work when its location is near poles.
telecom
24 hours is at the pole, on the latitude of Paris around 30 hours.
Its driven by the rotation of the Earth itself.
The pendulum is not practical, much more practical is a gyro.
Low-Q
Quote from: sm0ky2 on January 31, 2017, 01:59:47 PM
I don't know how this has gone completely unnoticed
I found this thread while looking for a place to post
Something I discovered about Earth's Gravity.....
This is a perfectly feasible gravity powered device.
It operates by combining gyroscope physics with
A historically proven earth powered pendulum clock.
We know how to do this. We can build these
"Earth Powered Generators" with existing technology.
Gyroscopic Precession tuned to the rotation of the Earth
It's perfect!
Except it takes 24 hours for one revolution. If you twist your hand, holding a powerball, and twist one turn in 24 hours, I don't think it will spin up much.
A larger powerball with much more mass, would be better, but then you need super strong material to keep up with the forces that wants to break it apart. I have had this idea myself many years ago when I got my first powerball.
It is in theory possible, but you need a massive powerball and large diameter to achieve any useful output. And the earth rotation will slow down more than it already is. So, I hope no one build such a thing, because I think my working hours are long enough as they are, LOL!
