Coincidence ?
Started by innov8, July 10, 2007, 02:27:58 PM
IronHead
The guy that made the thing came out in a forum and told everyone how he made it.
I have the forum and page some where . he even showed the original wire frames.
And the modified  Klingon text.
I don't really want to start a debate , I will see if I can find the page . The guy use to show his work over at highend3d.com
giantkiller
Quote from: IronHead on July 10, 2007, 04:46:50 PM
This is the one I want to know the power source in   :o
http://www.youtube.com/watch?v=N64H1g6apQo
In a 3d package the opposite applies to real life  it is gravity that is hard to mimic
and make things look like they react to gravity forces in an natural way.
That was done with extra spray starch...
--giantkiller.
Bruce_TPU
The "Drone" story is actually far stranger than any poster here seems to realize.
Please go to the following website and read all of their drone reports, as well as a documented report from an individual who worked on this project.  The writing is not Klingon.  Be sure to read the CARAT report there as well.  Enjoy!
http://www.earthfiles.com/
IronHead
Really . Maybe the guy I found was not the real guy then . I thought I had it bookmarked but can not find the page . Might be he was just a 3d replicator. This is far more interesting than I had thought . I just never looked any further once I saw those art posts .
Thanks btentzer
Ironhead
gn0stik
It's a very nice story and all, well crafted. But those artifacts are obviously made in maya. A few of the pics look real, but he gives it all away with the artifacts.
It's fake.
