Wavefront : 35165.5
Started by darkspeed, January 06, 2010, 01:15:22 AM
darkspeed
Bruce, can you please give me a link to your thread???
Bruce_TPU
Quote from: darkspeed on January 16, 2010, 07:12:01 PM
Hi Dark Speed,
Please start at the following and read to the end.  You of all people will understand.  Finally ... someone... LOL   :o
http://www.overunity.com/index.php?topic=2300.msg200211#msg200211
Cheers,
Bruce
