The Theory of everthing Solved
Started by Dave45, November 09, 2010, 07:16:18 PM
Dave45
Forget the physics you've been taught and listen to this guy he explains what electricity is and much more. FINALLY
http://www.toesolved.webs.com/
Dave45
Dact
Agree totally with this theory. Always thought that magnets were somehow at the root of it all!
"Terror hearts out, always;
Terror fabric, NEVER!"
shylo
Hi all ,Dave I tend to agree that modern physics is on the wrong track.The chemical battery for instance...it says that when sulfuric acid and water are mixed,...to become an electrolyte,...the sulfuric acid breaks down into hydrogen and sulfate.....hydrogen becomes pos.,..sulfate becomes neg,.....when you insert a copper bar and a zinc bar into the solution....the positive ions of the hydrogen draw out the excess of electrons in the copper,...making the copper positive........also the negative ions of the sulfate pull positive ions from the zinc leaving it with a net negative charge....then if connected by a conductor between the copper & zinc...current flows.... IF THIS IS TRUE ...there should be no flow at all....all of the gaining and losing of pos. & neg. ions should take place within the solution itself,...flow takes the path of least resistance,... within the liquid not through a conductor which has built in resistsnce............this is the one of the major flaws in modern science............the theory of voltage and current are wrong too ..shylo
