Thanks to ALL for your help!!
Does anyone have any idea how to apply Frank Znidarsic's formulas
Started by Tempest, November 15, 2010, 07:56:41 PM
jbignes5
Quote from: shylo on January 02, 2011, 08:10:47 PM
Hi Tempest....I think that the electrical field is just a by-product of the magnetic field and the force of gravity.Gravity and magnetism are =, but opposite. They say there is a nucleus ,protons and neutrons +, with orbitting electrons -. Why don't the electrons just collapse into the nucleus?? Gravity, the constant struggle to keep them apart is the potential for electrical production..........it is Saturday lol........shylo
No no no... Magnetism is the byproduct of the electric field. Magnetism is the skinned layers around the source. These two fields move in 90 degree fashion. Just like we have when we take two wires and put them crossed. They will not interfere with each other. It is the same principle as that except that magnetism is the skin itself between two charge layers.
Matter is merely statically clung material that was attracted to the source charge. The allowed the source to be encapsulated by the matter that was in resonance with the source charge. what forms around the matter are charge spheres separated by a density change that causes a skin effect. These layer out from highest charge density to lowest from the center charge. Mind you to pay specific attention to the word density and layers.
If one wanted to see how matter looked on the smallest scale all one would have to do is look further out in scale from what we want to see. Ie our planet. If this is a fractal nature then it should repeat itself further out of the fractal. As we can see our atmosphere has layers and density changes and skins. The skin in this case is the lowest scale of water to the highest scale of our ionosphere. The clouds being in layers around our world tells us that there is some kind of density change there. Have you ever flown in an airplane. The cloud tops are pretty flat or nearly so.
Now relate that to the atom and we can see how it works or nearly so.
If we start to understand that in the middle of our world is a huge potential. A Static Potential created from all the rubbing and flowing going on in there. This potential at some point radiates out of our planet like a huge pom pom. You know the yarn ones you used to make as a kid. These fingers I like to call them are the virtual connection to the solar system. They reach quite far out into space even connecting to others and gaining in strength. Most of the fingers rotate extremely fast in two directions. One being from the base to the tip and the other in a helical style. Have you ever watch a string on a base chello in slow motion? Well times that by a thousand for an atom or in the case of our planet by a quadrillion or plainly infinite.
