New permanent magnet motor on youtube from Roobert33
Started by hartiberlin, November 17, 2010, 05:47:43 AM
Omnibus
Quote from: maw2432 on January 02, 2011, 08:25:08 AM
@ Clanzer
Nice work... Looks like you have most of the Kinks worked out with the cam.   I am looking forward to seeing your replication with the stator magnets installed.
Take a look at Clanzer's latest video.
http://www.overunity.org.uk/showthread.php?527-Flexible-V-Track/page2
Just saw it on my laptop. You're getting there, brother. Good luck.
maw2432
OK here is my attempt to use a Leveraged Approach to solve the problem.   I am waiting on magnets... should be here by Friday.    Anyway,   there is a lever at the bottom to lift the stator arm on the right side.  It provides a little over 4 to 1 leverage.  The cam is on the wheels left side.  I know I need to make a better cam but I just wanted to show how I visioned a lever to do the lifting.   I moves the stator up about 5 to 6 mm but very easily.  I put a couple steel bearings on the stator to add some weight for testing .
maw2432
McGiver30
I would certainly agree with the last test rig posted on here for a chance of success. I have thought the exact same principle. I would change one thing and add one thing. I would make the rotor much larger and I would add a weight on shaft to help momentum to get past the cam lift/sticky spot.
Omnibus
Good build, @maw2432. Waiting to see how it will behave with the magnets. Good luck to you too.
